how to disable parking break DVD safety feature
Discussion in 'Audio & Video' started by tooth sleuth, Oct 1, 2010.
  1. Oct 1, 2010 at 3:40 PM
    tooth sleuth
    tooth sleuth [OP] Well-Known Member
    Ben
    Maine
    Pyrite mica trd offroad
    5100's (front 1.75) all around, rear leaf TSB. Bestop supertop, OEM bed mat. Pioneer 3200 HU, Pioneer GM 9500f amp, Eclipse SC6900 Front, Rear Eclipse 5 1/4, Marv box with Arc 10 sub. Dampened all doors and back wall with BXTII and ensolite, Supertop, blacked out emblems, 2011 grille, bedmat
    On a pioneer 3200DVD HU. So i should run that wire to a 2 way switch connected to the ground? Is this the best way to disable the safety function that prevents you from using the DVD function without the parking break on?
  2. Oct 1, 2010 at 3:47 PM
    jtav2002
    jtav2002 Kenny Fuckin Powers
    Josh
    Reading, PA
    2013 Tundra DBL Cab TRD OR
    Depends on the unit. When I had my Pioneer Avic D3 in my last vehicle you had to both ground the wire that's supposed to go to the parking brake and move the mute wire on the RCA harness to a different pin. Just grounding the parking brake wire would give an error saying the parking brake wire wasn't properly connected. Not sure if it would be the same with yours. Sorry I can't help with that specific unit.
    I didn't really care about the DVD part, I just cared about the fact that the D3 had navigation and I wanted to be able to change the destination without being in park.
  3. Oct 1, 2010 at 4:50 PM
    m3zy6
    m3zy6 Well-Known Member
    Reno, NV
    '17 TRDSport AC 6spd 4x4
  4. Oct 3, 2010 at 6:12 PM
    tooth sleuth
    Ben
    Maine
    So, I grounded one wire and soldered it to one of the poles of a two way switch. I soldered the parking break wire from the wiring harness to the other pole of the switch. When the screen for the HU with the "Don't drive and watch DVD's (whatever it says)" comes up, i flip the switch up down and up. That fixes it. I mounted the switch underneath the dash.
  5. Oct 3, 2010 at 6:14 PM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    So you have to flip a switch every time you turn the car/HU on?? That sounds like a minor annoyance every time...
    And it's brake...
