"How to" clean MAF sensor
Discussion in 'Technical Chat' started by 02ttaco, Apr 3, 2011.
  1. Apr 3, 2011 at 7:46 PM
    02ttaco
    02ttaco [OP] Member
    Tyler
    Maryland
    02 tacoma trd
    three inch spacer lift with blocks in the rear
    I took my truck through some thick mud last night. The whole night and part of the morning the truck ran great. It was after i washed underneath the hood the truck started bogging down and seemed to be misfiring. I had this problem on my old nissan and it was the MAF sensor which i replaced.
    Could there be another possible issue? Upon start up the truck has a really rough idle:confused:, however The problem seems to correct itself after going 5 miles or so. Check engine light came on but i have yet to read the code. Thanks in advance for any help
  2. Jun 2, 2011 at 6:07 PM
    pyroskier
    pyroskier Well-Known Member
    Jacob
    Laramie, WY
    2004 Ext Cab TRD 3.4
    Bump for same situation
  3. Jun 2, 2011 at 6:10 PM
    scocar
    scocar Patron of the Farts
    Did you check to see if the air filter is wet?
  4. Jun 11, 2011 at 1:18 AM
    x2468
    x2468 Well-Known Member
    '02 TRD 4wd V6 Xcab Sr5
    Either way can anyone tell us how to clean a Maf?
