how to clean engine
Discussion in '1st Gen. Tacomas (1995-2004)' started by tacoma driver99, May 28, 2011.
  1. May 28, 2011 at 4:20 PM
    tacoma driver99
    tacoma driver99 [OP] New Member
    Thomas
    mississippi
    it is a ruby red 1999 toyota tacoma
    lifted
    can i take a hose and spray it off or do i need to take it somewhere?:confused:
  2. May 28, 2011 at 4:21 PM
    Madjik_Man
    Colorado Front Range
    Simple green & rinse
  3. May 28, 2011 at 5:24 PM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    DO NOT USE SIMPLE GREEN. It attacks aluminum. Read the bottle, it will confirm this.
    Use a degreaser/soap and rinse.
    NMTrailRider and opteron like this.
  4. May 28, 2011 at 5:31 PM
    Khaos
    Khaos Big Member
    Bryant
    Jacksonville, Florida
    2011 DC TRD SPORT Prerunner
    3” spacer lift, 285/75/17 KO2, Spidertrax 1.25” spacers
    Every thread I've ever read recommended simple green. Interesting..
    I really need to clean my engine bay. It still looks like shit from when I was a kid and loved to mud.
  5. May 28, 2011 at 5:33 PM
    ian408
    ian408 Well-Known Member
    Ian
    Santa Clara, CA
    09 Tacoma
    Use Simple Green. Just don't let it sit for ever.
    FAQ from Simple Green.
    opteron likes this.
  6. May 28, 2011 at 5:38 PM
    Rebel Taco 22
    Rebel Taco 22 mall crawler
    I just hosed it off. Still works fine.
  7. May 28, 2011 at 5:45 PM
    bellassaiw10
    bellassaiw10 Formally afroman5015
    Currituck NC
    09 LMM 2500HD Duramax
    simple green and a pressure washer works good
  8. May 28, 2011 at 5:46 PM
    707tothe907
    707tothe907 Superior Member
    Jake
    Chico NorCal
    05 DCSB Off Road
    Just use a pressure washer. All of that degreaser crap has so much chemicals in it it's horrible for the enviroment esspecially when it gets washed down the storm drain.
  9. May 28, 2011 at 5:47 PM
    Bz3r0
    Bz3r0 Smackalicious!
    Bryan
    Edwards AFB, CA
    White 2017 TRD Offroad
    Under Construction
    1. Acquire a spray nozzle that has multiple spray options.
    2. Using the "Shower" selection, LIGHTLY go over the engine. (There should be no need to use a "Full Blast" sprayer).
    3. Use "Purple Power" or "Dawn Liquid dish detergent" and spray to coat what you need to clean.
    4. Get a microfiber rag or soft bristled brush to scrub the tough stuff.
    5. repeat 3 & 4 as needed.
    6. Dry and use Armor-all on the plastic/rubber you want to preserve.
    7. Wipe off excess Armor-all
    Thats how i do it, and haven't had a problem after cleaning this way... Really, i've only needed to use dawn or purple-power after pollen season or if its been awhile since i've cleaned my engine bay. I don't roll through high mud or anything like that. Hope some of this is useful.
  10. May 28, 2011 at 5:52 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    i always pressure wash my engine compartment with it running. never have had any probs, but i try keeping most of the blast away from the alternator and other main electrical areas. simple green and greased lightning work wonders.
  11. May 28, 2011 at 6:02 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    yeah....you gotta dilute that stuff fo sho, but it does clean engine parts that are gunked up pretty good. i still like greased lightning better than most things for cleaning.
  12. May 28, 2011 at 6:03 PM
    kmok
    kmok Plastidipped ma Hootus!
    Kyle
    Columbus, Ohio
    2005 Subaru Outback XT 5MT
    I used simple green and used a pressure washer to rinse it off. No problems here and my engine bay is very clean :D
  13. May 28, 2011 at 6:11 PM
    NC15TRD
    NC15TRD Well-Known Member
    Nick
    PA
    16 Sierra SLT All Terrain
    Readylift, Truxedo, Husky Liners, Carven
    Just used simple green today on my engine bay. Looks awesome, almost like new, and smells nice too!
  14. May 28, 2011 at 6:49 PM
    kmok
    Kyle
    Columbus, Ohio
    I thought it smelled nice too lol
  15. May 28, 2011 at 7:01 PM
    Monkeysuncle
    Monkeysuncle My Cat's breath Smells like Cat Food
    Kevin
    Florida
    99 Tacoma SR5 4x4 5 speed Manual Hubs
    Diff Breather,CB thingy,GPS,Cop Shocks,Cop Brakes, old Man Emu 881's Dakar Leaf Springs and Nitro sport shocks. Deck Plate mod
    As far as degreasers go the castrol purple(or similar) cleaner will etch,scar, discolor aluminium and polished stainless parts when used at full concentration. But if you follow the destructions you will be fine to wash off simple road grime and engine filth. My rear main is leaking and I use it on my skid plate at full strength and it does wonders. Simple green is good also, but like others have said, spray, scrub, rinse, rinse, and avoid water on anything you don't want to replace
  16. Jun 3, 2011 at 10:00 PM
    tacoma driver99
    Thomas
    mississippi
    lifted
    my engine is clean thanks to all of yall thanks
  17. Jun 3, 2011 at 10:34 PM
    x2468
    x2468 Well-Known Member
    '02 TRD 4wd V6 Xcab Sr5
    "Aluminum - Is it safe to use Simple Green® on aluminum?
    When used with caution and according to the instructions, Simple Green All-Purpose Cleaner has been safely and successfully used to clean aluminum. Simple Green All-Purpose Cleaner, Crystal Simple Green® Cleaner/Degreaser, Simple Green Pressure Washer Concentrates, and Pro Series™ Simple Green® Automotive Cleaner have been used on aircraft, automotive, industrial and consumer aluminum items for over 20 years. However, caution and common sense must be used: aluminum is a soft metal that easily corrodes with unprotected exposure to water. The aqueous-base and alkalinity of Simple Green All-Purpose Cleaner can accelerate the corrosion process. Therefore, contact times for unprotected or unpainted aluminum surfaces should be kept as brief as the job will allow - never for more than 10 minutes. Large cleaning jobs should be conducted in smaller-area stages to achieve lower contact time. Rinsing after cleaning should always be extremely thorough - paying special attention to flush out cracks and crevices to remove all Simple Green® product residues. Unfinished, uncoated or unpainted aluminum cleaned with Simple Green products should receive some sort of protectant after cleaning to prevent oxidation. "
    Is anyone using a protectant like simple green recommends?
  18. Jun 3, 2011 at 10:43 PM
    ian408
    Ian
    Santa Clara, CA
    09 Tacoma
    I don't use any sort of protectant. I am careful to thoroughly wash the stuff off though. And that means sometimes more soap and water.
  19. May 14, 2013 at 7:04 PM
    dand
    dand Blood and tears
    Dan
    Newport News VA
    2021 DCSB TRD Sport Army Green
    Yes, think of the children.....;)
    I thought this thread needed to be restarted. ...
  20. May 14, 2013 at 7:08 PM
    kws129
    kws129 Well-Known Member
    PA
    TRD Off Road Double Cab
    I like the gunk foamy engine bright. Get thenengine warm give a liberal doucheing of gunk let it sit fornanfew minute then hose off. Works awesome.
