how to change sparkplugs 2TR-FE
Discussion in '4 Cylinder' started by YotaMan2007, May 16, 2011.
  1. May 16, 2011 at 11:50 AM
    YotaMan2007
    YotaMan2007 [OP] Well-Known Member
    Brian
    where my boots and ruck lay
    07 Tacoma 2wd
    K&N Drop-in airfilter, secondary airfilter removed, Satoshi Mod, Kenwood Stereo System, Gibson catback system , Painted Steelies, Offroad Lights, Fatbob's spacer lift
    Since I haven't seen a write up on the 2TR for the sparkplugs and my first time was trial by fire, I've decided to do one for the guys on here.
    everything you'll need:
    10mm socket
    1/4" drive Rachet
    extension
    9/16" sparkplug socket
    philips head screwdriver
    flat head screwdriver
    new sparkplugs (i used NGK laser Iridiums)
    anti-sieze (highly recommended if you don't want the threads to break off next time)
    rjbiii, Tex-Tac and akaboras like this.
  2. May 16, 2011 at 11:56 AM
    YotaMan2007
    Brian
    07 Tacoma 2wd
    Step one:
    Dismantle the Intake starting with the s bend piece, then remove all the bolts holding the intake (resonater/silencer?). the bolts are marked in red. Then disconnect the pieces marked in blue.
    Tex-Tac likes this.
  3. May 16, 2011 at 12:01 PM
    YotaMan2007
    Brian
    07 Tacoma 2wd
    movew the larger thing out of the way so you have full access to the top of the engine. Start unplugging the conntecor going to the sparkplugs. Those are marked in blue. then loosen the bolts holding the coil in place. Those are marked in red.
    percy4029 and Tex-Tac like this.
  4. May 16, 2011 at 12:07 PM
    YotaMan2007
    Brian
    07 Tacoma 2wd
    one at a time remove and replace the sparkplugs going from front to back. makesure you have an extension that will reach all the way down to the spark plugs and leaves you alittle room to work with. when you go to put in the new sparkplug be sure to put a line of anit-sieze on the threads. it make it alot easier to replace the next set you get. DON'T BE LIKE ME AND DO THIS AFTER YOU JUST TURNED THE ENGINE OFF. DO THIS WHEN THE ENGINE HAS COOLED OFF UNLESS YOU ENJOY GETTING BURNED! :eek:
  5. May 16, 2011 at 12:10 PM
    YotaMan2007
    Brian
    07 Tacoma 2wd
    after you have replaced all four sparkplugs put everything back in where it came from.
    Note: I am not responsible for any accidents/personal injury/damage to vehicle. if you mess this up then you don't belong under the hood of any car or truck. :D
  6. May 16, 2011 at 3:21 PM
    george3
    george3 Well-Known Member
    new jersey
    tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    Thanks. Chris4x4 has a 4.0 so he did a very good write up for the 4.0. Thanks for the 2.7 write up.
    rjbiii likes this.
  7. May 16, 2011 at 5:04 PM
    91r100gs
    91r100gs Understand the Voice Within
    Dan
    Kansas City area
    '08 Impluse Red SR5 I-4
    Factory bed mat, TacomaWorld.com sticker, EGR In-Channel Vent Visors, AFE ProDryS drop in air filter
    Thanks Bro
  8. May 16, 2011 at 5:11 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Any spark plug change must be done on a COLD engine.
    percy4029, sly1 and 95SLE like this.
  9. May 16, 2011 at 5:16 PM
    george3
    new jersey
    tacoma
    So you don't burn your hand or something more technical ?
  10. May 16, 2011 at 5:29 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Because the heat makes the aluminum head softer, and more likely to strip threads. Also, as it expands with heat, you might think the plugs are torqued, but when it cools, they can become loose. Ive seen a few times when the plugs have loosened to the point that they shoot out of the head, and put a little dent in the hood.
    fast5speed and House of Chaos like this.
  11. May 16, 2011 at 6:00 PM
    george3
    new jersey
    tacoma
    Thanks Chris, good info. I suppose I should have known or read this B 4 but I don't remember it. Thanks again for the answer.
  12. May 17, 2011 at 7:42 AM
    YotaMan2007
    Brian
    07 Tacoma 2wd
    i was in a rush when i did mine, i had alittle more than an hour for workso i wanted to get it knocked out.
  13. Jun 23, 2011 at 8:56 AM
    Collins
    Collins Well-Known Member
    North Carolina
    09' Tacoma, 2.7L, 5spd, 4x4
    Thanks man, good info.
    Doing that this weekend i hope.
    PC
  14. Jun 23, 2011 at 9:45 AM
    george3
    new jersey
    tacoma
    How many miles on your '09 ?
  15. Jun 23, 2011 at 12:44 PM
    pinktaco808
    pinktaco808 Hot Steppa
    how many miles? what spark plugs you guys used?
  16. Jun 24, 2011 at 5:29 AM
    Collins
    North Carolina
    Hey G3,
    Just coming up on 10k, i'm sure the plugs are fine, i was planning
    on getting in there and taking a look at gaps, wear etc...for the hell
    of it...GF is out of town this weekend, so i was hoping to have a truck
    tech weekend.
    I'll probably use NGK's if i do change them, but i'll see what the Denso's go for.
    btw, is there a special anti-seize to use?...while i have the plugs out
    i'm def. going to do that.
    PC
  17. Jun 24, 2011 at 7:10 AM
    george3
    new jersey
    tacoma
    Interesting. I thought Tacoma recommends 2.7 change at 100,000 and 4.0 at 30,000. My 2.7 has 43,000 - I don't think I'll wait for 100,000 but 10 seems premature - I'm sure they will be fine when you inspect them. I just use regular anti-seize - there may be other opinions. Toyota says no anti-seize but I don't want problems getting them out next time - dissimilar metals.
  18. Jun 24, 2011 at 7:59 AM
    YotaMan2007
    Brian
    07 Tacoma 2wd
    sparkplus will run for sometime, my friend bought a silverado with 220k miles on it with the original sparkplugs in it. :eek:
  19. Jun 24, 2011 at 8:17 AM
    george3
    new jersey
    tacoma
    One reason not to run them for such a long time is that you will have a hard or impossible time getting them out. Once they break off in the head you are F'd. A lot of work and or $.
  20. Jun 24, 2011 at 8:21 AM
    TheMrGExperience
    TheMrGExperience Because Tacos are too mainstream...and Im poor.
    Garrett
    Slidell, LA
    01 GMC Sierra z85 4x4 4.8L RCLB
    Debadged, 4x6 to 6x9 rear speaker conversion
    im closing in on 70k should i change mine?
