How to: Checking/changing transmission fluid
Discussion in '1st Gen. Tacomas (1995-2004)' started by Coldspire, Apr 25, 2010.
  1. Apr 25, 2010 at 7:32 PM
    Coldspire
    Coldspire [OP] Well-Known Member
    B-Rad
    AB, Canada
    2001 Xtra Cab, 2.7L 4cyl. Manual
    Grill guard, Helo rims on Wrangler 245/75 R16s, Altezza taillights, Kenwood DVD Player
    Hello TW, I would like to know how exactly one would go about checking the level of and changing the transmission fluid in a first gen manual trans. Also, when refilling do I just put back into the tranny exactly as much as I took out?
    Thanks in advance to any advice :)
  2. Apr 25, 2010 at 7:53 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    In the diagram in this link you will see the drain plug, and fill plug. Remove the fill plug first, then the drain plug. Let it dran out, then refill with your favorite gear oil of 75-90 or 80-90 (GL-4 or GL-5), 2.3 quarts. 2.7 if your not a 4x4.
  3. Apr 26, 2010 at 6:24 AM
    asphaltpilot
    asphaltpilot CAPS CAPS CAPS!
    South Florida
    PreRunner SR5
    ^ You're correct about the capacity, because that's what my manual says also. However...
    I drained my trans fluid this weekend. I turn the truck on and let it run for 5 minutes. I turn it off, get under the truck, and unscrew the drain plug. Just over 4 quarts of fluid drain out. Yes, 4 quarts. WTF? I thought that was it, but then I drop the trans fluid pan because I'm replacing the filter and pan gasket as well. When I drop the pan and the filter, I drain out another quart and a half. So I end up draining out about 5.5 quarts. I'm very confused at this point. The Toyota dealership was closed so I call AutoZone and have them look at all the transmission capacities listed for my year Taco. They say the same, 2.3, 2.5, 2.7. FFS.
    I'm thinking that maybe it was overfilled, but if it was overfilled that much something would have ruptured or blown by this point. I refill the trans with 5 quarts. I drive the truck around for the 10 minutes, come home, put it in park but don't turn the engine off. the level on the dip stick read "cold." So I added another .5 quarts. Now it's in-between "cold" and "hot." I leave at that for now as I'm very apprehensive to add more. It's been two days the truck runs fine. *shrug*:confused:
  4. Apr 26, 2010 at 6:30 AM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    :rofl:
    I think you drained the tranny completely.
  5. Apr 26, 2010 at 7:10 AM
    asphaltpilot
    South Florida
    PreRunner SR5
    That's what I'm thinking too but I didn't think that could happen without a flush.
    Even in the manual it says "drain and fill - 2.5 qts." Well, the drain alone was still just over 4 quarts. :confused:
  6. Apr 26, 2010 at 7:31 AM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    If you just remove the pan, you should get the 2.5 qts, IIRC.
  7. Apr 26, 2010 at 6:06 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    No "Pan" on the manual tranny.
  8. Apr 26, 2010 at 6:35 PM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    Asphalt has an auto..............:p
  9. Apr 26, 2010 at 6:37 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    :anonymous:
  10. Apr 26, 2010 at 9:05 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 Auto Trans With Lots of Mods King Extended Travel COs Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Alcan Custom 8-Leaf Rear Spring Packs Fox 2.0 Resi Rear Shocks FrankenFab Rear Shock Relocate All-Pro U-bolt Flip w/Timbren bumps Toytec 1" Extended Shackle 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Gunmetal 16x8 SCS Ray10s 285/75r16 Cooper STT Pros Limited Edition Relentless Front Bumper Smittybilt X2O 10K Winch 3" LED Pods w/Amber covers in the Bumper 22" Single Row LED Bar on the Bumper Mini D2S Projectors XB35 Ballasts + 4500K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Whynter 65 qt. Fridge/Freezer CVT Mt Bachelor RTT Badland Custom Bed Rack GM 140 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Magnaflow 18" Muffler 13WL Brake Calipers Braided Steel Brake Lines AFE Pro Dry S air filter ScanGauge II OBDII Scanner Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    Its OK you know. :p I figured you were being sarcastic when they were talking auto stuff. The OP that you responded to was referring to a manual trans in his 1st gen. :eek:
  11. Apr 27, 2010 at 6:44 AM
    MK ULTRA
    MK ULTRA Well-Known Member
    JIM
    Huntsville Ala
    4X4
    I wondered when someone was going to figure this out.....
    LOL
    have a nice day.
