How to debadge?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 2011TacoBeav, Aug 30, 2011.
  1. Aug 30, 2011 at 6:47 PM
    2011TacoBeav
    2011TacoBeav [OP] Well-Known Member
    Bret
    Oregon
    2012 Sr5 v6 auto DCSB
    Self made rear bumper Colormatched Bush Wackers CB Center console lock box Camo seat covers Weathertech Digi blk Bilstein 5100s set at .85 Eibach coils LR UCAs Rear 1.5" block
    Hey ya'll! I'm thinking of debadging my black taco and wanting to paint them matte black
    I've seen multiple people mention that they have debadged but was curious if there were any tricks that could help me out before I go tearing into it full steam ahead!?
  2. Aug 30, 2011 at 6:50 PM
    rleeharris
    rleeharris "Old Timer," compliments of 11Taco2.7
    Bob
    San Antonio, Texas
    '11 Tundra Crew Max TRD Off Road
    It will help if you left the truck out in the sun all day to get warm. Loosens the adhesive up a bit.
    Oh, just saw you were in Oregon... never mind.
  3. Aug 30, 2011 at 6:51 PM
    Dibblit
    Dibblit Eh?
    Paul
    Stony Plain
    Truck
    Icon Suspension ARB OBA
    A heat gun.
  4. Aug 30, 2011 at 6:53 PM
    sprocketdog
    sprocketdog Well-Known Member
    Halifax Pa
    05 Taco 96 Taco 06 TSX 94 extra cab Hilux
    DR coilovers, Camburg UCAs, Dakar rear springs, Bilstien 5150s, Demello sliders, rear plate bumper w/ swing gate, and alot more mods. [IMG]http://i1216.photobucket.com/albums/dd368/sprocketdog1/059.jpg[/IMG]
    Just did mine this weekend with a heat gun, fishing string, and a little acetone. Use medium heat, then work the fishing string back and forth. I had to use a little bit of acetone for the buggers that were left over dont go crazy though. Once everything is removed i used some 3M polishing compound then waxed over the areas. They have been on since 05 and you cant even tell (Garage kept so barely in the UV rays so paint is not too faded).
  5. Aug 30, 2011 at 6:57 PM
    sprocketdog
    Halifax Pa
    All acetone does is remove the wax and oils, it is much safer than gasoline and alot faster than goo gone. Used this many of times on many of finishes, just dont use on plastic.
  6. Aug 30, 2011 at 6:57 PM
    2011TacoBeav
    Bret
    Oregon
    Haha! Yeah not a lot of sun, but been working in Medford so its about 90 out!
    Is that 3M tape any good? I hear it is but my only concern would be its thickness and causing the emblem to stick out to where you can see the tape?
  7. Aug 30, 2011 at 6:58 PM
    2011TacoBeav
    Bret
    Oregon
    Anyone use scotch brite or something to assist in adhesion of the paint?
  8. Aug 30, 2011 at 6:59 PM
    2011TacoBeav
    Bret
    Oregon
  9. Aug 30, 2011 at 7:00 PM
    sprocketdog
    Halifax Pa
    Yes just as long as the vehicle has not had alot of sun fade (which causes the breaking down of clear coat) and so you do wax all areas that it has contacted (since the wax will now be gone). Never had any issues.
  10. Aug 30, 2011 at 7:02 PM
    sprocketdog
    Halifax Pa
    If you mean for the badges you will want as much of the chrome finish off as possible or you will run into the chance of the paint not adhering.
  11. Aug 30, 2011 at 7:06 PM
    okboatie1
    okboatie1 Well-Known Member
    Darrell
    Chula Vista, CA.
    03 PreRunner TRD SR5 DCSB
    OME 881's w/Dakar's, Deckplate mod, Debadged, door chime mod, 12V outlets always on,
    Used the old lady's hair dryer. Takes a bit longer than the heat gun, but works. When the fishing line breaks, time to heat it up again. **BE CAREFUL** Only use this method when (insert her title here, wif, GF, ho...) is otherwise incapacitated or personal physical harm can result;). Good Luck!!
  12. Aug 30, 2011 at 7:10 PM
    sprocketdog
    Halifax Pa
    Yes this is correct if you are going to use a heat gun keep on medium heat and dont hold it in one spot for too long. Doing so you could bubble the paint then it is SOL. Becareful in using the old ladies hair dryer as well I burnt up my wifes a couple of years ago and never hear the end of it.:)
  13. Dec 14, 2011 at 9:38 AM
    johnnyman1
    johnnyman1 Well-Known Member
    Jax
    2012 TRD OR PRE
    nerf audio
    Just debadged my '12 magnetic grey truck. Took off V6 & Prerunner. Total breeze. I left the truck out in the sun for two hours before I started. I did not use any heat gun or blow dryer. I found this makes the glue too tacky. You want he glue kind of firm. I first ran fishing line through the badge. Used the same line , 30 test, for all the badges, none broke. Just go slow and saw motion. Once the badge is off , lift one corner of the glue and pull it away at a 45 degree angle slowly. The glue will completely release itself. Don't go more than 45 degrees or it will tear the glue strip. Then I used Orange Glow and in literally 4 swipes,, all residue was COMPLETELY gone. Washed with water and then used Mag's Quick Detailer. No shadow, no residue,, factory look. Anyway,, that was my experience. The key for me was not to heat the badge but just warm it with the sun. That should keep the glue firm enough to work with. The last thing you need is that glue smearing all over the place bc it was overheated.
  14. Feb 12, 2012 at 11:54 AM
    jande016
    jande016 Well-Known Member
    Puget Sound
    2012 Tacoma Auto DC OR SB
    :rofl:
  15. Apr 5, 2013 at 3:38 PM
    Quadmaster96
    Quadmaster96 New Member
    San Diego
    2005 Tacoma Extended cab
    What glue did you use to re install the badges?
  16. Apr 5, 2013 at 4:40 PM
    bullaculla
    bullaculla IKA fabrications
    Da big big island!
    2013 MGM DCSB Tacoma 4X4 TRD Off Road
    All pro 3 link SAS kit, Diamond axle, kings on 37" MTR/K
    X2 :D
    I like to use dental floss instead of fishing line.
  17. Apr 5, 2013 at 5:02 PM
    Markallyn86
    Markallyn86 I like tacos and burritos
    Mark
    Houston, TX /Heights
    Trd sport 4x4 2012
    OME kit 885, LR UCA, XD addict 17's, 265 70 Nitto, ultra gauge, weather tech
    A hair dryer and 20lb fishing line worked great. Once there off use your thumb and the hair dryer to remove excess adhesives then clean with windex or w/e
