How to check the level and condition of my 2013 Takoma TDR?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ivokunc, Oct 16, 2022.
  1. Oct 16, 2022 at 6:30 AM
    ivokunc
    ivokunc [OP] Active Member
    2013 Tacoma TRD
    Hi guys! It looks like my Tacoma has a sealed automatic transmission - no deep stick. How can I check the level and condition of this fluid? It already has 136000ml and running great.
    Thanks!
  2. Oct 16, 2022 at 6:32 AM
    pahaf
    pahaf Well-Known Member
    paul
    NorCal
    2015 Tacoma TRD Off Road
    Bilstein 6112/5160 OME Meduim leaf pack JBA HD UCA 3* retard exhaust gear TRD Pro Sema rims 265/70R17 Falken Wildpeak AT3W
  3. Oct 16, 2022 at 7:01 AM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    ^^^This, or you need a scan tool to read trans temp. Fluid temp must be 97-115F and engine running in park when checking.
    Note the temp of 115-130F in the original thread is wrong, it was revised in 08 to 97-115F (see attached TSB).
    TOMB, wi_taco, NORCAL50 and 1 other person like this.
  4. Oct 16, 2022 at 9:02 AM
    ivokunc
    2013 Tacoma TRD
    Thanks! Is it a special scan tool or it is a regular test-scaner that can be purchased on (let say) eBay? Thea are few scan tool there for about $100 or so...
  5. Oct 16, 2022 at 9:13 AM
    NORCAL50
    NORCAL50 Active Member
    2014 Toyota Tacoma SR5 V6 4x4
    Any scan tool that can read ECM (Engine Control Module) & TCM (Transmission Control Module) that has live data functionality (sometimes referred to as Mode 6 I think?) should be able to read A/t oil temperature.
    I use the Autel MD806 Pro ($230) but there are many others that can be had for much cheaper that can do the same thing.
    If you get the Autel, the ATF fluid temp is found in Scan > Asian > Toyota > Manual Selection > USA > Tacoma > Select Your Vehicles Year From The List > Select Your Vehicles Model Code From The List Found On Door Placard > Diagnosis > Control Unit > Engine and ect (yes, it's spelled ect) > Live Data > Custom List > (Select Both) A/t oil temperature 1 & 2
    *Note: The higher of the two temperatures is the sensor located in or near the torque converter. The other is the temp of the oil in the pan. Use the temperature of the oil in the pan to get your reading.*
  6. Oct 16, 2022 at 1:29 PM
    ivokunc
    2013 Tacoma TRD
    Thanks, norcal50! I think I'll buy one Autel new(or used) with Owner Manual book
    NORCAL50 likes this.
  7. Oct 17, 2022 at 9:06 AM
    10thMTNgrunt
    10thMTNgrunt This is the way, step inside.
    2013 TRD Sport
    Good info, about to purchase scan gauge II for the same purpose, do you know if the trans temp reading it relays is that of the trans oil pan or of the torque converter?
  8. Oct 17, 2022 at 9:20 AM
    NORCAL50
    Please see the note at the very bottom of my last post. There's two sensors (at least for the A750F transmission that comes in the 4.0 4x4) and thus you should see both sensors in the scanner.
  9. Oct 17, 2022 at 12:34 PM
    10thMTNgrunt
    2013 TRD Sport
    Ahhh thanks!
    NORCAL50[QUOTED] likes this.
  10. Oct 17, 2022 at 2:13 PM
    Ricardo13x
    Ricardo13x YT: @UrbanOpsOffRoad IG: @urban.ops.offroad
    Upland, CA.
    05 OR DCSB ProRunner(4x4 conv.), Chevy 63”s, NWF EcoCrawler, 35”s
    Random stuff. Oh! and converted to non ADD 4x4.
    Friday yet?
    SR-71A and GoldenBrew like this.
  11. Dec 14, 2022 at 11:23 AM
    ivokunc
    2013 Tacoma TRD
    Hey, norcal50 I got a new AUTEL 806PRO and just measured AT temperature. The digits are:
    AT temperature 1 158.08
    AT temperature 2 161.24
    So obviously high readings... I think I need to do the Transmission Oil change. Here at St. Pete, FL we have a Toyota dealership and these guys have machine(vacuum pump) for this procedure. I read some posts online that say to stay hands-off from this action.
    Do you have any experience with this?
    Thanks for any answer!
  12. Dec 14, 2022 at 11:30 AM
    Clearwater Bill
    Billy
    Largo Florida
    Those are not high readings.
    NORCAL50, cryptolime and SR-71A like this.
  13. Dec 14, 2022 at 11:32 AM
    GoldenBrew
    GoldenBrew Insufficient Privilege
    Golden, Colorado
    Gen3 4X4 TRD OR AT - SOLD not Forgotten
    Everyday has the proven potential to be Friday! So true.
    Ricardo13x[QUOTED] likes this.
  14. Dec 14, 2022 at 12:20 PM
    ivokunc
    2013 Tacoma TRD
    But the normal, good Fluid temp must be 97-115F, right??
    So, 158 is not a high temperature in the oil pan?
  15. Dec 14, 2022 at 12:22 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    That's the temperature to check the fluid level, operating temp is higher (typically ~160-200)
    Hook78 and cryptolime like this.
  16. Dec 14, 2022 at 12:24 PM
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    Re-read the procedure in post #2 above. You must check the ATF level under certain conditions including having the engine running and being at the proper ATF temp.
    Honestly, if you are not having any issues with the truck and not seeing any evidence of leaks, I would not worry about it. Its not a hard procedure per say, but you can makes things worse if done wrong.
  17. Dec 14, 2022 at 12:25 PM
    ivokunc
    2013 Tacoma TRD
    Oh, I can see... So, is that mean the transmission fluid level is low?
  18. Dec 14, 2022 at 12:28 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    You have to get the temp to 97-115, pull the check plug, and see if fluid runs out, if it doesn't it's low.
    Did you read the fluid check procedure I posted above?
    cryptolime and Clearwater Bill like this.
  19. Dec 14, 2022 at 12:32 PM
    ivokunc
    2013 Tacoma TRD
    I did the measuring just after I drove the truck for about 30 min on the road.
  20. Dec 14, 2022 at 12:44 PM
    SR-71A
    Zack
    Southern Maine
    Im guessing no..
    NORCAL50 and Clearwater Bill like this.
