How to: DIY Wedge Camper
Discussion in 'Tonneau Covers, Caps and Shells' started by Ripcord, Apr 15, 2019.
  1. Aug 9, 2021 at 10:00 AM
    #2161
    Afilao
    Afilao Tacoma Driver
    SoCal
    ‘18 MGM DCSB Off-Road 6MT
    I ended up not putting any. Just added silicone
  2. Aug 9, 2021 at 11:28 AM
    #2162
    JMcFly
    JMcFly Well-Known Member
    Central FL
    2012 Tacoma SR5 4x4
    renosauce[QUOTED] likes this.
  3. Aug 9, 2021 at 11:32 AM
    #2163
    renosauce
    renosauce Well-Known Member
    Ill let you know what i hear. I think if they can get it back in stock, ill tell her a few people will be incoming to order it, as i assume if it works good more people would use this as cleaner.
    JMcFly[QUOTED] likes this.
  4. Aug 9, 2021 at 12:10 PM
    #2164
    2ski4life7
    2ski4life7 Well-Known Member
    Seattle WA
    17 DCLB 4x4 TRD Off Road Previously '12 DCLB 4x4 SR5
    Question what’s the opening dimensions of the fixed floor? I’m trying to gauge what size opening to leave for my movable platform. I had 1ft previously but I think it’s a bit too narrow.
  5. Aug 9, 2021 at 1:21 PM
    #2165
    Afilao
    SoCal
    Do you mean the dimension of the hole to get inside the tent? I drew my own panels and I made mine 20" x 49"
    2ski4life7[QUOTED] likes this.
  6. Aug 9, 2021 at 11:06 PM
    #2166
    2ski4life7
    Seattle WA
    Does anyone know if the 80/20 extrusion 3" has the same track separations as the GFC? Curious in buying some GFC brackets to use.
  7. Aug 10, 2021 at 5:23 AM
    #2167
    davzx
    davzx Well-Known Member
    CO
    2007 Tacoma TRD Sport DCLB
    Do you mean the T-slot sizes? From what I understand, GFC’s t-slots are not standard.
  8. Aug 10, 2021 at 10:34 AM
    #2168
    2ski4life7
    Seattle WA
    Yeah I was wondering if I could use their awning mount and put it on the 8020 extrusions. I can't find any other awning mounts that will work currently without fabricating.
  9. Aug 10, 2021 at 5:37 PM
    #2169
    Bassshreddin
    Bassshreddin Well-Known Member
    Wes
    2019 Tacoma trd off-road
    RLD canopy, icon stage 1 lift.
    Having issues on the side and rear panels. I used similar hinges to ripcords idea and they work. My problem is that when the side tubes connect to the upper and lower frame, it creates an unwanted angel. With that angle there is now a huge gap at the top, between the panel and spaceframe. Sure I can put more weather stripping, but for security, it's not an option. Either I have to find another way, or just do without and sell what iver got into it so far. This was the easy part....along with waiting on the sewing of tent. Literally all that's left. Sad sad day. Just getting so frustrated. Seems like I get so close and then a slap in the face.
    I don't think it was mentioned in the beginning of the thread whether or not it was an issue for anyone.
  10. Aug 10, 2021 at 5:42 PM
    #2170
    JMcFly
    Central FL
    2012 Tacoma SR5 4x4
    care to share a picture of the issue?
    Bassshreddin[QUOTED] likes this.
  11. Aug 10, 2021 at 7:56 PM
    #2171
    Bassshreddin
    Wes
    I feel as though I did something wrong with the space frame. But I measured and cut to spec and measured 5 or 6 times before and after cuts and welds. There's just an overlap. I can compensate with more gasket, but anyone could break into this. And I can't mount flush because I don't want to drill holes and just use rivets
  12. Aug 10, 2021 at 7:57 PM
    #2172
    Bassshreddin
    Wes
    At this point it's either figure a way out, weld tabs etc, or find a way to mount directly. Just worried about water intrusion with so many rivets into the spaceframe
    I'm wondering if I mount the panels to the inside of the hinge if it will make a difference, but then I will run into binding there as well I'm sure
  13. Aug 10, 2021 at 11:48 PM
    #2173
    nanserb
    nanserb Well-Known Member
    Elliott
    2019 ZR2 Colorado
    Some people have stepped up to the next size gasket for that same reason
    Bassshreddin likes this.
  14. Aug 11, 2021 at 6:13 AM
    #2174
    Afilao
    SoCal
    I feel like it doesn’t matter which bed cap or tonneau cover you have if someone wants to get in they can. Unless you have something like a diamond back
  15. Aug 11, 2021 at 6:56 AM
    #2175
    Bassshreddin
    Wes
    I ended up adding some extra gasket in the corners and it seems to seal, but not as uniform. Basically it starts to push out on the panel corners, vs actually sealing
  16. Aug 11, 2021 at 7:53 AM
    #2176
    nanserb
    Elliott
    2019 ZR2 Colorado
    Someone posted the link to the taller seal a few pages or so ago. You might try that, even if it's just 10'.
    There's 3/4" and then 1" heights. You may even try using some of the double bulb seal on one side to mate with a single bulb seal on the other when the door is closed.
    Otherwise, maybe make a small filler ramp for that area and weld it in, and grind it smooth.
    Your panel really seems to be bowing out in those corners though, you might swap to a piano hinge to bring it in at the corners
  17. Aug 11, 2021 at 8:18 AM
    #2177
    Labbi85
    Labbi85 Well-Known Member
    Exactly, when someone wants to break in they can, no matter how flush the panels are.
    I have the same “issue” and just put a seal on the panel and one on the frame amd this keeps the water out…so for me all is good.
    When you want to have it break in safe, then you have to use different stronger/heavier materials and probably also use different locks, which don’t have the same keyway like every other lock.
    Rando_lurker and Bassshreddin like this.
  18. Aug 11, 2021 at 8:50 AM
    #2178
    Afilao
    SoCal
    I had the OEM tonneau cover and even though it was a tight seal I never left anything that I was worried of being stolen. It was just one crowbar away.
  19. Aug 11, 2021 at 9:32 AM
    #2179
    Bassshreddin
    Wes
    Thanks for the info! Will Def rework this and come up with a solution. Was just getting frustrated.
  20. Aug 11, 2021 at 10:17 AM
    #2180
    Bassshreddin
    Wes
    Just ordered 6mm dibond panel for the sides now. Going to use a router for the slight angles, then mount the panel hinges to the 8020. This way there is absolute flush mount
