How to check/adjust valve clearance on 3.4L 5VZ-FE?
Discussion in '1st Gen. Tacomas (1995-2004)' started by ThunderOne, Feb 12, 2018.
  1. Feb 12, 2018 at 9:09 PM
    ThunderOne
    ThunderOne [OP] Well-Known Member
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    I have never done this before but I will be replacing valve cover gaskets soon and maybe even the injectors.
    I was wondering if there are some videos or write ups on how to do a valve check and shimming, while I'm in there.
    Thanks!
    Please keep this thread on the topic of 3.4L engines please.
    tony2018 likes this.
  2. Feb 13, 2018 at 5:24 AM
    tony2018
    tony2018 Well-Known Member
    Same, I think mine are overdue but because I don't drive it much it wasn't priority.
  3. Feb 13, 2018 at 5:29 AM
    Clearwater Bill
    Billy
    Largo Florida
  4. Feb 13, 2018 at 5:45 AM
    tony2018
    CRAP, I gotta remove the timing belt. uugh...
    And I also gotta buy shims? uugh..
    Tundra2 likes this.
  5. Feb 13, 2018 at 6:20 AM
    old grouch
    old grouch Well-Known Member
    Stan
    Colorado Springs, CO
    95 4x4 V6 Extra Cab
    E-Locker SS Skid 2" Lift
    I had a shop tell me a couple weeks ago they are not adjustable, so you guys clearly have nothing to worry about. :rofl:
  6. Feb 13, 2018 at 6:36 AM
    tony2018
    But wouldn't the shims wear out over time? I know the motor oil will lubricate it to keep the cams from making direct contact.
  7. Feb 13, 2018 at 7:55 AM
    mwrohde
    mwrohde Well-Known Member
    Sugar Hill, GA
    2003 Tacoma 4x4 5-speed 3.4 TRD SR5
    That really seems like a hell of a job. I don't feel like I'd do it right, I don't want to pay for it, and I don't want to bury my head in the sand. Unsure how to proceed. Wish I didn't know.
  8. Feb 13, 2018 at 8:48 AM
    ThunderOne
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
  9. Feb 13, 2018 at 8:54 AM
    ThunderOne
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    Where does it say the TB needs to be removed? Just skimmed the write-up.. forgive me if I missed it
  10. Feb 13, 2018 at 8:55 AM
    mwrohde
    Sugar Hill, GA
  11. Feb 13, 2018 at 8:59 AM
    tony2018
    The cams have to be removed in order to get to the shims. should be a set for the intake and the exhaust. right?
  12. Feb 13, 2018 at 9:07 AM
    cory02taco
    cory02taco Well-Known Member
    Cory
    Maine
    2013 trd super sport
    This is one where unless you REALLY know what you're doing, you're better off paying someone. Especially if you're squeamish about pulling the cams.
  13. Feb 13, 2018 at 10:36 AM
    ThunderOne
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    Hmm, well if I'm gonna be doing the VC gaskets, how many more steps is it to remove the camshafts? Can I measure the clearances without doing this?
  14. Feb 13, 2018 at 10:38 AM
    tony2018
    You have to mark the cams, unbolt cam caps, remove cam caps, remove cam, remove shims one by one, measure shims to ensure proper spec, if not within spec you replace with the proper one.
  15. Feb 13, 2018 at 10:43 AM
    ThunderOne
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    someone in this thread said you don't need to remove the camshafts.. From another source.. again no mention of removing the camshafts:
    "Then you can remove the covers. Once you have access to the valvetrain, you need to begin measurement of the valve clearances. INTAKE: (.006-.009"), EXHAUST: (.011-.014"). Use feeler gauges to measure the clearances between the cam lobe and the valve shim ONLY when the lobe is 'pointing' upward. Document all changes that need to be made on each valve, and label accordingly."
  16. Feb 13, 2018 at 10:57 AM
    cory02taco
    Cory
    Maine
    This is incorrect based off every shim/bucket valve train I've ever worked on. Clearance is checked with the cylinder at top dead center, then you measure the clearance, and move along. Cams only need to be removed if you have to change the shims.
  17. Feb 13, 2018 at 10:57 AM
    tony2018
    Thats interesting, scratching head atm. Not sure how thats done with the cam still in place.
  18. Feb 13, 2018 at 10:58 AM
    tony2018
    OH, this was the removal process i followed from one of the links. Just skimmed down, not mine.
  19. Feb 13, 2018 at 10:59 AM
    cory02taco
    Cory
    Maine
    You put a feeler gauge in between the cam lobe and bucket. It can ONLY be done with the cam in place. You're measuring the clearance between the cam and bucket, not the thickness of the shim.
  20. Feb 13, 2018 at 11:05 AM
    tony2018
    yes measuring clearance with the cam inside, my comments were all about how to adjusting. 2 links in this thread, one shows that op remove the cams, another states you don't have to remove the cams.
