How to Change Differential Oil
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tacoma65, Feb 1, 2017.
  1. Feb 6, 2017 at 11:03 AM
    tacoma65
    tacoma65 [OP] Member
    los angeles
    09 tacoma 4cylinder
    Thank you for the input
  2. Feb 6, 2017 at 11:04 AM
    tacoma65
    los angeles
    09 tacoma 4cylinder
    Jajajajajajaj
  3. Feb 6, 2017 at 11:04 AM
    tacoma65
    los angeles
    09 tacoma 4cylinder
    Take Pictures when you do it. Thank's
  4. Feb 6, 2017 at 11:07 AM
    tacoma65
    los angeles
    09 tacoma 4cylinder
    Yes They Toll me Around $400 to $500. is a lot of Money
  5. Feb 6, 2017 at 11:11 AM
    tacoma65
    los angeles
    09 tacoma 4cylinder
    That's Why I'm here Learning from the pro's Thank's
  6. Feb 6, 2017 at 11:12 AM
    tacoma65
    los angeles
    09 tacoma 4cylinder
    Thank you
  7. Feb 6, 2017 at 2:14 PM
    DGXR
    DGXR Well-Known Member
    Friend
    Sacramento, CA
    2006 2.7L SR5 2-wheel drive
    I have a 2006 2wd 2.7 and the rear axle lube capacity is listed as 3.5 quarts. I used 75w90 but 75w85 or 80w90 will be fine too. As long as it's in that weight range we will have no issues.
    I would not use 75w140, which is completely overkill for your 4-cylinder truck... unless you beat the hell out of it all day every day. Even then I would still use a 75w90 :)
    tacoma65[OP] likes this.
  8. Feb 6, 2017 at 2:30 PM
    Blockhead
    Blockhead Well-Known Member
    Pittsburgh, Pa.
    2024 Silver SR5 DCLB
    The math doesn't add up on their end. That would be free labor based on what they quoted you per quart of fluid. Doesn't surprise me coming from a dealer.
  9. Feb 7, 2017 at 9:18 AM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    For our rear diffs, higher second number means the oil will be more stable and won't thin out as much when the diff heats up (about 11% of engine power is lost as friction heat in the rear diff). There's no worry of the oil being too thick, as 140 weight gear oil when hot is still thinner than 75 weight gear oil when cold. I used Castrol 75W90 synth and got some chatter when powering out of corners. Switched to Quaker 75W140 synth 2.5 years ago and the chatter hasn't appeared since.
    Oils with bigger difference between first- and second numbers tend to be more difficult to manufacture, so 75W140 tends to cost slightly more than 75W90, etc. Toyota is specifying the "minimum" with 75W85. In theory 75W90 would cost more than 75W85, but other market mechanisms negate this.
  10. Oct 8, 2017 at 8:55 AM
    KnobleOne
    KnobleOne Member
    Larry
    Upsate New York
    09 DblCab Longbed TRD
    Found Redline 75W85 GL5 at Summit Racing for $16.49 a quart
