How to: Change the alternator on a 2nd gen Tacoma.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TacomaPrime, Aug 31, 2011.
  1. Nov 20, 2018 at 1:42 PM
    #61
    Rob MacRuger
    Rob MacRuger Well-Known Member
    2006 4X4 SR5 4.0
    I just helped someone do this on a V6 '06 with AT/AC. Trying to get the alternator out the top was a joke. We removed the front left tire and front splash shield and the alternator rolled right out. New one went in the same way. Would have been a one hour job max had we had just done the wheel well exit/entry first.
    BTW the one odd clip on the splash shield is the same as the two holding the front grill in place. Glad I had a spare as only that one broke.
    bagleboy, BenMara and Crom like this.
  2. Aug 27, 2019 at 7:56 AM
    #62
    Tnronin
    Tnronin Two things in this world smell like fish!
    Mitchell
    Cookeville TN area
    2006 DCSB OFFROAD
    Thanks for the thread! My diode is going bad, I'm not going to rebuild. LOL
    Would a higher amp alternator be something to look at? I don't run a lot, but to have and not need, versus need and not have........
  3. Aug 27, 2019 at 10:51 AM
    #63
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    If you've got an OR it probably came with a tow package and larger of the two alternators (140 amp I think)
  4. Aug 27, 2019 at 11:07 AM
    #64
    Tnronin
    Mitchell
    Cookeville TN area
    2006 DCSB OFFROAD
    Thanks, I know I have the tow package for sure.
  5. Aug 28, 2019 at 6:18 PM
    #65
    Tnronin
    Mitchell
    Cookeville TN area
    2006 DCSB OFFROAD
    Well changed the alternator, all in all not hard BUT I misaligned the belt just a little and frayed the inside. OK adjust it to ride until I can get another belt. I'll be damned if I don't find an oil leak on the front crank! It was dry as a bone on the outside before and now it's dripping 3 drops every 17 seconds. Crap crap crap now something else. I should have let my mechanic do it. I'm on a crappy tablet and can't get a good search to see what I have to do.
  6. Aug 28, 2019 at 6:47 PM
    #66
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Check the crank pulley/harmonic balancer really close to make sure its not separated
  7. Aug 28, 2019 at 7:06 PM
    #67
    Tnronin
    Mitchell
    Cookeville TN area
    2006 DCSB OFFROAD
    Ya don't understand that. I guess I'm not driving it until then? Not good.
  8. Aug 28, 2019 at 7:46 PM
    #68
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    If the serp belt is walking around and won't stay aligned in the grooves, often its because the two halves of the balancer are coming apart and dragging the belt around.
    Recently a guy (who's on here regularly) had a bad oil leak down by the crank seal, turns out the outer part of the balancer knocked/rubbed a hole in the timing cover.
    Not saying thats whats happening with your truck but just something to check
  9. Aug 28, 2019 at 8:01 PM
    #69
    Tnronin
    Mitchell
    Cookeville TN area
    2006 DCSB OFFROAD
    Gotcha. The belt misalignment caused this. It was fine until I screwed it up.
    MuddyJackson likes this.
  10. Aug 29, 2019 at 3:52 AM
    #70
    Muddinfun
    Muddinfun Well-Known Member
  11. Aug 30, 2019 at 6:36 AM
    #71
    Tnronin
    Mitchell
    Cookeville TN area
    2006 DCSB OFFROAD
    Per my discussion with my mechanic (who I trust) he said to see if I could find any belt wrapped around the pulley. I might be able to unwind it and fix the issue. I found some, unwound it and it's leaking twice as bad now when running. LOL.
    Limping to the shop this weekend for him to change to fix ($150) on Wednesday. Ugh.
    Sidney Vicious and b_r_o like this.
  12. Aug 30, 2019 at 6:56 AM
    #72
    Muddinfun
    Sorry to hear about your seemingly simple belt swap turning into a nightmare. Changing the front crank seal is probably a little bit above novice level. No disrespect towards your mechanical abilities, but if you're not comfortable really digging in and going for commitment, you could be getting yourself in more trouble. See if you have towing insurance on your insurance policy. If you do, just have it towed to the shop. Using your towing insurance doesn't raise your rates and there's no deductible. The worst that can happen is if you end up using it too often, they'll cancel your towing insurance.
    Larzzzz likes this.
  13. Sep 4, 2019 at 12:04 PM
    #73
    Tnronin
    Mitchell
    Cookeville TN area
    2006 DCSB OFFROAD
    No offense taken. I was able to drive it to the mechanic. He's a good guy and $150 later I can pick it up this afternoon.
  14. Sep 4, 2019 at 4:04 PM
    #74
    MuddyJackson
    MuddyJackson Well-Known Member
    Eva
    Billings, Montana
    2006 Toyota Tacoma Base 4x4 6 speed
    Good timing to come across this as my baby just let me know he's ready for a new alternator.
  15. Jan 21, 2020 at 7:44 AM
    #75
    JonBoatBilly
    JonBoatBilly If it fly's, It dies
    Josh
    Lebanon,TN
    06 Prerunner V6
    I gots some rims yall
    I replaced my alt around 151k or so, then afterwards belt started to squeal at start up and really hard turns. Replaced the belt a little later, squeaked a little that first start up and slightly when shutting down. It has been in the 20’s the pas 2 mornings and it’s screaming like a banshee now. Belt looks it’s on all the pulleys evenly. Stopped by the local Toyota service dept and the guy says to adjust the alternator?!? Once the belt has been warmed up it doesn’t do it anymore only when it sat all night or all day while I’m at work. Any ideas?
  16. Jan 21, 2020 at 9:27 AM
    #76
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Might still be a belt. I thought all Bandos were good since technically they make the OEM belt for these trucks. Unfortunately i found out that there are actually 2 Bando options. The "cheapie" Bando sucks ass and started squealing on cold startup after 2 weeks. I switched to a Gates and its been quiet for over a yr now.
    The Bando that they put on at the factory has got to be a better version. Dealers cant have brand new trucks squealing right when the truck leaves the lot.
    Id go dealership belt or Gates
    Muddinfun likes this.
  17. Jan 21, 2020 at 12:39 PM
    #77
    muddog321
    muddog321 Well-Known Member
    FL
    09 Tacoma DCSB 4wd TRD Off-Road w/e-locker Pyrite Mica
    TW 1-piece driveshaft with 1310 u-joints All Pro and Budbuilt skid plates OME Dakar rear springs 3" with 5100 5100 front set at 1.75" (3rd groove up) with stock springs Falken Wildpeak A/T3W 265/70R16 2018 TRD Offroad wheels 16x7J with +25mm offset Powerstop rotors with Z36 pads and rebuilt with OEM caliper kit Complete rebuilt rear brakes drums, shoes, springs, wheel cylinders Rebuilt rear diff with Yukon 3.73 ring/pinion Denso 130A rebuilt alternator AGM 24F Battery New OEM idlers and tensioner assembly New AC compressor New PS hose and flushed Walker SS Quiet Flow muffler Denso Iridium long life plugs #3421 (SK20HR11) OEM coolant, cap, and thermostat NAPA CV axles and new seals ECGS bushing Rhino front guard Shortened mud flaps Alziria Black Tail Lights Nilight Headlights X-Bull Traction Boards Maaco full single stage paint job 2023 Nat CV to Knuckle seals 710573 New SKF wheel bearings/hubs BR930978 New Moog stabilizer links K80946 & 948 New MOOG K80819 Suspension Stabilizer Bar Bushing 28mm New Dorman rear wheel bearings using complete axles 926-139 & 140 New Radiator support bushings Dorman 924-267 (front body mounts)
    Might not be the belt. Did you check the 3 idlers and the tensioner pulleys when you did the alternator? If not my bet is on at least the tensioner bad and maybe 1-3 of the idlers going by 150k. I put a new tensioner assembly on as it was getting weaker and belt slipped on full throttle and flat pulley was getting grooved and bearing grating some. All three idler bearing were slightly worn but compared to new ones felt rough when spinning. After changing all it was very quiet up there.
  18. Sep 30, 2021 at 1:55 PM
    #78
    DanerZone
    DanerZone Active Member
    Dane
    Dana Point, CA
    2006 Toyota Tacoma Prerunner SR5
    Camper Shell / Custom Lighting in bed & Shell / Bigger offset Rims 17x9 / A/T Tires BF Goodrich K02 265/70/r17.
    Thank you for all the Info! So grateful for this page! My 2006 Tacoma starting making a high pitch / grinding noise. I suspected the alternator after reading this section. Sure enough, the battery light came on this morning. I knew immediately that it was the alternator! Picked up a new one at my local Toyota dealership for $326. Installed in less than 2 hours. Thanks again everyone!
  19. Oct 1, 2021 at 6:28 PM
    #79
    07tacoark
    07tacoark Still kickin like a chicken!
    Red
    Fort Worth, TX
    07 4x4 SR5 & 19 TRD-OR 4x4
    Lots on 07 ... getting started on 19
    Is it me or did I get sabotaged?? I used some pointers from this thread & replaced the alternator, hooked everything back up & worked.
    I replaced the tensioner pulley while I was down there, broke the tensioner's hole where you insert a bit/screwdriver/etc but replaced it was. Afterwards there was NO MORE SQUEALING!
    Fast forward a few days, I went to the Toyota dealership to get diagnostics on my radiator cooling system & they found nothing wrong. I get in my truck, still at normal temp, head home with no noises. The next day I went to start it, my God at the squealing it ain't ever done before like that.
    I went to lunch meeting today & when I started it up to head there the squealing was even worse. I sounded like those people we all stop & stare at... It was that bad!! I know damn well I fixed what was needed w/ no noises.
    So ... Anyone else have the noise come back 300% worse after what all I had to do??
  20. Oct 1, 2021 at 7:38 PM
    #80
    BenMara
    BenMara That Asian RedNeck
    Ben
    Belton, SC
    2011 DC 4x4 SCed
    TRD Blower, Ham Radio, DBA T2 Rotors
