How to: Chevy 63" Leaf Spring Swap
Discussion in 'Suspension' started by dakotasyota, Jun 13, 2015.
  1. Sep 16, 2019 at 1:17 PM
    #641
    Jerneyman
    Jerneyman Well-Known Member
    Wes
    Huntsville, AL
    2011 Tacoma TRD OffRoad 4x4
    **Armor** Home Fabbed Hybrid Front Bumper Home Fabbed Rock Sliders Home Fabbed IFS Skid Plate Home Fabbed Mid Skid Plate Home Fabbed Transfer Case Skid Home Fabbed High Clearance Rear Bumper **Suspension** ADS Front Coilovers (Extended Travel, 700lb coils, Remote Resi) Total Chaos UCAs Chevy 63 Swap w/ custom shock hoops 14" Bilstein 7100s **Wheels/ Tires** Spidertrax 1.25" Wheel Spacers Front/Rear TRD Rock Warrior Wheels 285/75/16 BFG KO2s **Electrical** Pelfreybilt Auxiliary Fuse/Relay Panel Blue Sea Fuse Box Bussman 100 AMP Breaker **Recovery** Smittybilt 9.5k Winch **Lights** 20 Inch Single Row LED Bar Rigid Side Shooters (Flood/Pair) w/ CBI Offroad Ditch Light Brackets Rigid Duallys, Amber for fog lights **Miscelaneous Mods** Rear Diff Breather Relocation RAM Mount A-Pillar Mod w/ Garmin Power Cable DRT Fabrication Cab Mount Relocation Pinch Weld Mod (Mini Sledge Special) Short Rise Bed Bar for Tire Storage/ Hi-Lift Mount
    Make sure when setting the shackle angle you set all 4 wheels on the ground and weigh the truck down like you'd be driving it. I mistakenly set my angle by only supporting the rear axle while my front was still set on the frame. The center of gravity was shifted towards the front and after I welded it all in, realized the angle was way to shallow and had to shift my shackles to the rear more.
    Take away. Only tack your mounts in until you have the truck completely on the ground and you're satisfied with the angles. Don't be a dummy like me.
    burntkat, marinemonkey and ovrlndkull like this.
  2. Sep 16, 2019 at 1:22 PM
    #642
    BamaTaco56
    BamaTaco56 Well-Known Member
    Trey
    I was thinking I’d get the front and shock hoops fully welded and then put the gas tank and bed back on before I fully weld the rear
  3. Sep 16, 2019 at 1:26 PM
    #643
    Jerneyman
    Wes
    Huntsville, AL
    That would work as well. I left my bed off and just added weight equivalent to the bed (i.e. my neighbor). Allowed easier access to other things. Shock hoops need to be welded while the bed is on the truck though so your clearances match the fender well. I tried to push mine up as high as I could in order to get maximum shock length and the only way to do that was with the bed on.
    burntkat and BamaTaco56[QUOTED] like this.
  4. Sep 16, 2019 at 1:29 PM
    #644
    Taconator_
    Taconator_ IG: ohv_tacotruck
    Eric
    SoCal
    18' DCSB TRD OR 4x4
    So 36hrs give or take at roughly $50hr, around 1,500-1,800 total?
  5. Sep 16, 2019 at 1:30 PM
    #645
    BamaTaco56
    Trey
    Makes sense. Should I simulate loaded weight when setting shackle angle. I have 600ish lbs on the bed when I camp, but don’t ride around daily with that much weight
  6. Sep 16, 2019 at 1:30 PM
    #646
    Jerneyman
    Wes
    Huntsville, AL
    For labor, sure. Personally if you’re spending that much, I’d do a bolt on swap. Much less headache.
  7. Sep 16, 2019 at 1:31 PM
    #647
    Jerneyman
    Wes
    Huntsville, AL
    For optimal performance at 600lbs, yes. So you might ride a bit high unloaded.
  8. Sep 16, 2019 at 1:33 PM
    #648
    BamaTaco56
    Trey
    That’ll be a fun task. Maybe just put husky @stronghammer back there on top of my tent and call it a day.
    stronghammer likes this.
  9. Sep 16, 2019 at 1:33 PM
    #649
    Taconator_
    Eric
    SoCal
    18' DCSB TRD OR 4x4
    I can’t weld, and even if I could I wouldn’t trust my self to get things lined up properly.
    Bolt-on.... 63?
  10. Sep 16, 2019 at 1:34 PM
    #650
    ovrlndkull
    ovrlndkull STUKASFK - HC4LIFE
    Skip
    Burlington, NC
    2005 DCLB Silver
    63s, XD Machete, Beat not Babied
    Depends on what all you are doing at the time of the swap. Me personally I'd charge a flat rate based on what all I am getting into.
    Lets see mine with a shock relocation and making and plating the frame took over 24 hrs. Myself and @Casper66 put in well over 30 hrs that weekend working on mine and his truck. Plus I had the help of 4 more people. 6 of us worked for 16 hrs straight in one day to get the majority of it done. Myself and Chris put in 9 hrs the day before just in prep. It's a job and not an easy one.
    For you
    Casper66 and Jerneyman like this.
  11. Sep 16, 2019 at 1:35 PM
    #651
    ovrlndkull
    Skip
    Burlington, NC
    2005 DCLB Silver
    Shackle angle was the hardest part you can easily center the axle just take a bunch of reference measurements.
  12. Sep 16, 2019 at 1:38 PM
    #652
    BamaTaco56
    Trey
    And that’s really just trial and error at the end of the day. Cutting everything off will be slightly sickening, but I don’t think I have any reservations for doing the swap at this point
  13. Sep 16, 2019 at 1:42 PM
    #653
    ovrlndkull
    Skip
    Burlington, NC
    2005 DCLB Silver
    You just need some friends for simulated weight @pabstsmeared :D
    Can't find the pic of them sitting on the frame. It's easier to just find some weights or something that is easily removed to put on and take off the frame than taking the bed on and off as well as the gas tank.
    f0YEBYsloKjmwxen0jA6Uy4Z2rYYMCX8CmM3FOkN_03023812956660caef3f65562b9056dd9bed6a19.jpg
  14. Sep 16, 2019 at 1:43 PM
    #654
    ovrlndkull
    Skip
    Burlington, NC
    2005 DCLB Silver
    We just tacked mine in like 4-5 places about a medium tack nothing too hard. And yes it's a bunch of trial and error all depends on the springs really. There are roughly 30 different variations of the chevy 63 springs maybe even more so each set up will be slightly different.
    mcharfauros likes this.
  15. Sep 16, 2019 at 1:46 PM
    #655
    pabstsmeared
    pabstsmeared Simulated Weight
    Tappahannock, Va
    '13 Super White DCSB TX Baja
    Mud Tars & Shit
    I now charge by the pound for frame sitting..... :bananadead:
    Skip you must've opened a honey bun or something right as you snapped this photo, you have my attention.
  16. Sep 16, 2019 at 1:48 PM
    #656
    Jerneyman
    Wes
    Huntsville, AL
    I’m talking about a set of Dakars, a shock relocation and set of hammer hangers. All that would probably be cheaper than paying for a 63 install.
    ovrlndkull likes this.
  17. Sep 16, 2019 at 1:49 PM
    #657
    SearArtist
    SearArtist GX poor
    NC
    GX470 & GX460
    Things
    I can see that being the biggest bitch.
    Tack mounts, hang springs, lower truck, measure...shit it's not right; lift truck, unbolt springs, grind off tack welds...rinse and repeat a dozen times.
    Jerneyman likes this.
  18. Sep 16, 2019 at 1:52 PM
    #658
    SearArtist
    SearArtist GX poor
    NC
    GX470 & GX460
    Things
    Did you see the shocks I bought today, in my build thread? I think I tagged you.
  19. Sep 16, 2019 at 1:52 PM
    #659
    ovrlndkull
    Skip
    Burlington, NC
    2005 DCLB Silver
    We got mine in 5 tries. If you take away one for trying the 6" shackles 4 We were pretty close with some maths then just fine tuned.
  20. Sep 16, 2019 at 1:53 PM
    #660
    ovrlndkull
    Skip
    Burlington, NC
    2005 DCLB Silver
    I'm not getting half the tags or alerts on any of the forums lately.
