How to disengage 4wheel drive on 04 Tacoma
Discussion in '1st Gen. Tacomas (1995-2004)' started by ohhtenko, Nov 21, 2013.
  1. Nov 21, 2013 at 9:17 PM
    ohhtenko
    ohhtenko [OP] New Member
    Toyota Tacoma
    Drove ~150 miles on 4wheel drive (40-60 mph), ~4-6" of snow on the road. After road cleared of snow, put it in 2Lo. 4wheel drive won't disengage. Tried forward/reverse a lot of times with no luck. Any suggestions. Thanks
  2. Nov 21, 2013 at 9:26 PM
    JLee
    JLee The Man! Vendor
    Jerry
    Benicia, CA
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    First thing take it out of low gear. Shifting into low will put in 4wd. You need to be in high gear to shift back into 2wd.
  3. Nov 21, 2013 at 10:49 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    For the life of me I can't remember having 2-lo. Are you sure you didn't mean 4-lo?
    Do you have automatic or manual hubs?
    I've always had the smoothest disengaing of 4-hi by driving in a straight line at any speed below 50 and letting up on the gas as slid the selector into 2-hi. Slight clunk and the 4x4 light goes off.
  4. Nov 22, 2013 at 7:47 AM
    JLee50
    JLee50 Well-Known Member
    Phoenix
    Stockish 99 4x4 TRD
    ToyTec coilovers
    There is no 2wd low range - if you're having trouble disengaging from 4hi, do what koditten said or shift into 2hi and then drive in reverse for about 15 feet.
