How to: Change the alternator on a 2nd gen Tacoma.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TacomaPrime, Aug 31, 2011.
  1. Aug 31, 2011 at 7:02 PM
    TacomaPrime
    TacomaPrime [OP] Cybertronian Tacoma
    Gregory
    Illinois
    14 TRD sport 4x4 Barcelona Red
    Weathertech front floor liners, window vent visors. Custom bedside decals. OEM bed mat, tonneau covrew. Added D rings to bed.
    Had to do this recently and found an easier way then what the FSM suggests.
    1. Disconnect the negative battery terminal!
    2. Remove the front skid plate. It is held in place by 4 12mm bolts.
    3. Use a breaker bar to rotate the tensioner COUNTERclockwise. This is the only socket size i cannot remember. I believe it may be 14 mm, but don't quote me on that. Once the tension is released, remove the belt.
    4. Remove the gray cap, and undo the 9mm nut towards the rear of the alternator. then remove the 2 10mm bolts near where the grey cover was. Toward the front of the alternator, there is also another 10 mm bolt holding on another clip. Undo that. Also, at this point, unplug the wiring harness plug that plugs into the alternator. Pic below.
    5. Remove the two bolts that hold the alternator to the engine block. The bottom one is not visible in the below pic.(pic below).
    The top one is 14mm, or 9/16's will work in a pinch. The top one is easy to get to. At this point, there is 1 bolt holding the alternator to the engine block. It may be helpful to have a friend nearby to hold onto the alternator for you. The bottom 14mm bolt that holds the alternator to the engine block is much easier to get to from underneath the truck, that is why I removed the front skid plate. Once you remove these two 14mm bolts the alternator will be free.
    6. Pull the alternator out through the top of the engine bay. You will have to move a radiator hose and maybe an AC line out of the way a little bit to get it out, but it WILL come out this way!.
    7. Put everything back in reverse order.
    8. Pat yourself on the back, cause you just saved your self a bunch of money on labor!
  2. Aug 31, 2011 at 7:04 PM
    98tacoma27
    Ben
    Not Beech Creek
    We just did this a few weeks ago in the Rausch Creek parking lot. We found it was easier to pull the alternator out through the fender well.
    Good write up!!
  3. Aug 31, 2011 at 7:09 PM
    TacomaPrime
    Gregory
    Illinois
    huh. Never thought about that. that would work too. Pulling it up through the top of the engine was literally easy as pie. The fsm talks about removing the fan shroud and a bunch of other stuff that is completely unnecessary.
  4. Aug 31, 2011 at 7:12 PM
    98tacoma27
    Ben
    Not Beech Creek
    Yes, I remember that. The shroud is only held in by two bolts but still seems unnecessary to remove. I seem to remember we couldn't get it through the top easily. I don't recall why though.
  5. Aug 31, 2011 at 7:28 PM
    docbrown
    docbrown Well-Known Member
    Tampa, FL
    05 Tacoma SR5 4X4
    Doug Thorley Long Tube Headers, Eclipse 6620 AVN GPS/DVD, K&N Drop-in Air Filter, Hose clamp mod, Redline Quick Lift Elites, Bilstein 5100's at .85, Firestone Ride Rite Air Bags, Weather Techs front and back, Bug Guard, and Factory Bull Bar, Wet Okole's up front, Bed Mat, LED interior lights, Fumoto Oil Valve
    Will a mod add this to the 2nd gen how to's?
  6. Aug 31, 2011 at 7:39 PM
    98tacoma27
    Ben
    Not Beech Creek
  7. Aug 31, 2011 at 7:41 PM
    UMBCrew
    UMBCrew Well-Known Member
    Nic
    Central Valley, CA
    05 6" Pro Comp Stage II
    6" Pro Comp Stage II, 305/65r17 Pro Comp Xtreme AT, Pro Comp 7033 17x9s, AFe Stage 2 Si, All-Pro Rear Bumper, Ultra-Guage, Kenwood KDC-X895, Kicker 6.5 2 ways
    Don't forget that you only want to remove the belt from the alternator and try to keep the rest of it In place so that when you go to put it back on you don't have to try and re-route the entire belt or worse try to remember how it is routed
    MuddyJackson likes this.
  8. Sep 1, 2011 at 7:37 AM
    docbrown
    Tampa, FL
    05 Tacoma SR5 4X4
  9. Sep 1, 2011 at 11:33 AM
    Crom
    Crom Super-Deluxe Member
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    Nice writeup! :thumbsup: If it doesn't die first, I'm changing mine out at 100K miles or 5 years. That and the starter too.
    :rofl:
  10. Sep 1, 2011 at 11:46 AM
    UndefinedTaco
    UndefinedTaco I'll eat all your food.
    Justin
    Tracy, CA
    Toyota
    It's an 89 Toyota Pickup. I got some stuff done to it.. FJ axles going under it soon.
    You can rebuild a starter for $21. Why buy a new one.
    :eek:
  11. Sep 1, 2011 at 12:58 PM
    Crom
    Nick
    San Diego, CA
    Millions
    Good to know. Perhaps I'll rebuild it. :)
  12. Oct 10, 2011 at 5:32 PM
    MAXTacoma
    MAXTacoma Well-Known Member
    Lexus GS 350
    What brand alternator has people used? I went online and a Toyota alt. is about 350 vs. 170 from Autozone. Any thoughts?
  13. Oct 10, 2011 at 5:49 PM
    pinktaco808
    pinktaco808 Hot Steppa
    can this be done to the 4 cylinder too? and any special tools or torquing needed?
  14. Oct 11, 2011 at 5:16 PM
    pinktaco808
  15. Oct 11, 2011 at 5:19 PM
    pinktaco808
    anymore pics? of the tensioner and grey cap?
  16. Oct 12, 2011 at 10:25 PM
    pinktaco808
    bump any help?
  17. Oct 14, 2011 at 3:42 PM
    pinktaco808
    what is that tension thing you talking about?
  18. Oct 14, 2011 at 3:50 PM
    jandrews
    '09 FourDubDee TRD OR
    I'd call that premature. Frankly, I wouldn't change either until they actually die. Original Starter and Alt in my Corolla are fine at 180+k miles. And yes, I've checked the currents recently. Usually do it about twice a year...everything in spec.
  19. Oct 27, 2011 at 10:16 AM
    WildWolfy
    WildWolfy Assitant Trainer/ Supervisor
    Just South of Dallas
    09 TRD 4x4 SR5
    Just Startin Stock TRD with Locking Rear and SR5 package
    Well the recc pulling the fan shroud so you don't chance damaging it while pulling the alt.
  20. Jul 17, 2012 at 11:12 PM
    BeeRadd
    BeeRadd Bought not built.
    Brad
    Fountain Valley, CA
    2010 DCSB LT 4x4
    LOADING...
    This thread was a big help, just replaced the alternator because a mudding trip this weekend ruined the old one :/
    was still a lot of fun messing around the engine though with this. Thx again!
