How to check the starter if its GOOD ???
Discussion in 'General Automotive' started by Mr.Tacoma, Apr 20, 2011.
  1. Apr 20, 2011 at 7:05 PM
    Mr.Tacoma
    Mr.Tacoma [OP] Well-Known Member
    toronto
    DoubleCab4x4
    TRD Exhaust, Side step bar & ARE cap
    Hey folks, I pulled the starter out of my 97 camry as it only clicks and dont start (even jump starting) is there a way to test it with a meter..??
    Before i check the Neutral/Drive shift switch i would like to be sure of the starter.
  2. Apr 20, 2011 at 7:06 PM
    rex99
    rex99 Well-Known Member
    TArdCOMAWORLD
    Proton Cruiser
    Rocket Boosters, Flux Capacitor, Escape Pod, Throttle Body Spacer, Homeroshi, ATRAC disable
    Doesn't Autozone check them for free??
  3. Apr 20, 2011 at 7:06 PM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    Most auto parts stores will test it for free
  4. Apr 20, 2011 at 7:07 PM
    Detective_Dan
    Detective_Dan "Place original and witty user title here"
    Colorado Springs
    2014 DCSB Beast / 2016 Yamaha FZ-07
    Pelfreybilt Front Plate Bumper, Brute Force Fab High Clearance Rear Bumper, Pelfreybilt Sliders, OME 886/Dakars, SCS F5's, 33" Ko2's, Cobra 75WXST/3' Firestik, oil catch can, aero turbine 2525, rear differential breather extension, bedmat, weathertech digital fit front/rear, BHLM, custom shiftknob (made by me),
    ya they do, im not positive on this (in fact im probably wrong) but i think it has to be in the vehicle for them to check it
  5. Apr 20, 2011 at 7:08 PM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    No, the have a test bench to test it on. They require it be removed from the vehicle
  6. Apr 20, 2011 at 7:14 PM
    Detective_Dan
    Colorado Springs
    ok. well, like i said above, im probably wrong :D
  7. Apr 21, 2011 at 12:41 AM
    shampoop
    shampoop Well-Known Member
    southwest WA
    08 tacoma extracab v6 auto trd offroad 4x4
    Jump it! The clicking is just the solenoid. If you understand basic electric principles and can read the diagram for it, it becomes pretty self evident how you would test any part of it.
    That kind of knowledge is a lifelong tool you will probably use often. Worth learning.
  8. Apr 21, 2011 at 11:18 AM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    To test the starter: Put the starter in a vise, Positive goes on the side lug(on the starter, not the solenoid), tap the negative on the side of the bolt flange.
    The solenoid is probably junk from hard starting and jump starting. Low voltage/poor connections/bad wires cause the starter to draw more amps. This wears out the solenoid and starter. Get it rebuilt.
    Check for corroded/frayed/poorly connected cables, and have the battery CAPACITIVELY tested. Load tests work for shit; capacitive tests the total health of the battery. Odds are it's bad, just judging from the starter problem. If the battery is more than 4 years old, or has been completely discharged more than three times, replace it.
