How to disable hill start assist on 2022 TRD Sport MT
Discussion in '3rd Gen. Tacomas (2016-2023)' started by maboytim, Dec 30, 2022.
  1. Dec 30, 2022 at 7:09 AM
    maboytim
    maboytim [OP] Member
    2022 Tacoma TRD Sport
    I saw this discussed for an earlier year but without an answer. I have a 2022 TRD Sport with manual transmission. Is there a way to disable the hill start assist (where it continues to apply the brakes after you take your foot off the brake pedal)? I don't want to debate the merits of the feature I simply don't like it and want to turn it off. I'm 61 and have driven manuals since I was 16. My last vehicle was a 2019 Nissan Frontier manual which I loved but was totaled when a kid plowed into me texting. I replaced it with the Tacoma because it's the only midsize pickup still available with MT. For the most part I like the Tacoma but I just can't stand the hill start assist. Thanks in advance.
  2. Dec 30, 2022 at 7:20 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    There is no way that anyone has found. I believe it is a function buried in the ABS unit.
    Note that any input from the throttle, the slightest tap that doesn't even raise the revs, will disengage the HSA line lock to the rear brakes.
    There should be a switch to toggle this function. Unfortunately, Toyota didn't see fit to give us that.
    Also, the MT ORs and Pros do not have an HSA function. Likely because they have an entirely different brake system.
    shakerhood likes this.
  3. Dec 30, 2022 at 7:23 AM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    You will need to trade it for an older model truck man. Can't do it without replacing pretty much all the control logic with aftermarket.
  4. Dec 30, 2022 at 7:24 AM
    bcmbcmbcm
    bcmbcmbcm Well-Known Member
    Brett
    22 Barcelona Red TRDOR 6MT worth the wait !! Hang in there !!
    I have a 22 with MT and never noticed hill start assist? How do I see if I have it? Is there a button?
    Hogleg918 likes this.
  5. Dec 30, 2022 at 7:25 AM
    50Buck
    50Buck Living rent free Timmy the Tool's head
    See the bold part of the previous quote.
    shakerhood and tonered[QUOTED] like this.
  6. Dec 30, 2022 at 7:25 AM
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission 5.29 R&P FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Bed Light Kit VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Customized 2WD Low Operable (Switched) Clutch Safety Bypass
    Off-roads and Pros don't have it, Sports do.
    HoppyTaco and shakerhood like this.
  7. Dec 30, 2022 at 7:33 AM
    Horseshoez
    Horseshoez Well-Known Member
    Dale
    Maryland
    I'm in the same boat, I'm in the downslope to 70 and have been driving manual transmissions roughly as long as you; not a fan of the HSA (in my wife's Mazda3 or my TRD Sport). That said, I have noticed some inconsistent application of HSA in the Tacoma, some times it happens, and other times it does not; I have yet to diagnose what I did to either cause it to engage or not.
  8. Dec 30, 2022 at 7:35 AM
    maboytim
    Thanks. I figured the lack of an answer in the earlier thread was a bad sign. I tried releasing it with the gas pedal but it seemed like it took more than a tap which made it worse because then I had to wait for the revs to come back down before releasing the clutch and the truck would start rolling backwards. I'll work on just tapping the gas. I miss my 2019 Frontier it was a joy to drive.
    wrightme43 likes this.
  9. Dec 30, 2022 at 7:38 AM
    eurowner
    eurowner Duke Sky
    Scoty
    FIFY
  10. Dec 30, 2022 at 7:47 AM
    maboytim
    Thanks I got the Sport because I wanted access cab. I see the OR is available in access cab - I wish I had known. I might look into replacing it with an OR.
  11. Dec 30, 2022 at 7:52 AM
    Horseshoez
    Dale
    Maryland
    Before you do you might want to drive an OR; between the two I'd choose the HSA and stiffer suspension of the Sport over the non-HSA with a living room sofa suspension of the Off Road.
    NorrinRadd likes this.
  12. Dec 30, 2022 at 7:54 AM
    RustyGreen
    sleeping in a chair
    2017 AC 4x4 Sport 6M Inferno
    Pavement Princess
    It seems to be "re-settable" (to hold) by a quick firm step on the brake when stopped.
    That said I really don't ever notice it in daily driving.
  13. Dec 30, 2022 at 7:59 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    You're welcome.
    Same here. MT, long bed, and tow package left me with one choice.
    Note that the MT OR only comes in DCSB in the US. ACLB OR is AT only. Canada does get an ACLB MT OR though.
    shakerhood and Junkhead like this.
  14. Dec 30, 2022 at 8:02 AM
    Horseshoez
    Dale
    Maryland
    I live in a reasonably hilly portion of New England so on any give drive I am highly likely to come to a stop at a light where I'm facing uphill; I'll give your suggestion a try and see what happens. :)
    RustyGreen[QUOTED] likes this.
  15. Dec 30, 2022 at 8:18 AM
    Just_A_Guy
    Just_A_Guy Rain is a good thing
    On the hunt
    A truck
    Trading in a truck solely because it has hill start assist is kinda nuts.
    You get used to the function in the vehicle. Every once in a while it kicks in when you’re not expecting and the vehicle will buck a bit because you didn’t give it enough gas. Not the end of the world.
    Tonyr56 and cryptolime like this.
  16. Dec 30, 2022 at 8:23 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    :notsure:
    I'm not interested in trading mine and have 85,000mi of enjoyment. Sure, I wish we had the option of the ACLB MT OR back in 2017. Nothing can be done about that.
  17. Dec 30, 2022 at 8:41 AM
    Just_A_Guy
    On the hunt
    A truck
    Ha, the trading comment was aimed at @maboytim
    tonered[QUOTED] likes this.
  18. Dec 30, 2022 at 8:33 PM
    maboytim
    I don't disagree but it will probably be my last chance to get what I want. As I mentioned I'm 61 and I really expected that my 2019 Frontier would be the last vehicle I would ever buy because I thought MT's had gone extinct. I babied that thing and there wasn't a mark on it until the kid plowed into me. Actually I didn't replace the Frontier directly with the Tacoma - I actually bought a new Ford Ranger. But I absolutely hated the Ranger - and not because it was AT although the I think 10 speed AT was horrible. I had the Ranger just shy of 4 months before trading it for the Tacoma when I learned you could still get MT - but in that case I hated the whole Ranger not just one annoying feature.
    wrightme43, Junkhead and shakerhood like this.
  19. Dec 30, 2022 at 8:43 PM
    maboytim
    Argh. I couldn't get the ACSB MT in Indiana - dealers said availability is by region and you can't get in our region. I had to go to Ohio to get the ACSB. But I don't think I'll be going to Canada though. Thanks.
  20. Dec 30, 2022 at 8:44 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    The problem there is the OR Access Cab is Automatic only, unless you live in Canada.
    Junkhead likes this.
