How to clear my foggy headlights?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by drakeb252, Jan 24, 2023.
  1. Jan 24, 2023 at 5:36 PM
    drakeb252
    drakeb252 [OP] Well-Known Member
    2014 Grey tacoma TRD
    2 inch Rough Country leveling kit
    Does anyone know how to eliminate foggy headlights so they’ll look like new?
  2. Jan 24, 2023 at 5:39 PM
    JasonLee
    JasonLee Hello? I'm a truck.
    Q322+3C Denver, Colorado
    15 TRD OffRoad
    TRD Supercharger and more.
    Many ways. The easiest is to buy new OEM housings.
    Outside of that, wet sanding with various grit levels of sandpaper and then finish with a UV protectant and/or wax. There are commercial products for this. Here's a website full of junk ads that show you some examples: https://www.cnet.com/roadshow/news/best-headlight-restoration-kit/
    drakeb252[OP] likes this.
  3. Jan 24, 2023 at 5:51 PM
    kozy
    kozy Well-Known Member
    Tim
    Arizona
    2006 Access Cab 4x4/6MT
    Here's the process that works pretty well for me:
    1. Wet sand with 800 grit 2 times covering the whole light
    2. Wet sand with 1200 grit 2 times covering the whole light
    3. Wet sand with 2000 grit 2 times covering the whole light
    4. Apply plastic polish. I use this product from meguiars with a foam wheel drill attachment a little bit similar to this one.
    Be aware that your headlight fog will look WORSE until step 4, don't panic. Also, I'm sure there are better UV protection products out there but I've been using the meguiars one for 7 or 8 years and it works great.
    usmc2msu likes this.
  4. Jan 24, 2023 at 5:53 PM
    jacpa
    jacpa Well-Known Member
    Jim
    2021 4Runner TRD ORP
  5. Jan 24, 2023 at 5:55 PM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    I polish my 09 a couple times with a buffer and mothers aluminum mag polish…just have to turn at a low speed
  6. Jan 24, 2023 at 6:13 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    I polished them on my 2007 2 or 3 times over the years. The 1st time they came out looking like new. Not quite as good the 2nd and 3rd times, but still a huge improvement. I finally broke down last fall and bought new ones. Made a HUGE difference in my 16 year old truck. Not only does it look better, but I can see better at night.
    jackn7 likes this.
  7. Jan 24, 2023 at 6:29 PM
    Geeves77
    Geeves77 Well-Known Member
    Mark
    Northeast
    2011 Tacoma DCSB
    3 inch Icon lift with UCA’s
    Tooth paste. No, I have not smoked to much tonight. Try it!!!!
  8. Jan 24, 2023 at 6:34 PM
    point45
    point45 Well-Known Member
    SoCal, OC
    05 DCSB TRD offroad
    I used to polish them at least once a year and use the protectant.
    Just clearcoat them after polishing. I haven't had to polish them in 2 years.
    Sprig likes this.
  9. Jan 24, 2023 at 9:36 PM
    TacoTuesday1
    SD CA
    replace
    19BlancoAmocat and CaTaco101 like this.
  10. Jan 25, 2023 at 2:05 AM
    Mudsock
    Mudsock Well-Known Member
    Indiana
    2010 2.7 4x4
    Rock auto and buy new ones.
    Every time I polished lenses, they would get foggy/ dull again in a short amount of time. The non oem light assemblies aren’t very expensive.
  11. Jan 25, 2023 at 4:03 AM
    Doc Samson
    Doc Samson Well-Known Member
    Almost NoVA
    2009 Tacoma TRD Sport
    None... yet.
    Depends on how much effort you want to put into it! I've never had much luck with any kits but I also haven't tried any recently. ChrisFix has a couple of good vids and I've used his method several times to good effect...
  12. Jan 25, 2023 at 4:42 AM
    FishaRnekEd
    FishaRnekEd Well-Known Member
    New Orleans, LA
    2005 4.0 6spd 4x4 Dbl Cb short bed
    I take the same buffing wheel that i use for paint.
    I use whatever polishing compound i have for paint.
    Scrub it off with dish soap when done.
    Dry it and see how it looks.
    Repeat the process again if necessary.
    After it looks as smooth and clear as it's gonna get, i get a clean polishing pad and put a coat of mother's cleaner wax.
    Let it fully dry and wipe off.
    Same exact process i use for paint.
    Nice and smooth, bugs won't stick.
    Old my old plastic was really yellow (not going to buff that out) so after 17 years, i finally replaced the whole assembly.
  13. Jan 25, 2023 at 4:44 AM
    FishaRnekEd
    New Orleans, LA
    Toothpaste has the same grit in it as other lite polishing compounds. (Ground, fine Diatomaceous earth)
  14. Jan 25, 2023 at 4:53 AM
    Venom
    Venom Well-Known Member
    Kevin
    Massachusetts
  15. Jan 25, 2023 at 7:16 AM
    Leomania
    Leomania Well-Known Member
    Leo
    2011 Tacoma TRD Sport DCLB v6 4x4
    All stock, baby!
    Depending upon how yellow your lights are, and whether it is limited to the outside of the lenses, you’ll get varying results from a cleaning/restoration product. Mine looked fairly bad, I polished them well with a Rain-X windshield polish, and that got them 90% of the way there. I then purchased this inexpensive 3M kit, which has a 3000 grit sanding pad and a couple packets of UV protectant. They got it another 5% clearer, and to my eye, they look great.
    @kozy is spot on about the “looks worse until the protectant goes on”. You’re going to think, “WHAT HAVE I DONE?!?” but in the end it looks fine, so long as you’ve polished through the degraded plastic to the clear stuff underneath.
  16. Jan 25, 2023 at 8:22 AM
    SpreadHead
    SpreadHead New Member
    2012 DCSB TRD Off-road
    Definitely go the polishing route these other guys have mentioned. The aftermarket headlight assemblies look cool but are garbage compared to the OEM, and OEM housings are expensive. You've got nothing to lose trying to polish them up and add the UV protectant. Maybe $40 Tops in supplied to do this. Maguires plastic polish works really well with a rag wheel or foam pad on a standard drill. Then just wipe on the UV coating stuff. It'll last years.
  17. Jan 25, 2023 at 9:58 AM
    BlkDakDave
    BlkDakDave Well-Known Member
    David
    CC TX
    07 AC PreRunner TRD/Off Road
    I heard about this about a year or so ago. I had some on the shelf so I gave it a try and it worked great. I follow up with a coat of Meguiars Gold Class Carnauba paste wax.
    HondaGM[QUOTED] likes this.
  18. Jan 25, 2023 at 11:31 AM
    jaymac10
    jaymac10 Well-Known Member
    Kelowna, BC
    2013 TRD Sport
    OEM Baja Kit
    It's easy to get them clear, the trick is to keep them clear! I did mine with a kit. I followed instructions and only applied one coat of the UV clear coat. Will re-do process this summer and put on 2-3 clear coats which will hopefully last longer than a couple years.
  19. Jan 25, 2023 at 11:51 AM
    CaTaco101
    CaTaco101 Well-Known Member
    California
    '13 TRD Off-Road PreRunner
    What’s the cheapest online for oem?
    im not keen on polishing my headlights every year or two.
    I’ve heard they get worse faster after you first polish so you have to keep polishing.
  20. Jan 25, 2023 at 7:48 PM
    Mudsock
    Indiana
    2010 2.7 4x4
    Maybe I got lucky, but, mine have been on for 5ish years and still look great. And they weren’t very expensive.
    RockAuto.com
