How to check "Check Engine" light
Discussion in '1st Gen. Tacomas (1995-2004)' started by StAndrew, Jul 2, 2010.
  1. Jul 2, 2010 at 1:09 PM
    StAndrew
    StAndrew [OP] Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
    The Check Engine light came on yesterday. I figured it was the MAF since thats ussually the easy answer. When I pulled it out, one side was coated in a black layer of gunk (dry). Probably from the K&N box filter. I just did the deck plate mod on top.
    I cleaned the MAF but the light is still on. Anyone know how to check the code? Thanks!
  2. Jul 2, 2010 at 1:15 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    go to autozone and get them to read it on their scan tool...then let us know what the code is.
  3. Jul 2, 2010 at 5:50 PM
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    Thanks. It was the MAF. I disconnected the battery to reset the light. Is there and easier way to do this?
  4. Jul 2, 2010 at 5:52 PM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    probably the only way,without a scanner
  5. Jul 2, 2010 at 7:51 PM
    Offroadfreak121
    Offroadfreak121 New Member
    Brian
    Dubuque
    96 Tacoma 4x4
    Monroe off-road shocks, New leafs,Echlin IAC, K&N intake/filter, Snow Plow,JVC USB receiver
    If you own a Tacoma, a $50 scanner from Harbor Freight is a worthwhile investment.
  6. Jul 3, 2010 at 12:44 AM
    Manlaan
    Manlaan Well-Known Member
    Greg
    Riverton, Utah
    2002 XtraCab SR5 V6 4x4 Black
    See Signature
    Scangauge II :)
    A lot more useful than a normal scanner and will read/reset codes, as well as show you all sorts of other things.
