How to Custom Startup and Screen Off
Discussion in 'Audio & Video' started by Ole Shawn, Nov 1, 2013.
  1. Jan 27, 2015 at 7:22 PM
    #141
    molimelight
    molimelight Well-Known Member
    MO
    14' Pyrite Mica TRD Sport 4X4
    Not sure what OS you are using, but many times systems will put hidden files in the folders, such as thumbnail indexes and the like. If you are putting the images in the folders in Windows (I'm using W7), under Tools/Folder Options, go to View and under that there is a folder icon in the list titled "Hidden Files and Folders" select "Show hidden files and folders" then scroll down and deselect "Hide protected operating system files." It wil give you a warning, but just click OK. Now look at your folders and see if anything else shows up. If it does, delete it so just your files are listed in the folder and try it again. You also might try changing the file type to all lower case. Instead of JPG, try jpg. That's all I can think of for now.
    Ruggybuggy likes this.
  2. Jan 28, 2015 at 11:40 PM
    #142
    gti2taco
    gti2taco Well-Known Member
    Brian
    Va Beach
    14 trd offroad, stock
    I know what I'm doing tomorrow. Sub'd
  3. Jan 30, 2015 at 8:53 AM
    #143
    bluesttape
    bluesttape Well-Known Member
    Denver
    '14 TRD Sport DCSB
    Debadged 3in Lift KO2s 275/70/17 OEM Stock Rims w/TRD Center Caps TRD Cap-Back Exhaust Avid Light Bar A.R.E. CX Cap OEM Nerf Bars OEM Rack on Cab Thule Rack on Cap WeatherTech Floor-liners WeatherTech Vent Visor CoverKing Seat Covers Chicco Keyfit 30 :-) Clifford 5806x Alarm & Remote Start LED Replaced (dome,map,flasher, reverse, & parking) Salex Organizer in Glove Box & Center Console Fully Tinted 12in ClearBra
    I was able to get it to work at first go on 2014 with Entune.
    Image Size (dimension): This can be done easily using 'Paint' which is built into Windows. I used 1280x720 which is standard HDTV screen ratio for 720p (not 1080p or 1080i). http://en.wikipedia.org/wiki/Display_resolution
    Image Format: jpeg
    File Size: I used one at 53mb and one at 143mb. Not sure if there is a file size limit or not.
    Folder Names: StartupImage AND DisplayOffImage -- These need to be in the root folder (main folder of flash drive)
    USB Drive: Formatted to FAT32
    Hope this helps. Also, thanks to whoever made the Back to the Future image. I extended the color and removed the lines in-between and it looks SWEET. If I could figure out how to get pix on the forum, I would upload
    davegoroun, dmurph1996 and Fredfifty like this.
  4. Jan 30, 2015 at 5:05 PM
    #144
    molimelight
    MO
  5. Feb 2, 2015 at 9:08 PM
    #145
    monkiboy
    monkiboy Well-Known Member
    did you ever get yours to work?
    I am having the same issue as you and it is indeed aggravating.
  6. Feb 2, 2015 at 9:13 PM
    #146
    monkiboy
    just reduced the file sizes to <50KB and it worked just gravy but the image quality suffered big time. going to increase resolution as much as possible while getting it to recognize but finally it works!
  7. Feb 4, 2015 at 5:15 PM
    #147
    molimelight
    MO
    monkiboy, if you're still having problems, you can PM me and send me the highest resolution image you have of the image you want to use and I'll see if I can adjust it down without losing image quality. A lot of times programs will put stuff in the jpg that may cause display problems or file size problems. You should be able to use a fairly big fie. The one I have that is of my dog is 350K and it loaded and displayed fine. I'm fairly good at this stuff and might be able to help you out.
  8. Feb 4, 2015 at 6:05 PM
    #148
    monkiboy
    thanks sir. I saved it at 300dpi and also maintained RGB color coding instead of CMYK which reduces the file size to 150KB or less while preserving the native resolution of the screen size successfully. now it looks great, uploads fine, and most importantly worked. illustrator or PS works great for this. thanks for reaching out sir!
  9. Feb 5, 2015 at 4:30 AM
    #149
    molimelight
    MO
    No problem. Glad you got it working. You could also reduce the size by reducing the dpi to 72 and keep the resolution the same.
  10. Feb 14, 2015 at 1:38 PM
    #150
    Callie
    Callie New Member
    Mark
    Pa.
    15 Trd Sport 4 door long box
    Thanks for info worked fine!!!:)
  11. Feb 15, 2015 at 2:13 PM
    #151
    Neutral
    Neutral Well-Known Member
    Fella
    Alabama
    14 SR5, 25 SR5
    14 4.5" RCD, Pelfreybilt armour, Fox coilovers/shocks, Alcan leaf springs, 4.56 gears, 35's 25 Stock
    Awesome, I finally got it working :cool:
    I used 1280x720 pixels and it looks perfect.
    Man of Steel TRD likes this.
  12. Feb 15, 2015 at 4:12 PM
    #152
    CC7242
    CC7242 Well-Known Member
    Lakeland,FL
    14 Pre Runner SR5
    HAM Radio and Glass Mount Antenna, Plasti Dipped badges
    Mine works, worked on the first try. Pretty sweet!
  13. Feb 15, 2015 at 6:46 PM
    #153
    josh0351
    josh0351 Californication
    Josh
    VA
    Supercharged '13 TRD OR | '96 4X4 Reg Cab (RIP)
    Some stuff...
    No workie on my '13. :(
  14. Feb 24, 2015 at 7:33 AM
    #154
    eazzzley
    eazzzley Active Member
    New Mexico
    TRD Off Road
    My Current Mods Tacoma Floor Mats (Weather Tech) TRD Seat Covers (Red and Black) TRD Shift Knob Blacked Out All Emblems TRD Sport Black Painted Matched Grill BFG TA KO2 265/70r17 Tires TRD Pro Black 17" x 7 Wheels W Black Lugs Blacked-Out Inner Headlight Housing "Tacoma" Bed Mat W Bolt Down (Next) Powder Coated Rear Bumper (Future) Toytec Adjustable Coilovers Set at 1.5" To Level (Future) No Rear Lift Color Match Bushwacker Pocket Flares/Rivets (Future) Smoked tail lights (Future)
    Thank you for the information! :) You rock!
  15. Feb 24, 2015 at 7:37 AM
    #155
    2004TacomaNavy
    2004TacomaNavy Well-Known Member
    Brian
    Oak Harbor, WA.
    04 Extra Cab 4X4 SR5
    All Pro rock sliders, U-Bolt flip kit, Shock mount relocation tabs, All Pro Billy 3" lift front and back, 2014 Tundra Bed Rail tie down system, Fuel 17X8.5 Wheels on 32's, LED front light bar, Raptor style grill W/lights, Tinted Headlights w/LEDs, ARB Dual Air Compressor W/ 2 Gal. Tank, Smoked Tail Lights, Double Din Sat radio w/ back-up camera, Redline Hood Struts, ARB Dual air compressor W/ 20 Gal. air tank, Sig P320C Security System!
    I hope this will work with the new 2016 Tacoma when I get one.
  16. Feb 24, 2015 at 10:23 AM
    #156
    choppersx
    choppersx ZoMbiE aLeRt
    Frank
    SoCal
    1968 Ford Mustang
    Lifted Bilstein shocks 5100's Front set 1.75, Rear set 1.5 ICON 3 Leaf Progressive add on / Lights-Retrofit with Halos & interior Dome / Tinted windows/AFE PRo Dry Air Filter / Go Rhino Bars / Flowmaster Exhaust 50 series
    On these 2014 units maybe already asked but i havent seen in here. Where you insert USB ?
    I might upgrade soon from 2013 to 2014
  17. Feb 24, 2015 at 10:43 AM
    #157
    09 Redneck
    09 Redneck Well-Known Member
    Ga
  18. Feb 24, 2015 at 3:22 PM
    #158
    1eyedjack
    1eyedjack Old Pirate
    Southeast USA
    2014 MGM DCSB TRD Sport Tow
    USB port on lower dash, just above the console. I use mine to hold my music collection for the USB player...
  19. Feb 24, 2015 at 3:58 PM
    #159
    choppersx
    Frank
    SoCal
    1968 Ford Mustang
    Thanks!
    What model touchscreen you have? ive been seeing lots of 57090, and another 57092 with memory card.
  20. Feb 24, 2015 at 4:15 PM
    #160
    1eyedjack
    Southeast USA
    Don't know the actual model number but the dealer print out for my Taco, says Entune Audio Plus. No nav in my audio system...
