How to change the color of your stock radio by "slvrAZtaco"
Discussion in '2nd Gen. Tacomas (2005-2015)' started by toku58, Jun 16, 2009.
  1. Jun 16, 2009 at 9:56 PM
    toku58
    toku58 [OP] Well-Known Member
    On a Rock in the middle of the Pacific
    Mall Crawler!
    21' TRD OffRoad 2" 887 OME on Bilstein 5100's. 285/70R17 General Grabbers G3 17x8.5" Icon TRD wheels (Gun metal gray) 4.75" BS
    Ok, here is my write up on how to change the color of your OEM stereo.
    Tools needed:
    Small sized screwdriver
    10mm Socket setup
    Soldering Iron
    Solder sucker
    Solder
    Needle nose pliers or tweezers
    And of course... new LEDs.
    The LEDs I used are a little bit smaller then the OEM LEDs. I used UT-672 LEDs 470nm wavelength. You will need 30 LEDs for the directions below; I would recommend ordering a few extra. If you want to replace the lights near the CD slot or the LCD backlighting then you will need to order more.
    ***If you do not know how to solder or properly remove soldered components do not attempt this, serious damage could occur. I am not responsible for any damage, you are taking the fate of your stereo into your own hands.***
    First you need to remove the stereo, to do this you must remove the climate controls. Insert your small screwdriver under the climate control and pry the lower part outward. Once the lower clips pop, grab the entire unit and carefully pull it straight out (toward you). Once the climate control is out you will see 4 bolts, these bolts are holding the stereo bracket. Remove these 4 bolts using the socket setup, then grab the stereo and pull it straight out (toward you). Once you have the stereo loose there are 4 wires that need to be removed, 3 to the stereo and one for the clock/hazard multiswitch.
    Here is the stereo once it is out. Rotate the face of the stereo away from you and remove the two screws on the top cover, and the four screws; two on each side, and the three on the bottom.
    Once the screws are removed, carefully pry the top cover up. You do not have to remove it from the face.
    Next move the stereo so the face is facing up. Remove the volume and station knobs by pulling them straight away.
    Once the knobs are removed you can start to "pry" the face away from the stereo. There are two large clips on the sides and numerous plastic clips along the top and bottom.
    When you have all the clips released then you can pull the face away from the unit. There are two electrical connections that will cause some resistance. Also watch the top plate that was released earlier, ensure that it does not drop back down.
    Here you can see the two electrical connections
    Now set the unit aside and place the face, face down. You will see 9 or 10 screws, remove all of these screws and set them aside.
    After you remove the screws you can the pull the PC board away from the face.
    You can then locate all the LEDs on the board, they are placed near each button and there are 4 surrounding the volume and station knobs. The LEDs for the LCD screen are under the LCD screen. In order to change these LEDs the entire LCD must be removed. These instructions do not cover the LCD color change.
    If the picture is clear enough, you should see the "blue" end of the LED. This is the Cathode side of the LED. All the LEDs are oriented in the same direction, all cathodes are to the right or up depending on where the LED is mounted. There are two LED's that are not the same as all the rest. These can be found on either side of the CD slot. You can probably replace these LEDs as well, but once again I did not feel the need to. They are not normally lit, and only light (green) when you are loading or unloading a CD.
    Use your soldering skills to remove the LEDs and solder in the new ones. Fortunately none of the LEDs are glued to the PC board and most can be salvaged, if for some reason you want to keep them. My method is to remove all the solder from both the anode and cathode sides, using the solder sucker. Then using my tweezers I gently pull up on the LED while heating both sides.
    Once the LEDs are removed I will then tin each pad and solder in the new LEDs.
    Ensure that you have the polarity correct!!! If you have a Digital Multimeter that has a diode test function then you can place the negative probe on the cathode and positive probe on the anode and the LED should still light. Test each LED to ensure that you have not burned any, and that you do not have any cold solder joints.
    If you have verified that all your LEDs work then you can reassemble the stereo. Just reverse the directions above.
  2. Jun 16, 2009 at 10:10 PM
    jdkeller
    jdkeller How many words can be fit in this s
    Jonathan
    Inland Empire, Ca
    2008 Tacoma Prerunner TRD Offroad
    Dome light LED, 6000k HID Headlights and fogs, Grillcraft black mesh, rear 5100's, Total Chaos UCA's, 285/75/16 BFG KM2's, Spidertrax spacers, Blacked out emblems, cb,kenwood tm270 ham radio, All Pro 3" leaf pack, Fox 2.0 coilovers, Revenge Fab Sliders, u bolt flip kit, Pioneer avh4200, bed bar with light and antenna, Wet Okoles, Weathertech Mats, Wet Okole Armrests, Rear KR Fab bumper, bed mat, N-Fab spare tire carrier with full size spare on 16" TRD rim, Bedlinered flares and grille. Camburg Spindles, All Pro front fenders.
    Nice Writeup!
  3. Jun 16, 2009 at 10:32 PM
    DDD
    DDD Shine bright like a hymen
    Derek
    Santa Clarita, CA
    Why didn't you change the color of the display?
    How did you change the color of the clock?
  4. Jun 16, 2009 at 11:13 PM
    toku58
    Mall Crawler!
    That's not my radio. Here is my radio:
    Mine is white:
    The clock? You need to strip the tint on the inside of the clock lens. Not very easy.
  5. Jun 17, 2009 at 2:30 AM
    S7ICKlVlAN
    S7ICKlVlAN Cpt. Bubbleguts
    Dave
    Hawaii
    2012 TRD Sport DCSB
    TRD badged | Hunting Cage | Smoked Tails | LED Everything | Slim Cubby HID bi-xenon's | Spidertrax 1.25" | BHLM | FLM | S2000 Ant | 20% Shade | PL 8521 | OME 885 | Bilstein 5100's | Toytec 2" AAL | FN 18x9" Bronze BFD's | 275/65-18 Duratrac's | Wrinkle Red Valve Covers | 3M Di-Noc Wrapped Interior | Kode MB Push Button Ignition | Relentless Sliders | URD TCAI | Mr.Marv Enclosure | Arc Audio 10" | Hybrid Audio Clarus F/R | Alpine PDX-5 | Alpine INE-S920HD
    Nice job Toku. I gotta see your truck in person sometime.....
  6. Jun 17, 2009 at 2:33 AM
    AFButters
    AFButters Rigger, Please!!
    "Butters"
    Albuquerque, NM
    2008 335xi BMW
    We need to have a First Annual Tacoma World "How-to Solder" Class.. we could do it in o I dont know.. Sanford, NC.. yea that sounds great
  7. Jun 17, 2009 at 3:46 AM
    brian
    brian Another Traitor
    Elizabeth City, NC
    2017 F-250 Powerstroke
    Come to the Cape, I'll teach ya :) Just soldered up a few things yesterday to brush up on my skills.
  8. Jun 17, 2009 at 11:48 AM
    A.D.
    A.D. Desert Riding Ninja
    SoC♠l 4 life but stationed in Utah
    Low and Slow Mini
    Nice write up!!
  9. Jun 17, 2009 at 2:27 PM
    Good351
    Good351 Well-Known Member
    Ames, IA
    03 4Runner V8
    Remember not to get those LED's too hot. They don't like heat! Do your solders quick.
  10. Aug 7, 2009 at 11:44 PM
    redraider
    redraider Well-Known Member
    Eric
    San Antonio,TX
  11. Aug 8, 2009 at 12:50 AM
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    BSP '10 4x4 TRD Off-Road DC
    See build thread in signature
    Very nice writeup! Now if only I had the balls to do it...
  12. Aug 8, 2009 at 7:50 AM
    Hootbro
    Hootbro Omnipotent
    Delaware
    2019 SR/SX Tacoma Access Cab 4x4 3.5L
    Just did mine and also the instrument cluster. Just need a fine tip soldering iron and a steady hand. Also, a cheap pair of 2X reading classes help.
  13. Aug 8, 2009 at 8:59 AM
    HwyRogue
    HwyRogue Resident Canuck
    Halifax, Canada
    2007 TRD Sport 4x4
    Arctic bull bar, hitch step, side bars (All by Avid Off Road!), BHLM, eye lids....
    Brilliant write up - looks easy enough to do, but I know very well that looks can be quite deceiving :D How did you change the color of the radio display?
  14. Aug 8, 2009 at 9:11 AM
    Killer Red Taco
    Killer Red Taco NorCal Rock Whore
    Whatsurname
    BFE–Norcal
    007 Tacoma A/C TRD O/R Impulse Red 4x4
    Bilstein 5100 on front at 1.75 setting • 5100 on back• K&N Air Filter• TRD Seat Covers• Day Time Running Lights• Foglights Anytime• Hella 500 lights in grille• Rear TSB Springs• Alternative Locker Mod• CB and 4 ft firestick II• Billet Grille• Kid puke in the back!• 265/75R16 Goodyear MT/R• 16" Devino wheels• Hose Clamp Mod• Revenge Fab Sliders• No Sway Bar• A Hottie as Copilot
    Some great tech! I wish I had bigger balls to tear apart my dash, i am to scarrrd.
  15. Aug 31, 2010 at 4:08 PM
    06aztaco
    06aztaco Screw you guys, I'm going home.
    Cole
    Phx AZ
    06 Prerunner 2.7
    toku.. I know a guy from TN did this writeup but I see you did it too. did you use 0805 or 1206 LED's? Do you have a link to the site you bought them from?
  16. Aug 31, 2010 at 6:37 PM
    yosh2000
    yosh2000 Well-Known Member
    CO
    '17 Tundra CM 5.7
    ^ i always use the PLCC-2 LEDs from oznium. yea, they are a little bigger, but they will fit, plus they are only 0.50 each!
  17. Aug 31, 2010 at 6:41 PM
    1BlkT
    1BlkT Mod'n on a Budget
    Ty
    90603
    2006 Black Sport Double Cab
    Allied 4'' Spindles, Sway A Way 2.5 Coilovers, Donahoe Remote Reservoir Shocks w/ Deaver 11Pack Leafs, Goodyear Duratrac 285's, Pro Comp Series 8128, Recessed Grill w/Hella 500's behind, Tint, Black TRD Skid Plate, Debadged, Tailgate Hose Clamp, Weathertech Mats, Aero Turbine 2525XL Exhaust, Volant Intake, RETRO'D Headlights by Yosh2000
    Yosh I know you have a service for the gauge cluster but have you done any stereos? I'm sorta like the white one in post 4 and then maybe get the gauges all back lit with white as well.
    Edit it looks like you do. Time for me to go read through your thread
  18. Aug 31, 2010 at 6:43 PM
    yosh2000
    CO
    '17 Tundra CM 5.7
    ^ yes sir, i've done a handful of them! i actually have a few that im trying to sell right now...they look pretty darn sweet modded....just like the clusters!
    you will need over 50 LEDs for them, but email and tell you more about the stereos...
