How to determine which TPMS sensor is bad?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 2009Access4x4, Jan 14, 2019.
  1. Jan 14, 2019 at 1:04 PM
    2009Access4x4
    2009Access4x4 [OP] Well-Known Member
    Shane
    2009 Silver 4x4 access cab 6cyl
    Hey everyone,
    I had a tire shop put balancing beads in my tires and it broke one of my tpms sensors. I would like to know which sensor is bad. Does anyone know how you can test or figure out which sensor is bad without buying an expensive reader?
    Thanks!
    Marc70 likes this.
  2. Jan 14, 2019 at 1:09 PM
    Lester Lugnut
    Lester Lugnut Well-Known Member
    N of Mex-S of Canada-E of LA-W of NC
    '15 Tacoma PreRunner V6 SR5 Auto
    Ask the shop that broke your TPMS sensor(s) to determine which is broken. I'm not sure they are liable as I do not know what you mean by "put balancing beads in my tires".
  3. Jan 14, 2019 at 1:13 PM
    2009Access4x4
    Shane
    It was a year ago. They can just say the battery went dead. They offered to fix it last year but I was too nice about it
  4. Jan 14, 2019 at 1:44 PM
    Muddinfun
    Muddinfun Well-Known Member
    Discount tire, and many other tire shops, have a hand held reader thingy that they hold next to the sensor and it reads the ID number of the sensor. Obviously, if it's not working, it's not going to transmit data.
  5. Jan 14, 2019 at 1:58 PM
    spitdog
    spitdog Well-Known Member
    2015 Access Cab V6 4x4 SR5 MGM
    Are they the original ? If so there life is over anyway.
  6. Jan 14, 2019 at 2:13 PM
    QChawks
    QChawks Well-Known Member
    Davenport, IA
    2009 TRD Sport DCLB
    Same thing happened to me last year when I had a shop change a tire for me, although they were adamant they were not liable for any damages
    However, that was easy since it was just one tire. I took Toyota and they tried replacing the battery, no luck. I went ahead and bought a new unit.
    I would take to your local dealer and have they try the same thing.
  7. Jan 15, 2019 at 5:38 PM
    Notoneiota
    Notoneiota Well-Known Member
    Oakdale, MN
    14 Tacoma DCLB TRD Sport
    Mostly stock with a few minor mods.
    Funny enough, I just had one go bad tonight.
    Can someone school me a little on these? Are there batteries that can be replaced? I'm at 100k now. Am I better off buying new sensors all around? And what sensors should I get from where? I'd rather just buy them and take them to a small shop and say, "Please pop these in for me."
  8. Jan 15, 2019 at 5:50 PM
    spitdog
    The mileage is irrelevant, if you own a 2014, you should be getting a little more life. Expect on the average 7 or 8 yrs. Some people even go a lot longer. You may just have a low tire.
    The lithium ion batteries inside TPMS sensors may last anywhere from five to 10 years. Five to six years is a more typical lifespan for older TPMS sensors. TPMS sensors don't broadcast a continuous signal but only broadcast when the vehicle is in motion. Even then, the signal is intermittent to conserve battery life.
  9. Jan 15, 2019 at 5:59 PM
    Notoneiota
    Oakdale, MN
    I checked. They are all dead on for pressure. TPMS light came on while driving home from work. Started blinking and then went solid. I used my gauge to check right away. All were fine. I'm anal about checking weekly. And yes I checked the spare.
  10. Jan 15, 2019 at 6:04 PM
    chucklefunkk
    chucklefunkk Well-Known Member
    So. AZ
    2016 TRD OR
    Avoid the dealer. They've got a long drawn-out expensive process to do this that'll cost you a fortune.
    Discount Tire all the way.
  11. Jan 15, 2019 at 6:11 PM
    08TacoTrD
    08TacoTrD Well-Known Member
    08 TRD Offroad
    I recently had a flat tire(to the rim flat) due to a nail and my tpms light wasn't lit on the dash. Changed to the spare and drove for about 20 minutes before the light came on. Now after putting a plug in the tire and checking the pressure in all tires, the light won't turn off. Guessing one of the sensors is shot.
  12. Jan 15, 2019 at 6:32 PM
    Lester Lugnut
    If you are a Costco customer, buy the sensors wherever you like; then take them to Costco. They will install them for a nominal fee.
    On a side note, I would love to be given the honor of castrating the person(s) who came up with this wallet-lightening idea...TPMS
    2009Access4x4[OP] likes this.
  13. Jan 17, 2019 at 6:30 PM
    Notoneiota
    Oakdale, MN
    Just to update my situation...I took my truck to a shop and they determined I had a bad sensor. A year ago I had a leaky stem and a small time tire shop said they could replace the stem with a rubber one that would attach to the factory TPMS. $20 later I was on the road just fine. Last night the shop said the previous place swapped the whole TPMS out for some shitty little one and now it is bad. So effers took my working TPMS and pulled a switcheroo on me. The shop last night put a new unit in for me but the damn light won't turn off. Any tips? I drove it 50 miles last night at 60mph and a good 60 miles today. They said it would turn off after 20 miles of driving above 20 mph. Not happening.
  14. Jan 17, 2019 at 6:33 PM
    Pushincaskets
    Pushincaskets Well-Known Member
    High Point, NC
    07 PreRunner DCSB
    4" Maxtrac Spindles, Dakars and extra leaf, SOS Concepts bed rack, Lund tonneau cover, RTT,
    Did they remember to properly register the new sensor. Shops forgets a lot.
  15. Jan 17, 2019 at 6:57 PM
    HBMurphy
    HBMurphy Ban Pending
    Paul
    So California Coast
    09 Off Road Delete Model
    None
    Umm, that would be the people who do not like the idea of “live-and-let-live” and are very keen on the idea of writing and instituting laws that will ‘make’ others live the way they think others should live.
  16. Jan 17, 2019 at 6:59 PM
    Notoneiota
    Oakdale, MN
    They said they did. Left it running when they gave it to me and said to drive it until light turned off. Drove 40 miles last night and gave up. I pushed the button under the dash this morning until it blinked 3 times this morning and then drove to work but no dice.
  17. Jan 17, 2019 at 7:48 PM
    Pushincaskets
    High Point, NC
    07 PreRunner DCSB
    That button only resets to my knowledge but does not register, therefore if it is still looking for the old sensor it would continue to flag it.
  18. Jan 17, 2019 at 8:21 PM
    rphillips
    rphillips Well-Known Member
    Rick
    Norene TN.
    2013 Reg. cab 4x4
    none
    Gosh these things are an expensive, aggravating, royal PITA. It sounds like maybe they didn't get your truck programmed to the new sensor. "OR", Just wondering, can two different brand, (unmatched), sensors be programmed to the vehicle at the same time, or do you need a matched set of sensors? If they programmed your truck's computer, to read the new sensor that they put in, maybe the computer is now not reading your orig. 3 sensors.
  19. Jan 17, 2019 at 8:25 PM
    Notoneiota
    Oakdale, MN
    I'll take it back on Monday. They said to bring it back if it didn't turn off.
    Still pissed those ass-hats lied to me and took my OEM sensor. The guy said he was just replacing the valve stem. Sack of poo.
  20. Jan 18, 2019 at 9:14 AM
    QChawks
    Davenport, IA
    2009 TRD Sport DCLB
    that sucks, that is part of the reason I went to the dealership. While I know I probably paid double than another shop, I knew they would get it right and if not would stand by there work.
