How to decide on oem parts
Discussion in '1st Gen. Tacomas (1995-2004)' started by Natenite, Jan 15, 2025.
  1. Jan 15, 2025 at 4:46 PM
    Natenite
    Natenite [OP] Well-Known Member
    Springfield Mo
    2003 Tacoma 4d TRD Radiant Red
    I need to do the timing belt, replace the radiator and apparently replace a pcv valve. I reached out to Joe Joe for a bid and am searching the forums for recommendations. Links can be a bit dated though. When I look at the pricing and parts I get confused real quick. Joe joes bid is way higher than getting a radiator online and getting aircabinmans timing belt kit. But aircabinmans kit is way more than several other ebay sellers with oem parts kits. I have ordered from Joe Joe in the past and it’s been successful but we are talking a few hundred or more dollars difference from the other options. I am not very knowledgeable in this stuff and do not want to buy junk or get an incomplete kit but also need to save $ where I can.
    Any recommendations on how to navigate this? I don’t want to insult Joe Joe but why is he so much higher? Is he accounting for miscellaneous parts that I am not even aware are needed? Do I trust the least expensive eBay oem kit that seems to match the aircabinmans kit? Help??
  2. Jan 15, 2025 at 5:04 PM
    Moonrman
    Moonrman Fix it and it will run
    Hill Country, TX
    2001 Dbl_Cab Prerunner TRD
    That's a good question, ask the sellers! Find the differences. if there's none than see if they will price match. If not than vote your pocket.
  3. Jan 15, 2025 at 6:16 PM
    AW11
    AW11 Well-Known Member
    Frank
    2002 Dbl Cab 4x4 3.4l
  4. Jan 15, 2025 at 6:32 PM
    Natenite
    Springfield Mo
    This is helpful thank you! How do I know which of the timing belt kits to get? Looks like some are for an oil cooler and some aren’t. Or how do I know if I need the one with the hydraulic tensioner?
  5. Jan 15, 2025 at 6:36 PM
    Natenite
    Springfield Mo
    Is there an easy way to know my radiator core size? I see two different options for my 3.4l
  6. Jan 15, 2025 at 6:37 PM
    Moonrman
    Hill Country, TX
    Check and see if you have an oil cooler. It attaches to the water pump on the drivers side with a hose that routes around the oil filter to the oil cooler at the same height as your oil filter but further back towards the back of the engine.
    Natenite[OP] likes this.
  7. Jan 15, 2025 at 6:40 PM
    Natenite
    Springfield Mo
    I meant to say the hydraulic tensioner. I’m guessing all 3.4l have the oil cooler.
  8. Jan 15, 2025 at 6:42 PM
    Moonrman
    Hill Country, TX
    The 3.4 jdm engine I put in my truck didn't have one. I had to install my original.
  9. Jan 15, 2025 at 10:27 PM
    Xperivent
    Xperivent Well-Known Member
    ‘24 Supersonic ORP & '04 Impulse Red DC OR
  10. Jan 17, 2025 at 10:16 AM
    skeezix
    skeezix Well-Known Member
    Colorado
    1998 Limited
    Ten years ago the Aircabinman kit came with new Toyota fan belts and I just didn't install them (MOF I still have them).
    Other than that, if I were to do the water pump and timing belt again, rather than buy from eBay and take my chances with counterfeit parts to save a few bucks, I would just go with Aircabinman again.
