How to disable DRLs (Daytime Running Lights) on 2004 Tacoma?
Discussion in '1st Gen. Tacomas (1995-2004)' started by jdm0912, Dec 12, 2009.
  1. Dec 12, 2009 at 1:04 AM
    jdm0912
    jdm0912 [OP] New Member
    04Tacoma
    Hello,
    Just like the title says, I would like to find out how to disable the DRLs (Daytime Running Lights) without doing damage to my 2004 Tacoma. If I can install a switch, that would be preferable, but I would even cut a wire just to disable it, as long as the headlights still worked. I tried just removing the DRL fuse, but that did not work as I believed. Any help appreciated.
    (I only have a schematic from a basic car manual that does not go into detail.)
  2. Dec 12, 2009 at 5:18 AM
    smuook
    smuook Daily Driver "Plus"
    Smuook
    Loganville, GA
    2004 DC V6 PreRunner
    Billy 5100, Satoshi, MBW Wheels, All Pro Front Bumper with 3x PIAA 530, LED dash lighting, other stuff too much to list
    I believe your DRL's are linked to your parking brake. Try this... with your car off, set your parking brake. Then turn your car on and see if the DRLs come on. My bet is that they won't. If that's the case... you want to fool the DRL control relay in thinking that the parking brake is always set (which in actuality, it won't be).
    Find the parking brake switch behind the dash. Should be green w/ white stripe and white w/ black stripe wires. Install a manual switch in parallel with the parking brake switch that will allow you to ground it out and trick it to think the parking brake is set.
    The only caveat to this is that it won't work if the lights are already on. In other words, you have to do it when you start up the car. If you want to test this... with your car on and DRLs on... set the parking brake. It shouldn't turn the DRLs off. This is the same reason that this switch wouldn't disable them once they are on.
  3. Dec 12, 2009 at 10:42 AM
    jdm0912
    04Tacoma
    Thanks, I will look into it and see if the parking brake has any effect.
  4. Dec 12, 2009 at 11:10 AM
    smuook
    Smuook
    Loganville, GA
    Here's is the schematic. On page 3, it talks about the parking break relationship to the DRLs.
    • drl.pdf
      File size:
      50.3 KB
      770
  5. Jan 6, 2010 at 3:55 AM
    matthew5olson
    matthew5olson Well-Known Member
    matthew
    pittsburgh, PA
    04 ext cab 3.4L 5spd 4x4 sr5
    K&N cold air intake, doug thorley headers, rear sensor simulator, flowmaster 40 series, magnecor plug wires, Royal Purple synthetic gear lube, airaid throttle body spacer, Hyperground system, flex-a-lite elec fan.
    Why doesn't mine have DRL. Mine have a cool feature where the headlights turn off when I stop the motor and open the door. But they're not DRL they are the actual headlights. Was this strictly a DC thing?
  6. Jan 6, 2010 at 4:15 AM
    supremetaco2
    supremetaco2 Well-Known Member
    concrete jungle, oahu
    04inacoma
    +hp, lifted, lights, dif breather mod, debadged, shorty antenna...
    finally a response to my question that was posted in the lighting section about a month ago hahaha
  7. Jan 6, 2010 at 4:37 AM
    EnolaGaia
    EnolaGaia Well-Known Member
    Midwest USA
    '01 & '04 S-Runners
    01 SR: Double Cab conversion, S/C, lowered.
    DRL's were an option, not a standard feature, up through 2004.
    The 'light auto turn-off' feature was not a Double Cab - specific thing.
  8. Jan 6, 2010 at 4:44 AM
    matthew5olson
    matthew
    pittsburgh, PA
    It was an option by itself? Or was it only on the limited version. Mine has the light auto turn off and mine's an access cab. This is different from the DRL correct
  9. Jan 6, 2010 at 8:07 PM
    EnolaGaia
    Midwest USA
    '01 & '04 S-Runners
    DRL = Daytime Running Lights (headlights on whenever the truck is running).
    DRL's were a standalone option on 2004 Tacomas. They weren't included or bundled within any other option package.
    The automatic turn-off of lights after the truck is stopped and the door opened is an entirely different feature.
  10. Jan 6, 2010 at 9:22 PM
    david7268
    david7268 Well-Known Member
    Tucson, AZ
    2012 DCLB 4x4 TRDSport
    NONE.....yet!
  11. May 28, 2013 at 6:53 PM
    amp3d
    amp3d Well-Known Member
    Mark
    Toronto
    2002 Double Cab TRD Offroad, 2012 Access Cab
  12. May 28, 2013 at 7:17 PM
    david7268
    Tucson, AZ
    NONE.....yet!
    Under the drivers side dashboard. It is almost directly under the steering wheel and the module is labeled DRL or something close to that. You'll know it when you see it. You don't have to remove anything to get to it.
  13. May 29, 2013 at 5:04 PM
    amp3d
    Mark
    Toronto
    thank you sir!
  14. Oct 24, 2015 at 8:50 PM
    DylansBase
    DylansBase Well-Known Member
    Dylan
    Murfreesboro TN
    2007 DCSB Taco TRD Off-road
    Bilstein 5100 w/OME 886 All pro expo leafs w/icon 2.0 Relentless Fab plate bumper BFG KO2
    Bringing it back from the dead. What connector is this in. Any clearer pics?
  15. Oct 25, 2015 at 9:06 AM
    keakar
    keakar Well-Known Member
    karl
    louisiana
    I really don't get the problem with this? on my 04 there is a completely separate 7 amp fuse for DRL in the fuse box under the hood, remove it and no more DRL.
    why go hacking on wires?
    phattestdude likes this.
  16. Oct 25, 2015 at 8:44 PM
    Sicyota04
    Sicyota04 Slowly but surely.
    Morgan
    California
    04 DC 4x4
    I don't have DRL's on my 04 Tacoma DCSB 4x4. WTH???
  17. Oct 25, 2015 at 8:46 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Is the OP in Canada ? DRL have been the law since the 90's here
  18. Jun 12, 2016 at 2:29 PM
    MrMattGarcia
    MrMattGarcia Member
    SA/CC, TX
    2004 Red Pre Runner TRD SR5
    I did take fuse out of my 04 fuse box under the hood and the DRLs are still there. How did yours work ?
  19. Jun 13, 2016 at 6:17 AM
    keakar
    karl
    louisiana
    did you remove the 7 amp drl fuse? that should do it
    I never disabled mine but I was told by Toyota mechanic I just needed to pull that 7 amp fuse
  20. Jun 13, 2016 at 12:46 PM
    MrMattGarcia
    MrMattGarcia Member
    SA/CC, TX
    I pulled the right fuse according got the diagram on the fuse box and turned on my truck and it still came on
