How to clean your Power steering resivor
Discussion in '1st Gen. Tacomas (1995-2004)' started by 4banger4x4, Mar 29, 2014.
  1. Mar 29, 2014 at 4:19 PM
    4banger4x4
    4banger4x4 [OP] Probably should'nt have done that.
    Eric
    Whorelando, Fl
    So I discovered this by accident but I figured I would share being that ive seen a lot of people complain about this.
    You can take the lid off the reservoir and access the screen to clean it.
    1. Drain All the fluid from the reservoir and pump.
    2. Remove power steering belt
    3. Remove pulley from front of PS pump
    4. Remove the two thru bolts that bolt the pump to the engine bracket
    5. Once removed, there are 3 bolts holding the reservoir to the pump, remove them.
    6. You need to pull the pump and reservoir apart. The reservoir has an o-ring that seals it inside the pump so it takes a little force to separate the two.
    7. Once separated flip the reservoir upside down and you'll see clips all the way around the cap. Pry these tabs out using a small screw driver. (Picture below is a tab I already pried loose)
    8. Once open you'll see the screen and be able to fully clean it. The best way I found to clean it was to soak it in gas and keep shaking it up and draining the gas out, you'll see all the shit falling out of the reservoir ( picture shows inside of reservoir without screen inside. Its missing because of my stupid mistake.)
    9. Once clean put the rubber seal back on the cap and then put the cap back on the reservoir. I used a pair of linesman pliers to reset the clamps.
    10. Put everything back on the truck and fill up the reservoir and bleed the system by having the wheels up in the air and turning lock to lock a few times with the motor off, and then start the motor and do it a few more times till there is no noise
    I am not responsible for any damage to your truck.
    Marc70 and beikokupilot like this.
  2. Mar 29, 2014 at 6:47 PM
    Taylor
    Taylor Check out NASA Spec3!
    Taylor
    Vienna, Virginia
    NASA Spec3 RaceCar
    Is this something that even needs to be done?
  3. Mar 29, 2014 at 7:17 PM
    lipster
    lipster Well-Known Member
    Northern MN
    2004 ext cab 3.4 auto TRD
    License plate frame
    It is if it is whining. Or hard to steer.
    Lots cheaper to try first as opposed to a new pump, only to find the plugged screen was the problem, as it was with mine.
    I did not have to remove the pulley. Bolts were easy to get at if I rotated the pulley a bit.
  4. Mar 29, 2014 at 8:22 PM
    Taylor
    Taylor
    Vienna, Virginia
    NASA Spec3 RaceCar
    Ohhh. TIL
  5. Mar 29, 2014 at 8:24 PM
    PcBuilder14
    PcBuilder14 Well-Known Member
    Brent
    Nor Cal
    2018 Tacoma TRD Off Road 4x4
    Now how do you do this without getting ATF everywhere? Haha
  6. Mar 29, 2014 at 9:20 PM
    4banger4x4
    Eric
    Whorelando, Fl
    Drain the fluid first? Kinda like asking how not to get kotor oil everywhere when you rebuild a motor.
  7. Mar 29, 2014 at 9:22 PM
    PcBuilder14
    Brent
    Nor Cal
    From what point though? You don't need to drain the whole pump/hoses/rack. That's what I was asking ;)
  8. Mar 29, 2014 at 9:49 PM
    tacomataco2
    tacomataco2 A dude
    Mass
    15’ ACLB
    Some of this Some of that
    Hmmm.. i just took the reservoir off and loaded the thing full of brake clean and shook it up inside a lot… Never thought to disassemble it. Nice!
  9. Mar 29, 2014 at 9:58 PM
    4banger4x4
    Eric
    Whorelando, Fl
    if youre going to take it off and clean it you might as well change all the fluid out while you're at it. I took a syringe and pulled all the fluid out of the reservoir, and then with the tires up in the air and the return line in a gatoraid bottle i turned the wheels till no more fluid came out, and then take your pump and reservoir off.
  10. Mar 30, 2014 at 5:01 AM
    lipster
    Northern MN
    License plate frame
    Turkey baster.
  11. Mar 30, 2014 at 10:11 AM
    PcBuilder14
    Brent
    Nor Cal
    Cool, thanks! :thumbsup:
  12. Mar 30, 2014 at 10:19 AM
    4banger4x4
    Eric
    Whorelando, Fl
    No problem, and just to be safe cover youre alt and belts below with plastic bags just incase you do spill some stuff
  13. Mar 30, 2014 at 2:17 PM
    Lester Lugnut
    Lester Lugnut Well-Known Member
    N of Mex-S of Canada-E of LA-W of NC
    '15 Tacoma PreRunner V6 SR5 Auto
    Every time I change oil, I siphon the power steering reservoir and replace what's extracted. Usually 8-10 oz is drawn out. 10 yrs. later my fluid and reservoir are as clean as the day I bought the truck.
    You can also flush the whole system by pulling the return line. This approach is documented all over the WEB and I would bet there are countless how-to videos on youtube.
  14. Apr 14, 2014 at 6:00 PM
    Eric05774
    Eric05774 Active Member
    vermont
    99 tacoma
    wow thanks for the tip, i cleaned the shit out of it before but everytime it looked clean i would fine more black particles in the screen.
  15. Apr 14, 2014 at 6:02 PM
    4banger4x4
    Eric
    Whorelando, Fl
    when i got my new to me resivor that had a screen in it, it was bad and took like 3 days to clean out. But i would put it in a cup and soak it in gas, and the pull it up and shake out all the crap. took 2 days of doing that to get little black shit to stop falling out.
  16. Apr 14, 2014 at 6:06 PM
    carcharias
    carcharias Giggiddy what what
    Los Angeles, CA
    SOLD: '11 AC MGM OR
    Kings all-around w/ 700lb coils, Dakar leaf pack, TC uca's, DO single hoop bumper, BAMF bolt-on sliders w/ kickouts, Rigid 20" e-series spot/flood, aFe pro-dry, BFG KM2 255/85/16, silver TRD FJ wheels, WARN M8000-s, Access LE, Grillcraft, BAMF lightbar, BAMF rear dif skid, BAMF LCA skids, window tint, Wet Okoles, WeatherTech floorliners, Silverstar lights, led dome lights, Redline Tuning hood struts, center console lock mod, mag-lite mod, extra d-rings, re-routed exhaust, ATO skids, ATO Hi-Lift mounts, pipe tailgate lock, seatbelt alarm delete, wheel/spare locks, Viper 5901, LoJack... WISHLIST: a golden canary that poops platinum
    My steering seems to make a dull "whir" when I turn the wheel and for the duration of most wheel turns. Is this what could be causing it?
  17. Apr 14, 2014 at 6:06 PM
    4banger4x4
    Eric
    Whorelando, Fl
    Now this is the new reservoir that i got from a member on here and you can see the screen was pretty clogged up.
    beikokupilot likes this.
  18. Jan 27, 2019 at 11:13 AM
    beikokupilot
    beikokupilot Well-Known Member
    Utah
    1997 Red Tacoma 4WD
    Power steering pump, Steering rack, Tie rods, Radiator cap, Thermostat, New radiator, magnets to hold the fuel door closed, new starter drum/cylinder, dash lights changed to red, replaced all carpet in the cab. Not real “mods”, but all work
    Reviving an old post. Almost 5 years later. I’m gonna have to try and take the lid of my reservoir and clean out the mesh. If you remember right @4banger4x4 do you remember what you did that made you lose the mesh? I just wanna make sure I don’t lose mine. I flushed my system twice, took the reservoir off and used a whole can of brake cleaner to try and clean the crud out and my whining went away for a couple days and then came back.
    Replaced the power steering pump, with the old reservoir on there. Same whining as with the old pump. Never even thought about taking the lid off the reservoir. Thanks for posting this. I’ve been searching for anything for weeks.
  19. Jan 27, 2019 at 5:27 PM
    4banger4x4
    Eric
    Whorelando, Fl
    I’m gonna say that I pushed on it with a screw driver while the whole thing was still assembled not knowing what at was. Once I took the top off I realized what it was and how I messed up
    beikokupilot[QUOTED] likes this.
  20. Jan 27, 2019 at 6:50 PM
    beikokupilot
    Utah
    1997 Red Tacoma 4WD
    Ok thanks!! Think it might be easier to work on it leaving the mesh in? From the second set of pictures I’m not sure I see an easy way to get the mesh out without damaging it. Or is that what the little cutout is for? With a screwdriver, can I force the mesh out without tearing it?
    Thanks for your quick response. I’m about to start working on it.
