How to disable TPMS?
Discussion in '5 Lug' started by Midnight Drifter, Nov 3, 2011.
  1. Nov 3, 2011 at 8:39 PM
    Midnight Drifter
    Midnight Drifter [OP] Well-Known Member
    Anthony
    Monroe Twp, NJ
    2TR W/T
    Flowmaster dual exhaust
    Alright, so... basically, I want my TPMS gone. Completely. I'm going to eventually have no less than 3 sets of wheels (One for snow, the other for 'off road' and a highway set for commuting) in my possession for my taco truck and in all honesty, I'd rather not shill out the dough for 8 more sensors. They're NOT cheap.
    And simply staring at that light is an unacceptable answer, too.
    Any suggestions on how to turn the light off, other than taping the IP or ripping apart the IP and desoldering the LED?
  2. Nov 4, 2011 at 6:43 AM
    Simon's Mom
    Judy or Jude :)
    NEK Island Pond VT
    24 Tundra Trd Sport former 13 TRD OR
    Stock for now
    Anthony, if you keep your original wheels and original sensors with a mounted set of tires aired up you will more than likely not ever trigger a tpms light.
    I ran two sets of tires & rims and only one set of sensors (in winter oem steel rims w/ original sensors).
    My summer set had no sensors.
    I never got a light unless I was out of range of the stored tires/rims.
    When that happened, I put a business card on the dash to cover the light. Once back home, the light reset by itself over night.
    It was pretty easy and no extra cost or dash removal.
    G/L
  3. Nov 4, 2011 at 6:55 AM
    TnRedNeck721
    TnRedNeck721 Nick Namer
    Zach
    TN
    07 TRD off road 4WD
    sounds like you could make the PVC tube thing. put them in the tube pressurize the tube and mount ing some wear under the truck. that way one have one set and the light will not turn on. idk how to do it exactly just know about it. maybe search of it or wait for another member that knows about it.
  4. Nov 4, 2011 at 7:09 AM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    Leave the sensors in the set of tires you use most, pull the dash and install a switch for the TPMS light, or just disable the light.
  5. Nov 4, 2011 at 7:51 AM
    TnRedNeck721
    Zach
    TN
    07 TRD off road 4WD
    it’s not a bad idea. but if he has winter tires. than most likely they will be on for a few months.
    i think the pvc pipe mod or what ever it is called. is a good idea for him to look in to. that way they wont ever set the light off. not madder what set of tires be has on.
  6. Nov 4, 2011 at 9:33 AM
    Manwithoutaplan
    ID
    have jerez remove the led :D.
  7. Nov 4, 2011 at 5:38 PM
    Midnight Drifter
    Anthony
    Monroe Twp, NJ
    2TR W/T
    You guys do know TPMS batteries eventually go dead, right? I'd rather toss the whole system. Just like ABS, I wish my truck never came with it.
    I'll probably just desolder the LED, even though I don't really want to.
  8. Nov 4, 2011 at 9:01 PM
    boatswain
    boatswain Well-Known Member
    carl
    palmerton,PA.
    2018 Tacoma TRD Sport access cab, magnetic grey metallic.
    like others mentioned, do the pipe bomb. when batteries go dead, go from there. I did it, and it worked.
  9. Nov 4, 2011 at 9:49 PM
    Wolfrunner
    Wolfrunner Well-Known Member
    Graham, WA
    '04 Tacoma Double Cab SR5
    Grey wire mod, 17" tundra wheels powder coated
    all vehicles made after 2008 are federally mandated to have a tpms system installed on the vehicle. the bad thing is that you cant just remove a part and have the system go away. you would have to disable the light on the dash to get it out of sight. sensors that dont move for a period of time will go to "sleep". after they are reprogramed or woken up they will activate again. the batterys are designed to last 7-10 years.
  10. Nov 5, 2011 at 10:11 PM
    Midnight Drifter
    Anthony
    Monroe Twp, NJ
    2TR W/T
    Probably just going to desolder the LED then. Too bad it's not like on the Yaris, where disabling TPMS is as simple as disconnecting one wire behind the dash and soldering it into another line.
  11. Nov 20, 2011 at 1:27 PM
    jbboater
    jbboater Member
    Behind the air conditioner panel on the dash you will find the ecu for the TPMS. Cut the blue wire, connect the end not on the connector to the red\white wire coming out of the same connector. This will shut the light off for good. This applies +5 volts which is exactly how the ecu shuts the light off. "bama trd" posted great instructions. Since there is 5 volts in the same harness it made it easy. Just did it today to get ready for inspection since my sensors are toast. I believe this works on 07+.
  12. Nov 28, 2011 at 11:47 PM
    scott572011
    scott572011 Well-Known Member
    SCOTT
    SO-CAL.
    THE RELENTLESS PRUIST....
    BF GOODRICH T/A ko, BILSTEIN HDs, AMERICAN RACING RAZOR`S 16X7.5, READYLIFT SST HYBRID LIFT SYSTEMS, ALTEC LANSING AUDIO,DREGS OF THE EARTH SYSTEMS,WOLF EYES,SUREFIRE ILLUMINATION TOOLS,HK-PROTECTION!!. POP LOCK, SHORTY ANTENNA, TACO TENT #3,. NITECORE ILLUMINATION, FENIX FLASHLITES. STILL PROTECTOR`S, FACTORY BED MAT, CUSTOM BED WEB, INTRO-TECH INTRO-GUARD CUSTOM TRUCK COVER, CENTER CONSOLE LOCK MOD, TECH-SHADE M1068, WEATHER-TECH CLEAR-COVER`S, OEM MINI TIE-DOWNS, TRUCK BEDZ AIR MATTRESS EXPEDITION SERIES, McGARD TOUGH NUTS WHEEL LOCK`S, DISABLE SEAT/BELT CHIME MOD, GARMIN GPS, KERSHAW BLADE`S, SKELETOOL, WEATHER-TECH FLOORLINER DIGITAL-FIT GRAY # 461781, NITE(IZE) KNOT-BONE ADJUSTABLE BUNGEE SYSTEM, WET OKole SEAT COVERS, UNDER DASH FLYZEYE BW LED LIGHT W/CUSTOM BLUE HALOS. NITECORE IFE1 INFILUX ILLUMINATION SYSTEM. JETBEAM BC-10 HANDHELD, HK VP-70Z 9mm PROTECTION!. JETBEAM PC-10 550 LUMEN ILLUMINATION SYSTEM. SUREFIRE E2D-LED-DEFENDER ULTRA 500 LUMENS KICK ASS ILLUMINATION...VIPER ALARM SYSTEM`S,ROCKFORD FOSGATE POWER COMPONENT SYSTEM`S.KENWOOD AUDIO/VIDEO,HUSHMAT SOUND DEADENING INSULATION,3M AUTOMOTIVE FILMS.
    nothing a little C-4 plastic explosive wouldn`t :infantry: fix!!!.
  13. Feb 26, 2012 at 10:03 PM
    jdh022764
    jdh022764 Member
    john
    toledo ohio
    if you take your time you can actually pull the wire out of the socket and not cut the wires and then attach them together , that way you can reinstall later and no will will ever know you had your hands in there . i think the ideas that people have on here are great . i still believe you can do the same thing without cutting the factory harness up
  14. Mar 31, 2012 at 11:36 PM
    Midnight Drifter
    Anthony
    Monroe Twp, NJ
    2TR W/T
    Aha! I KNEW that that trick would work, I just didn't know which colors to snip! Considering the Yaris (yes, I know it's built in Japan but most Toyotas are designed around the same basic principle) TPMS system hasn't overgone any changes between 2007 and 2012, I can safely infer that this should also be the case here.
    Well, I'll be putting that theory to the test soon, going to switch over to some new wheels wearing 265-75R16's on 'em. Wish me luck.
    Valhalla18D likes this.
  15. Apr 5, 2012 at 7:45 PM
    Midnight Drifter
    Anthony
    Monroe Twp, NJ
    2TR W/T
    I am so not concerned about cutting wires. :)
  16. Apr 27, 2012 at 12:39 PM
    devrep
    devrep New Member
    florida
    12 acess cab SR5
    how about a small stickyback black dot? peel off the backing and stick on the dash lens right over the light? anyone have any carbon fiber stickyback dots?
  17. May 31, 2012 at 4:27 AM
    JLPruit65
    JLPruit65 New Member
    jbboater I did this on 2011 so it still works great :D I didn't cut the blue wire I got a wire connector to connect two wire together and put a fuse link in system and ran it to the Cig. lighter hot wire and done the same time there.
  18. Jul 28, 2012 at 1:36 AM
    650H1
    650H1 Well-Known Member
    Michael
    VA
    2020 (Cement) TRD O/R
    sub'd
  19. Jul 28, 2012 at 9:48 PM
    Spoonman
    Spoonman Granite Guru
    Jamie
    Alberta
    I hate my light.
  20. Nov 8, 2014 at 1:09 PM
    dirtymike
    dirtymike Well-Known Member
    mike
    orlando fl
    2nd gen
    Fiberglass,spindles, coils, 4"leafs, gears&locker, no skids :-/
