How to: Chevy 63" Leaf Spring Swap
Discussion in 'Suspension' started by dakotasyota, Jun 13, 2015.
  1. Mar 25, 2019 at 6:41 PM
    #601
    WormSquirts
    WormSquirts Armageddon
    Braeden
    BC
    Looks awesome!!! Can't wait until I can say mine is done!!
    Do the 14s limit your travel? Is that why you need limit straps?
  2. Mar 25, 2019 at 6:43 PM
    #602
    ovrlndkull
    ovrlndkull STUKASFK - HC4LIFE
    Skip
    Burlington, NC
    2005 DCLB Silver
    63s, XD Machete, Beat not Babied
    I just boxed them in and around them.
  3. Mar 25, 2019 at 6:45 PM
    #603
    ovrlndkull
    Skip
    Burlington, NC
    2005 DCLB Silver
    Not 100% sure on that haven't flexed it all out yet. I will have to see but I want limit straps to protect them. Also they stretch some so kinda act like a bumpstop in droop to slow the rate of drop so that it isn't so harsh.
  4. Apr 8, 2019 at 6:46 AM
    #604
    dakotasyota
    dakotasyota [OP] Just a Fringe of the Ging in your Minge
    Dakota
    Ellensburg, WA
    06 Access Cab, Manual, V6, 4x4, TRD Off-Road
    Total Chaos +2 LT w/ 2.5 x 8 Kings, 700 lb coils, Chevy 63s, BAMF Shock relocation, 12" King Smoothies, Locker Anytime Mod, 5% Tint All Around, 4xInnovations full skids, Custom Made Rock Sliders, 4xInnovations HC Rear Bumper w/ Tire Carrier, SOS Original Plate 2 Front Bumper, 130 w KC Slimlites, Homertaco Raptor Grill, Bestop Supertop, Smittybilt 9500 lb winch, Flowmaster 40 series, JVC deck w/ 12" Rockford Fosgate T1 in custom box, and lots more!!
    Glad to help :cheers:
    Casper66[QUOTED] likes this.
  5. Apr 12, 2019 at 5:48 PM
    #605
    ferntr33
    ferntr33 Well-Known Member
    Has anyone done this in stages? I forget where, but I read you can do this in stages if you don’t have the time to do it all at once. I’m. It sure what Toyota it was done on, but it looked like you could weld on the new front hangers whenever since they are further forward than stock ones. Can you weld on rear hangers and run the shackles with factory springs and factory front hangers?
  6. Apr 12, 2019 at 6:20 PM
    #606
    Timbo's Customs
    Timbo's Customs Well-Known Member
    Timothy
    Lakeland FL
    2019 f250 6”lift 37s deleted 1997 T4r, tons and 4ds
    1997 t4r has super duty axles, 5.13s locked front and rear. 3 link front with 14" kings. Rear 63s.
    :eek:
  7. Apr 13, 2019 at 8:37 AM
    #607
    TS7xTaco
    TS7xTaco Warlock
    Charles
    New Mexico
    16 Super White TRD-OR DCSB
    ARB Locked, Nitro 5.29's, Cooper 315's, 16x8 Methods, Cab mount hacked, Firewall Hammered, OME Suspension, Camburg UCA's, ARB OBA, RCI skids and sliders, WarFab Front Bumper, Home Brew Rear Bumper, Orange Virus Tuned, Dobinson Snorkel, Cobra Comms...
    I'd say it's not advised, just by using someone else's measurements you my end up with an uncentered axle and/or a bad shackle angle. Everything needs to be measured at the time your installing so you end up with everything the way you want it...
    Ariyan, ovrlndkull and Sociopenguin like this.
  8. Jun 2, 2019 at 7:11 PM
    #608
    Btnewman
    Btnewman Benjamin Newman
    Benjamin
    Grand Junction co
    Uh. It's beat to he//. But it's only 1 owner.
    Custom body work/damage ARB rear locker Bumpers Shocks Other parts Tires and Rims Air tank fully plumbed into truck "Golf ball mod"
    Will definitely have to do this! Already have foX 12"ers mounted, so springs will be cake. Hopefully the shock travels in the range with the springs. But if I have to g
    Cut the mounts and move them up or down it won't be terrible20140527_121040~2.jpg 20140527_121031~2.jpg
  9. Jun 6, 2019 at 12:07 AM
    #609
    Taconator_
    Taconator_ IG: ohv_tacotruck
    Eric
    SoCal
    18' DCSB TRD OR 4x4
    Is anyone running archives hammer hangers with these? Actually, now that I think of it is that even possible?
    I was going to purchase the hammer hangers for my Dakar pack but Also decided to slowly build a 63.. now I’m wondering if the hangers would just be wasted money.
    All I have so far is a set of 14” 5125s laying around.. baby steps lol.
  10. Jun 6, 2019 at 5:48 AM
    #610
    Jerneyman
    Jerneyman Well-Known Member
    Wes
    Huntsville, AL
    2011 Tacoma TRD OffRoad 4x4
    **Armor** Home Fabbed Hybrid Front Bumper Home Fabbed Rock Sliders Home Fabbed IFS Skid Plate Home Fabbed Mid Skid Plate Home Fabbed Transfer Case Skid Home Fabbed High Clearance Rear Bumper **Suspension** ADS Front Coilovers (Extended Travel, 700lb coils, Remote Resi) Total Chaos UCAs Chevy 63 Swap w/ custom shock hoops 14" Bilstein 7100s **Wheels/ Tires** Spidertrax 1.25" Wheel Spacers Front/Rear TRD Rock Warrior Wheels 285/75/16 BFG KO2s **Electrical** Pelfreybilt Auxiliary Fuse/Relay Panel Blue Sea Fuse Box Bussman 100 AMP Breaker **Recovery** Smittybilt 9.5k Winch **Lights** 20 Inch Single Row LED Bar Rigid Side Shooters (Flood/Pair) w/ CBI Offroad Ditch Light Brackets Rigid Duallys, Amber for fog lights **Miscelaneous Mods** Rear Diff Breather Relocation RAM Mount A-Pillar Mod w/ Garmin Power Cable DRT Fabrication Cab Mount Relocation Pinch Weld Mod (Mini Sledge Special) Short Rise Bed Bar for Tire Storage/ Hi-Lift Mount
    Those hammer hangers are designed to be bolted in the same bolt holes as the stock hangers. With the 63s, both front and rear mounts are being pushed further apart to accommodate the springs. So the hammer hangers could work but you’d be modifying them quite a bit. I’m pretty sure you’d get more flex with standard shackles anyway.
    Taconator_[QUOTED] likes this.
  11. Jun 6, 2019 at 11:16 AM
    #611
    Jerneyman
    Wes
    Huntsville, AL
    So what had everyone settled on for shackle angle? When mocking up the mounts to tack everything in place, should they sit at 45 degrees, then 20 degrees when sitting on all 4 wheels? I just want to make sure I understand all this before jumping in.
  12. Jun 6, 2019 at 12:26 PM
    #612
    ovrlndkull
    Skip
    Burlington, NC
    2005 DCLB Silver
    You'll have to play with it we did like 4 times before it settled where I wanted it. I am at like 25° but when we set it up I went ahead and accounted for added weight later on down the road. Every truck is different so dropped out angle doesn't always correlate to correct resting angle. We tacked it in place dropped the truck checked everything then did that several times till it was right.
    Jerneyman[QUOTED] likes this.
  13. Jun 6, 2019 at 12:29 PM
    #613
    Jerneyman
    Wes
    Huntsville, AL
    Generally you want the angle to rest between 20 and 30 degrees at ride height though?
  14. Jun 6, 2019 at 12:32 PM
    #614
    ovrlndkull
    Skip
    Burlington, NC
    2005 DCLB Silver
    Yes to get the best flex and ride quality. At full droop you also want it to be angled towards the rear a bit that way it can't go forward at all
  15. Jun 6, 2019 at 12:34 PM
    #615
    Jerneyman
    Wes
    Huntsville, AL
    And should full droop occur without any articulation? I imagine that with one side stuffed the other would potentially drop further out.
  16. Jun 6, 2019 at 12:40 PM
    #616
    ovrlndkull
    Skip
    Burlington, NC
    2005 DCLB Silver
    Kind of not really though you will still be limited by the length of your shock or limit strap and/or mounting of where the shackle is. They can kind of droop out a little further but nothing to worry with IMO. We set mine up by just jacking up the rear of the frame. I had the bed off and took the gas tank out as well since we plated my frame at the same time. Set the shackle position so at full droop both rear wheels off the ground shackle angle was ~85*. Now since I'm limited by my shock travel they only get to ~70* or so fully drooped out. Hence why I was mentioning needing 16" shocks. My added arch allows more stuff and droop than the typical chevy 63 leafs.
  17. Jun 6, 2019 at 12:48 PM
    #617
    Jerneyman
    Wes
    Huntsville, AL
    I plan on adding limit straps once I get everything setup where I can maximize the travel of my 14 inch shocks. This gives me somewhere to start though. How much time does plating the frame add to the whole process? I’ll need to add a beefed up crossmember to mount my limit strap tabs anyway.
  18. Jun 6, 2019 at 2:22 PM
    #618
    ovrlndkull
    Skip
    Burlington, NC
    2005 DCLB Silver
    It added a good 4 hrs or so. But we templated the frame then cut and fit the pieces and burned them in. @EatSleepTacos just made a little plate to go where his limit straps crossmember is. Maybe he can post some pics of that.
  19. Jun 6, 2019 at 2:30 PM
    #619
    Jerneyman
    Wes
    Huntsville, AL
    I’m blocking out a 3 day weekend to do this so I’ll probably end up doing everything I want during that time since I’ll have the bed off. I don’t mind a few 16 hour days. Don’t tell my employer that though...
    ovrlndkull[QUOTED] likes this.
  20. Jun 6, 2019 at 2:46 PM
    #620
    ovrlndkull
    Skip
    Burlington, NC
    2005 DCLB Silver
    So Fri it was me and Chris we took the bed off and hacked everything off and tacked the shock relocation brackets on and started making the frame plates. Sat. Chris and I got started around 6:30am then 4 other guys showed up around 8-9. It took the 6 of us until about 8 pm to get pretty much everything done. Sun morning Chris and I got up early again swapped his springs out then did a cab mount relocation on my truck and finished a few other little odds and ends. I headed home around 2pm sun.
    You need to have weight to put on the truck to simulate your static weight if you take the bed and other things off that'll normally be on the truck. This will be pertinent when it comes time to making sure you get the shackle angles set up right.
