How to: Chevy 63" Leaf Spring Swap
Discussion in 'Suspension' started by dakotasyota, Jun 13, 2015.
  1. Mar 18, 2019 at 5:09 PM
    #561
    Casper66
    Casper66 grumpy ass
    Culpeper, Va.
    '15 DCSB TRD Sport 4wd super white (sold) '13 access cab SR5 4wd
    piddly stuff
    Dude I'm not the brain in this fandango I'm just there to look pretty, cook ribs, and melt steel
    ovrlndkull likes this.
  2. Mar 18, 2019 at 5:10 PM
    #562
    SearArtist
    SearArtist GX poor
    NC
    GX470 & GX460
    Things
    Fair enough. :thumbsup:
  3. Mar 18, 2019 at 5:11 PM
    #563
    ovrlndkull
    ovrlndkull STUKASFK - HC4LIFE
    Skip
    Burlington, NC
    2005 DCLB Silver
    63s, XD Machete, Beat not Babied
    I've been coaching him. He's good. Just getting some more in depth reading :rofl:
    Casper66 likes this.
  4. Mar 18, 2019 at 5:54 PM
    #564
    Sociopenguin
    Sociopenguin 2 Fang Engineering
    Tate
    NW MO
    DevilPenguin
    Schtuff
    Got the truck stripped down and ready for install. Also got the leaf springs ready for poly bushings.
    BlakeM likes this.
  5. Mar 18, 2019 at 7:18 PM
    #565
    ovrlndkull
    Skip
    Burlington, NC
    2005 DCLB Silver
    :bananadance:
  6. Mar 18, 2019 at 7:23 PM
    #566
    Sociopenguin
    Tate
    NW MO
    DevilPenguin
    Schtuff
    We are thinkin the +4 lines I already have in the back aren't gonna be long enough...
  7. Mar 18, 2019 at 7:32 PM
    #567
    ovrlndkull
    Skip
    Burlington, NC
    2005 DCLB Silver
    I ended up ordering +9 from Crown just to be on the safe side I already had +6". If you call crown you can order just the rear lines and not have to get the full kit. They were like 70 some or 80 bucks to my door. They will also do whatever length you want and color. All that cost extra is the different lengths. Guy I talked to was really helpful and on point. After talking to them I got the feeling they are a small mom and pop operation that really is focused on customer support and satisfaction.
  8. Mar 18, 2019 at 7:49 PM
    #568
    Sociopenguin
    Tate
    NW MO
    DevilPenguin
    Schtuff
    Badass. I'll ring them in their morning, probably also get a measurement and get a braided line for the air locker as well.
  9. Mar 18, 2019 at 7:50 PM
    #569
    ovrlndkull
    Skip
    Burlington, NC
    2005 DCLB Silver
    They may be able to make that as well just depends on the style of fitting. Oh and the new lines they send new spring retainer clips with that are nice and shiny they look to be stainless steel like their fittings.
  10. Mar 18, 2019 at 8:06 PM
    #570
    HB Taco
    HB Taco Well-Known Member
    Curt
    Huntington Beach, CA
    2019 F150 FX4 S Crew 3.5 TT
    Bad A$$
  11. Mar 18, 2019 at 9:48 PM
    #571
    WormSquirts
    WormSquirts Armageddon
    Braeden
    BC
    Hmm let me know how it goes, I only have +4 as well
  12. Mar 19, 2019 at 6:54 AM
    #572
    Timbo's Customs
    Timbo's Customs Well-Known Member
    Timothy
    Lakeland FL
    2019 f250 6”lift 37s deleted 1997 T4r, tons and 4ds
    1997 t4r has super duty axles, 5.13s locked front and rear. 3 link front with 14" kings. Rear 63s.
    All I have is the allpro extended lines
  13. Mar 19, 2019 at 8:01 AM
    #573
    ferntr33
    ferntr33 Well-Known Member
    Has anyone mounted shocks inside frame rail instead of outside? Would like to keep from using spacers if possible. Not sure if I would just get DMZ frame boxing kit and maybe just mount it inside?
  14. Mar 19, 2019 at 4:27 PM
    #574
    HB Taco
    Curt
    Is this much better than say a Dakar leaf pack which is made for our trucks? Just trying to decide if all the extra work is worth it?
  15. Mar 19, 2019 at 5:08 PM
    #575
    ovrlndkull
    Skip
    Burlington, NC
    2005 DCLB Silver
    I have seen some build threads where guys mounted the shocks in-board angled pretty steep. Research because angling like that there are pros and cons.
    The biggest thing is what you are wanting to do with your truck and get out of the suspension. You can get a lot of flex out of Dakars or other springs with something like the Archive Garage hammer hangers and a shock relocation. This set up allows even more flex.
    Here is a pros and cons list.
    Chevy 63s
    Pros:
    Lots of flex
    Load carrying capability
    Easy to source parts
    Beefier springs
    Cons:
    Can get expensive
    Lots of work/permanent modification to truck
    Not as easy as just swapping parts
    Not for a novice to install
    Requires welding and fabrication
    Dakars or similar
    Pros:
    Easy installation
    Can source parts easily
    Decent flex
    Can do other mods to get more flex
    can go back to stock if need be
    cheaper initially than chevy 63s
    Cons:
    limited in the amount of flex you can get
    Not as beefy of a spring
    needs additional mods to get the most flex
    I am sure there are more that others can add. Hope this helps.
    HB Taco[QUOTED] likes this.
  16. Mar 20, 2019 at 7:29 AM
    #576
    HB Taco
    Curt
    Thank You! But then now what do you do to the front to try to match this? SAS / SAC seems like to only way? If / when I want to take it to the next level I'll certainly consider this. Great thread OP. :thumbsup:
  17. Mar 20, 2019 at 7:38 AM
    #577
    BamaTaco56
    BamaTaco56 Well-Known Member
    Trey
    You won’t be able to “match” the travel of the 63 swap or a Dakar (or equivalent) swap with the IFS front suspension of these trucks. A long travel setup can compliment it but it won’t match it as far as wheel travel goes.
    That being said, unless you really need the travel in the front, you don’t have to “match” the wheel travel front to back. Many people run the 63 swap with long travel or even extend travel setups up front.
  18. Mar 20, 2019 at 12:21 PM
    #578
    ovrlndkull
    Skip
    Burlington, NC
    2005 DCLB Silver
    Like you said SAS or like what @BamaTaco56 a LT set up. Now Marlin Crawler is releasing a pretty wicked LT set up that looks like it'll be better than what's on the market now for rock crawling flexy technical type offroading. This set up just makes the truck that much more capable. There are trade-offs to everything and you just have to figure out what will best suit your needs and style.
  19. Mar 20, 2019 at 1:43 PM
    #579
    WormSquirts
    Braeden
    BC
    Here are my thoughts:
    With LT, you gain a small amount of droop, but LT still doesn't flex thaaat well. LT is only really good for speed. So if you are going to LT, you might as well do the +3.5 because the +2 really isn't that much better. If you are going LT, then a Linked or Spring Under Axle rear set up will be a much better fit for LT than a 63 swap.
    A 63 swap is more for crawling. If you are hardcore into crawling, obviously SAS + 63 swap is the way to go. Marlin has their new "Rock Crawling" LT set up, but I'm guessing for the price, a SAS would be a better value, and much more capable. However, if you are into some pretty decent off road stuff, but want to stick with a "mid travel" IFS front end, then the 63 swap is the perfect way to compensate for the lack of flex in the front.
    For me personally, I would love to SAS, but I also love the way the IFS rides on dirt roads and pavement alike. I use my truck for a lot of longer road trips that a more dedicated crawler would suck for. So for me, the compromise is to 63 swap the rear, and maintain a mid travel front. Sure my truck won't be able to send King Of Hammers stuff, but the Rubicon or trails like that would be totally within the capabilities of my truck, yet still comfortable for driving to and from the trail as well.
    That's my opinion anyway.
    Drburn1718, ovrlndkull and BamaTaco56 like this.
  20. Mar 20, 2019 at 1:50 PM
    #580
    BamaTaco56
    Trey
    You said what I was thinking / trying to say in a much better way.
