How To Convert 2.5x6” Coilovers for OEM Replacement Use (2nd Gen Tacomas)
Discussion in 'Suspension' started by blackhawke88, Jun 28, 2012.
  1. Jun 28, 2012 at 12:15 PM
    blackhawke88
    blackhawke88 [OP] wo ai ni bao bei ^_^
    SGV, CA
    07 TRD Offroad
    I recently converted a 2.5x6” King Coilover from a generic off road vehicle (non-toyota) to be used in the OEM shock mounts. This is a brief write up of how I did it.
    I first did a lot of calculating to determine which shocks I would need to get to fit within the stock mounts. I consulted the King website to get some numbers:
    King OEM Tacoma front Coilovers: 16.750” compressed length, 21.687” extended length, 4.937” total travel
    King Performance Series 2.5x6” Coil Over: 14” compressed length, 20” extended length, 6” of total travel
    Now, what makes the King OEM series coilovers fit on a Tacoma?
    - 1.25" bearing spacers to fit in the top plate adapter (YOU MUST CONFIRM THIS WITH THE COMPANY YOU ARE PURCHASING THE TOP PLATE ADAPTERS FROM FIRST)
    - 1.5” bearing spacers to fit in the stock lower control arm shock mount
    - Raised lower spring cup to clear space for the CV axles
    - A 2” thick rod spacer that fits between the rod end and the spring cup to raise the coils even higher to clear the CVs. Note that this robs the coilver of shock travel
    - Top plate adapter on top of the coilover that converts the top mount from eyelet to the Toyota 3 bolt design
    - 600 – 650lb springs
    After recognizing these necessary conversions, I set out to obtain the following parts:
    - 1.5” bearing spacers from Polyperformance: Part Number: KRS-25016-008
    - Raised lower springs place: part number: KRS-25301-003
    - 3” extended rod end: Part number: KRS-25005-004. I ditched the rod spacer and opted for a rod end because it allowed us to use the full 6” of shock travel
    - Top plate adapter from a buddy’s Camburg LT kit that he didn’t need. You can either make these yourself, or get it from King, Camburg, Fox, Total Chaos, and Engage. I know Engage sells a set of these for under $100
    - 14” 600lb King Springs from a swap meet
    If you don’t want to piece it together, you can buy a 2.5x6” King Coilover from Downsouth Motorsports and, in the lower options drop boxes, choose:
    - 6.0” travel
    - +3” Length Longer Rod End (+$50)
    - 90 Degree Hose Adapter (+$15)
    - Raised Lower Spring Plate (free)
    Mention that you need a 600 or 650 lb spring too. When all is said and done and 2 are added in the cart, the total price comes out to $1,142.00, around $300 cheaper than the King OEM replacement shocks. Now all you have to do is find the 1.5” bearing spacers and the Top plate mount and you are set.
    The coolest thing about this is you can find used 2.5x6" coilovers for way cheaper than OEM King Replacement Toyota Coilovers. All it takes is to find the rest of the parts you need to convert it used or new and, depending on how resourceful you are, you can have a King Coilover that pulls more shock travel than the OEM series for way less than a OEM King Coilover.
    Here is our finished product mounted on Jen’s truck. It cycles nine inches of hub travel without the CVs or anything else binding, and uses almost the full 6” of shock travel before hitting the stock bump stops:
    Full Compression Cycling:
    Full Droop Cycling:
    With 12" 550lb springs on. These were way too soft so we later switched to 14" 600lb springs:
    Ride Height:
    And this is a picture pointing out where the rod/shaft spacer on the OEM replacement Kings are that robs travel:
  2. Jun 28, 2012 at 12:40 PM
    Taqoma
    Taqoma Well-Known Member
    Brennan
    Los Angeles
    2011 TRD Off-Road
    TRD Supercharger, TRD CAI, Camburg LT, Fox 2.5x8 coilovers, Fox 2.0 bumps, Deaver e30 leafs, Fox 3.0x18 triples, Avid sliders, Yaesu 2900R, Pro Comp 7089 16x8, DDM 55w HID Hella 500FF, DDM 35w HID headlights, Magnaflow 11255 muffler, PLX DM-100 OBDII, Autometer Ultra-Lite II Boost gauge, Flex Pod gauge mount, LSK tube bumper, McNeil fenders, Fiberwerx bedsides, 285/75/16 Toyo MT's
    so can I get this 3” extended rod end: Part number: KRS-25005-004 and convert my OEM kings?
  3. Jun 28, 2012 at 12:42 PM
    MonkeyProof
    MonkeyProof Power Top
    SoCal- SGV
    Why no spindle gussets?
    Nice write up!
  4. Jun 28, 2012 at 12:43 PM
    blackhawke88
    SGV, CA
    07 TRD Offroad
    technically yes, but it will make your Kings way longer because your Kings actually have a 8" shaft vs Jen's 6" shaft, and you saw how hard it was to squeeze it in the lower shock mount with the regular rod end.
    If you got the 3" rod end, you would need to get limit straps for your front and wouldnt be able to use the last 2-3" of shock travel.
  5. Jun 28, 2012 at 12:43 PM
    blackhawke88
    SGV, CA
    07 TRD Offroad
    spindle gussets are sitting in the garage waiting to be welded on!
  6. Jun 28, 2012 at 12:49 PM
    blackhawke88
    SGV, CA
    07 TRD Offroad
    This picture shows where the OEM Kings shaft spacer between the rod ends and the lower springs plates are that rob around 2" of travel:
  7. Jun 28, 2012 at 12:52 PM
    Taqoma
    Brennan
    Los Angeles
    2011 TRD Off-Road
    so for me, pointless thread ;):):D
  8. Jun 28, 2012 at 12:53 PM
    blackhawke88
    SGV, CA
    07 TRD Offroad
    lol yup! This thread is for people who cant afford fully adjustable compression OEM replacement Kings!
  9. Jun 28, 2012 at 12:54 PM
    Taqoma
    Brennan
    Los Angeles
    2011 TRD Off-Road
    it's a curse...everyday I keep turning the compression up/down in the rear :(
  10. Jun 28, 2012 at 1:12 PM
    blackhawke88
    SGV, CA
    07 TRD Offroad
  11. Jul 6, 2012 at 10:19 AM
    6spd
    6spd Well-Known Member
    san diego
    2023 4x4
    damn! I totally would have done this! ah well. new to the game.
  12. Jul 29, 2012 at 12:13 PM
    superwhite
    superwhite Well-Known Member
    sean
    Western NC
    07 double cab 4x4
    Dana 60 rear Chevy 63's shackle flip mid travel gears lockers and 38's in progress
    can someone post a link to the coil bucket adapter? i cant seem to navigate those sites well enough to find one haha.
  13. Jul 29, 2012 at 12:46 PM
    blackhawke88
    SGV, CA
    07 TRD Offroad
    Not so much a direct link, but contact the following companies by googling them:
    - Total Chaos Fab
    - Camburg
    - Engage Off Road
    Each of the above companies have the adapters for sale. Just call them for a price.
  14. Jul 29, 2012 at 3:26 PM
    superwhite
    sean
    Western NC
    07 double cab 4x4
    for sure, ill have to give them a call tomorrow, didn't see them listed on any of their sites.
  15. Jul 29, 2012 at 3:31 PM
    superwhite
    sean
    Western NC
    07 double cab 4x4
    one more question, where can i get the adapter to charge the kings with nitrogen?
  16. Jul 29, 2012 at 3:35 PM
    stunt man hans
    stunt man hans DISPLACED VIKING LIVING IN WYOMING
    Hans
    LIVE FREE OR DIE
    2015 AEV RAM 3500
    FULL AEV PROSPECTOR KIT++
    nice this will save somebody a pretty penny great job on this.
  17. Jul 29, 2012 at 10:04 PM
    superwhite
    sean
    Western NC
    07 double cab 4x4
    just ordered the kings from dsm, just need to give king a call in the morning and see about getting the top mounts. Super stoked to have the remote resivoir setup and 6" travel for around 1400, not bad if you ask me; considering the direct replacements are closer to 2k.
  18. Jul 29, 2012 at 10:10 PM
    6spd
    san diego
    2023 4x4
    this really should be stickied. this is a great way to maximize the stock tacoma travel with great shocks, rather than paying more for the OEM length kings.
  19. Jul 29, 2012 at 10:11 PM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    engage sells the top mounts for 75
  20. Jul 29, 2012 at 10:23 PM
    superwhite
    sean
    Western NC
    07 double cab 4x4
    awesome, thank you sir!
