How to disassemble front suspension.
Discussion in '1st Gen. Tacomas (1995-2004)' started by IDtrucks, Jun 8, 2010.
  1. Jun 8, 2010 at 5:45 PM
    IDtrucks
    IDtrucks [OP] Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    Does anyone have a good write up or a semi detailed description to take apart the front suspension to install different coils?
    truck-99 2wd xcab
  2. Jun 8, 2010 at 5:47 PM
    derekabraham
    derekabraham Living vicariously through everybody
    TW'S Hippy Liberal
    Portland, OR
    2002 4x4 4Runner
    Stick on hood scoop from Autozone.
  3. Jun 8, 2010 at 5:48 PM
    derekabraham
    TW'S Hippy Liberal
    Portland, OR
    2002 4x4 4Runner
    :D
    Somebody should help you shortly, I'm just giving you a free bump!
  4. Jun 8, 2010 at 7:25 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Its similar to the second gens, just the ball joint is upside down. 3 nuts on top, a center nut holding the spring top plate on, and 1 bolt on the bottom of the shock.
  5. Jun 8, 2010 at 7:27 PM
    JimBeam
    JimBeam BECAUSE INTERNETS!! Moderator
    JB
    2015 Tundra
    do NOT disassemble the coilover setup without a proper spring compressor
  6. Jun 8, 2010 at 7:30 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Correct.
  7. Jun 8, 2010 at 7:34 PM
    98tacoma27
    Ben
    Not Beech Creek
    pre/4wd 5 lug
  8. Jun 8, 2010 at 9:04 PM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    the car jack method doesent work??
    (putting a car jack under the lca and slowly lowering it)
  9. Jun 8, 2010 at 9:07 PM
    SC4333
    SC4333 Well-Known Member
    Grant
    FL
    SOLD - 2016 TRD Off-Road 4x4 DCSB
    The strut will come out of the truck in one piece, granted you disassemble everything correctly. What tigerfan is saying is do not disassemble the strut assembly without using the proper spring compressors to relieve the tension that is being exerted onto the upper and lower retainers of the strut assembly. If you remove the top plate without using a spring compressor, you will find you're self in the emergency room quite quickly.
    All in all, it is a pretty simple job if you a semi-mechanically inclined. Just read some of the write-ups on here and you should be good to go. The search button is your friend!
