How to: Chevy 63" Leaf Spring Swap
Discussion in 'Suspension' started by dakotasyota, Jun 13, 2015.
  1. Sep 18, 2015 at 7:33 PM
    #41
    weldo
    weldo Well-Known Member
    Pittsburgh, pa
    2014 base ac 2.7 5-speed 4x4
    Subbed, got me thinkin...
    Great info man, thanks for sharing!
    dakotasyota[OP] likes this.
  2. Sep 19, 2015 at 6:26 PM
    #42
    weldo
    Pittsburgh, pa
    Is there significant advantage to doing the Chevy springs vs just doing a shackle flip on the Toyota springs, be they dakars, all pros or whatev?
    IIRC I've seen guys running oem length springs with a shackle flip (ato?) and 12" shocks in factory location.
    Regarding shock location, any advantage to moving the mounts on the axle tube? For example, move them 2" up, gain a bit more ground clearance and use a 10" shock instead of 12"?
  3. Sep 19, 2015 at 7:03 PM
    #43
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    Probably the main advantage is with the 63"'s you'll get more travel from the longer spring...
  4. Sep 19, 2015 at 7:11 PM
    #44
    916TacoTruck
    916TacoTruck BallzDeep is how I go
    Inyo mom
    2019 Rapturd
    Former 2013 TRD OR. Sickass edition
    So glad I found this write up. It's awesome. Great job. I picked up the ruff stuff kit today and will slowly piece together all the parts I need.
  5. Sep 19, 2015 at 7:12 PM
    #45
    weldo
    Pittsburgh, pa
    But with the Chevy springs, shock relocation is a must to take advantage of all the travel potential, right? And even more travel is possible if you extend shock mounting into the bed area? Like shock hoops or something?
  6. Sep 19, 2015 at 7:15 PM
    #46
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    I don't think shock relocation is a requirement but moving the hangers certainly is
    EDIT: You'd get full benefit relocating shocks yes
  7. Sep 20, 2015 at 6:20 AM
    #47
    Rattletrap66
    Rattletrap66 (ノಠ益ಠ)ノ彡┻━┻
    Frank
    Tampa, FL ☜(゚ヮ゚☜)
    2014 TRD Off Road DCSB
    ╭∩╮(ಠ۝ಠ)╭∩╮
    Also when you need new springs it will be super cheap compared to after market
  8. Sep 20, 2015 at 6:04 PM
    #48
    dakotasyota
    dakotasyota [OP] Just a Fringe of the Ging in your Minge
    Dakota
    Ellensburg, WA
    06 Access Cab, Manual, V6, 4x4, TRD Off-Road
    Total Chaos +2 LT w/ 2.5 x 8 Kings, 700 lb coils, Chevy 63s, BAMF Shock relocation, 12" King Smoothies, Locker Anytime Mod, 5% Tint All Around, 4xInnovations full skids, Custom Made Rock Sliders, 4xInnovations HC Rear Bumper w/ Tire Carrier, SOS Original Plate 2 Front Bumper, 130 w KC Slimlites, Homertaco Raptor Grill, Bestop Supertop, Smittybilt 9500 lb winch, Flowmaster 40 series, JVC deck w/ 12" Rockford Fosgate T1 in custom box, and lots more!!
    Yes because dakars/all pros are designed to be bolted in and work with the stock inverted shackle. I probably won't do this explanation as much justice as @jberry813 but here goes. Imagine drawing a line between the eyelets on your leaf springs. When you flex your leaf springs will go up and be even with that straight line. That's good. Now flip your shackle and draw a line between them. Now when you flex you will bend past that straight line going negative arch. All pro and dakar leafs are a pretty arched spring (compared to chevy 63s and stock leafs). Going negative arch a lot will kill them quite fast. They're an expensive leaf spring to replace too.
    A 12" shock in a stock location is beyond retarded. You will have no uptravel whatsoever.
    Yes moving up lower mounts 2" is beneficial for clearance, but you must then make up for how much you move up with the upper mount.
    Thanks man :)
    Yes it is. Like I said this is a good deal of work and it's not worth it all to have factory shock travel.
    Yes, more travel is possible by going thru the bed. That is my future plans. I've mentioned before I'm not happy with my 12" shocks. I have to use limit straps to prevent overextension and since I mounted my lower shock mounts even with the axle my uptravel is severely limited. The BAMF kit doesn't go high enough to bump in the factory location when you mount the lowers even with the axle.
  9. Sep 22, 2015 at 3:25 PM
    #49
    GARSHA91
    GARSHA91 YES, that is me on that Facebook group
    Chicago
    2015 TRD Off-Road DCSB
    Just a grocery getter
    great write up. eventually want to do this so making this comment in order to have it for reference and thank you for writing it and giving the links for extra parts. also what did you use to paint and get rust off?
  10. Sep 22, 2015 at 3:36 PM
    #50
    GARSHA91
    Chicago
    also do you think icon shocks would work?
  11. Sep 22, 2015 at 4:40 PM
    #51
    ckeene9
    ckeene9 Well-Known Member
    Chesterfield, VA
    '12 DCSB Supercharged 4x4 TRD Sport
    See Build Thread
    Whatever shock your heart desires will work with the proper dimensions.
  12. Sep 22, 2015 at 4:42 PM
    #52
    GARSHA91
    Chicago
    But I'm not sure if they would be long enough
  13. Sep 22, 2015 at 4:49 PM
    #53
    ckeene9
    Chesterfield, VA
    See Build Thread
    They'll be whatever length that you request them to built/order at.
    If you're asking that the standard Tacoma icon shocks will work, they'll be way too short.
  14. Sep 22, 2015 at 5:04 PM
    #54
    GARSHA91
    Chicago
    Ok so I'd have to specifically ask them to be 12"
  15. Sep 22, 2015 at 5:05 PM
    #55
    GARSHA91
    Chicago
    Also reservoir beneficial? Must? Doesn't matter?
  16. Sep 22, 2015 at 6:06 PM
    #56
    dakotasyota
    Dakota
    Ellensburg, WA
    A lot of grinding to get parts off, and I always use my 1/4" die grinder with 80 or 100 grit sandpaper to get the frame paint off.
    Yes.
    Depends on your usage... Do you go fast? All a resi does is hold more shock oil so the shock can stay cooler. A cooler shock means less fading.
    You may not need it, but they're typically not much more so, why not?
  17. Sep 22, 2015 at 6:27 PM
    #57
    GARSHA91
    Chicago
    Thanks for all your help!
  18. Oct 2, 2015 at 4:40 PM
    #58
    Rattletrap66
    Frank
    Tampa, FL ☜(゚ヮ゚☜)
    ╭∩╮(ಠ۝ಠ)╭∩╮
  19. Oct 2, 2015 at 5:51 PM
    #59
    dakotasyota
    Dakota
    Ellensburg, WA
    Awwww snap!
    Rattletrap66 likes this.
  20. Oct 3, 2015 at 3:53 PM
    #60
    GARSHA91
    Chicago
