How to: Dis-assembling your mirrors for painting
Discussion in '2nd Gen. Tacomas (2005-2015)' started by macgyver, Sep 19, 2010.
  1. Sep 19, 2010 at 8:20 AM
    macgyver
    macgyver [OP] Well-Known Member
    Brad
    Canton, GA
    '13 Tundra double cab SR5 4x4
    So yesterday I finally got around to painting my mirrors and door handles. I have seen threads on removing the door handles so I won't post that part but here is a How-to on dis-assembling your side mirrors so make painting easier. Yes, I could have just masked stuff but it wouldn't have come out as well and you would be able to tell they didn't come from the factory that way.
    Here we go
    Step 1
    Remove door panel (I won't cover this since there are already how-to's on this)
    Step 2
    Disconnect the mirror plug and remove the 3 10mm nuts circled
    Step 3
    Remove mirror and place it on a work surface
    Step 4
    involved remove the outer shell from the plug (the plug won't fit through the holes in the pieces if you don't do this)
    You have to fold back a little tab on the back of the plug then push it through as pictured. It may take a little prying with a tiny flathead screwdriver.
    Step 5
    Remove the plastic "gasket" type piece that goes between the body and the mirror. You have to remove one small phillips screw circled in red
    Step 6
    Remove the cover plate on the bottom of the mirror and remove the 3 T-25 Torx screws you see
    Step 7
    Remove the bracket/hinge thing from the mirror and you will see one more T-25 Torx screw you need to remove
    Step 7
    Remove that metal bracket and you will see a phillips screw under that you need to remove
    Step 8
    Now to removing the actual mirror from the motor and housing. Push the top in, then pull from the bottom towards you, it will unclip then you need to pull it backwards towards you. In the second pic you can see how it hooks on the top and it clips at the bottom
    Step 9
    Remove the 3 phillips screws that attach the motor from the housing. Once you have removed these slide the motor unit out of the housing.
    Step 10
    You are now left with just the housing. I wet-sanded it with 600 grit sandpaper. I used a dawn dish-soap and water mixture to wet-sand since this will clean a lot of the oils off of them. Let them dry
    Step 11
    wipe it down with some isopropyl alcohol to clean any remaining residues off.
    Step 12
    Spray them with an adhesion promoter (Bulldog and duplicolor both make this product, I have used both brands with good luck in the past)
    Step 13
    Spray with a primer. 2 coats allowing proper flash time as labeled) Technically you don't have to do this since the adhesion promoter is a primer. I did this because it for some reason a rock were to hit the mirror and chip the paint, It would show the gray primer instead of the black plastic underneath.
    Step 14
    Spray basecoat (color coat) and allow proper flash time as labeled. I used duplicolor perfect match silver streak mica in a spray can
    Step 15
    Spray clear coat. I sprayed a urethane clear that I mixed and sprayed with my HVLP spray gun. You can use a spray can of clear however I have always had better results spraying clear with my gun. It seems to lay flatter and more evenly.
    Step 16
    Let them dry for about 3 hours then re-install them.
    Here is the finished product, both mirrors and door handles
  2. Sep 19, 2010 at 8:22 AM
    brutalguyracing
    brutalguyracing BIG DADDY
    F.U> GUYZ
    broken mods
    great write up
    thank you
  3. Sep 19, 2010 at 8:25 AM
    Jason'sLawnCare
    Jason'sLawnCare Prepared for Bambi
    Jacksonville Florida
    08 4x4 Double Cab TRD Rugged Trail
    CBI Moab 2.0, CBI Trail Rider 2.0, CBI sliders w/kickout, Superwinch EPi9.0S, OME sport shocks w/886 coils, OME n182, 1.5" aal, JasonBuilt 3/16th full belly skid, BuiltRight uca, Body Mount Chop, 285/75/16 km2's, Rear cat delete, exhaust crossover rerouted, Fog light anytime, Locker mod, Rear leaf tsb, Debadged, Uws Tool Box, Electric Exhaust Cutout, AFE Pro Dry S, Kiwi Wifi, Diff Breather Relocated, Grom Ipod Adapter, Dual Diehard platinum batteries isolated by BlueSea marine switch
    subbed. I may have to do this some day because my mirrors are scratched like crazy.
  4. Sep 19, 2010 at 8:33 AM
    2chains
    2chains Well-Known Member
    Calgary, Alberta
    2010 Tacoma DC LB 3" Revtek lift
    3" Revtek lift, k&n 63-9025 intake, tailgate debadge, OEM Bed mat, decals gone. helo black max 6 bs 4.5 os-12,duratrac 285 70 17,smittybilt light bar, kc slimlites, pioneer pb3300 bt, window tint, weathertech digfits, raider lorider elite tonneau, at2525xl,
    this will come in handy! thanks for posting
  5. Sep 19, 2010 at 11:09 AM
    clintonjeffries
    clintonjeffries Well-Known Member
    Clinton
    Wenatchee, WA
    07 4x4 SR5 super white
    6" stage 1 Procomp lift, 18" matte black XD Monsters, 33" Nitto Trail Grapplers, AMP Research Electric Steps, Grillcraft upper and lower grill, Paint matched tailgate handle, Black headlights w/ black corners & reflectors, 6k HID in heads and fogs, tint, RED badges, red brake calipers, black brake drums, flowmaster exhaust, black shorty antenna, remote start, iPod interface, Weathertech floormats front and rear
    Looks great man! Why didn't you paint the mirror brackets as well???
  6. Sep 19, 2010 at 11:21 AM
    BakoTruck
    BakoTruck Well-Known Member
    Matthew
    Bakersfield, CA
    05 PreRunner TRD
    Cool write up!
  7. Sep 19, 2010 at 11:30 AM
    macgyver
    Brad
    Canton, GA
    The brackets on the sport model aren't painted. I wanted it to look stock.
  8. Sep 19, 2010 at 6:45 PM
    skistoy
    skistoy Make mine a Double!
    Western New York
    09 4X4 SR5 BSP Double Taco
    Rear Spring TSB,Billy 5100@.85,Bull bar,Nerfbar,Painted Grill,Painted Rims,Bed D-rings,Compustar Starter,Goodyear Duratrac's,Transmission TSB,Brake Overide
    Very informative, great write up!
  9. Sep 19, 2010 at 6:50 PM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    great write up dude,nice work
  10. Sep 19, 2010 at 9:19 PM
    pinktaco808
    pinktaco808 Hot Steppa
    what about manual mirror??? anything different or to watch out for???
  11. Sep 19, 2010 at 10:34 PM
    Eurosport
    Eurosport Well-Known Member
    around the world
    i thought you don't have to remove the door panel to remove the mirrors, must have misread another thread?
  12. Sep 20, 2010 at 1:59 AM
    floridaoccifer
    floridaoccifer Civil Servant
    W-O-W... Great Write Up!!!
  13. Sep 20, 2010 at 7:00 AM
    macgyver
    Brad
    Canton, GA
    You won't be able to reach the bottom two 10mm nuts or unplug the harness...unless you have really tiny hands.
  14. Sep 20, 2010 at 10:33 AM
    Eurosport
    around the world
    thank you much appreciated
  15. Sep 20, 2010 at 11:15 PM
    pinktaco808
  16. Sep 22, 2010 at 10:14 PM
    pinktaco808
  17. Sep 23, 2010 at 12:32 AM
    Gitmo
    Gitmo Well-Known Member
    Justin
    Niice, looks great! I will definitely have to do this when I install the heater pads on the mirrors.
  18. Sep 23, 2010 at 11:23 PM
    pinktaco808
    pics man^
  19. Sep 25, 2010 at 4:17 PM
    pinktaco808
    anyone else did this tooo
  20. Sep 28, 2010 at 11:22 PM
    pinktaco808
