how to change interior lights
Discussion in 'Lighting' started by ezjumper8, May 4, 2013.
  1. May 4, 2013 at 11:57 PM
    ezjumper8
    ezjumper8 [OP] Ethan
    ethan
    camp pendleton, ca
    white tacoma dbl cab 4WD sport
    20% tint all around, blacked out badges, flowmaster 40 series and tip, rock hood deflectors, window deflectors, home made baja bumper, 17" XDseries wheels on some nitto terra grapplers, bright white led interior lights, blue needle on white gauges, cb antenna, with cobra radio.
    im thinking about changing all my switch lights, from my window switches to my air controls, clock and steering wheel controls. how difficult is this process?
  2. May 5, 2013 at 12:05 AM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Very tedious.
    If you are not comfortable handling surface-mount electronic components, pay someone to do it.
    The only actual lamps in the truck are on the HVAC dials (two lamps) and the dash pushbuttons to the left of the wheel.
    Everything else is a small "chip" LED soldered to a board.
