How to change the front Diff Oil?
Discussion in '1st Gen. Tacomas (1995-2004)' started by tacoma-man, Jul 22, 2009.
  1. Jul 22, 2009 at 3:17 PM
    tacoma-man
    tacoma-man [OP] New Member
  2. Jul 22, 2009 at 5:46 PM
    senna
    senna Well-Known Member
    San Jose CA.
    09 DBL CAB TRD-OR OME shocks 885 and AAL
    Assuming the steering rack is behind the front axle center line, that puts the drain plug on the drivers side close to being inline with the axle center line and the filler plug just above that.
    Welcome to TW ;)
  3. Jul 22, 2009 at 5:49 PM
    TengoTaco
    TengoTaco Newb
    La Quinta, CA
    2020 OR 4x4 Manual
    8112, SPC, Elka 2.0 rear and Icon AAL. About 1.5”
    Once you take off the skid plate its fairly easy to see. It has 3 shafts going into it. (I know what i set that up for...)
    The drain and fill both need a hex key. I forgot the size.
    You should take the fill, (top) one off first then get the bottom.
  4. Jul 22, 2009 at 5:54 PM
    stucksucksnayota
    stucksucksnayota Well-Known Member
    Barry
    Fort Smith, Arkansas
    14 Taco 4x4 TRD Sport DCSB
    OEM roof rack, Shorty antenna (eBay), soft tonneau cover, K&N drop in air filter, bed mat, interior LED lights, 5100's, MT tires to come soon!!!
    Ya just pull the skid plate off then unscrew the top plug and then the bottom let it drain out completely. The put the bottom plug in and fill from the top plug until the oil starts to come out of the top hole then put the top plug back in.
    Replace skid plates and your good to go!!
  5. Jul 22, 2009 at 6:13 PM
    Krp2nite
    Krp2nite Well-Known Member
    same procedure as the rear......but it does take a different tool......I used a big torx bit but don't remember what the size was.
  6. Jul 22, 2009 at 8:00 PM
    ETaco23
    ETaco23 Marshall offroad Fabrication
    Evan
    PNW
    13' Pyrite Mica TRD Offroad DCSB 4x4
    Color Match Grille, Bed mat, Kings with JBA UCA's, Dakars and 34" BFG KM3, Snugtop Canopy, and my "Marshall Fabrication" Rock Sliders.
    I still gotta do mine! I might have to pick up a hex key for it.
  7. Jul 22, 2009 at 8:12 PM
    wolfgang123
    wolfgang123 Well-Known Member
    Skyler
    Charlotte, NC
    1997 TACOMA - 4x4
    its a 10mm hex the fill plug, but the drain plug is atleast a 13mm on mine atleast. is it like that for anyone else? cause i cant find a 13mm hex to save my life.
