How to: DIY Wedge Camper
Discussion in 'Tonneau Covers, Caps and Shells' started by Ripcord, Apr 15, 2019.
  1. Dec 12, 2021 at 12:24 PM
    #2461
    renosauce
    renosauce Well-Known Member
    Finally got it on the truck!
  2. Dec 12, 2021 at 12:46 PM
    #2462
    Taco Camper
    Taco Camper Well-Known Member
    This is the first version of how I held the bed platform in place up front. It basically is just sitting in an aluminum U channel/L angle setup with the gas struts pushing it firmly in there (lower pic) and disconnected and pulled back a bit (upper pic). It only pivots about 40 deg so this works ok for now. I want to create something a bit more robust later that will be a two long hinges fixed to the black lower cross beam and bed platform which is a few inches back from the very front. I am taking all this apart and applying sealant this winter (I never sealed it when I built it).
  3. Dec 12, 2021 at 12:55 PM
    #2463
    Taco Camper
  4. Dec 12, 2021 at 1:01 PM
    #2464
    dherring256
    dherring256 Well-Known Member
    Daniel
    04 Taco, 18 Thundra
    beautiful man. I want to do this so bad, just dont have the garage space to really do any of it.
  5. Dec 13, 2021 at 1:17 PM
    #2465
    Pickup90
    Pickup90 Well-Known Member
    North Carolina
    09 DCLB TRD Sport
    I wussed out on the new truck build, I just bought one. Wanted some more space than the taco. Fitting 37s with no trimming is nice as well! I learned a whole bunch building the first one and was super thankful for this thread! Luckily the taco is still in the family and I have visitation rights.
  6. Dec 13, 2021 at 4:21 PM
    #2466
    jjnicolas
    jjnicolas Well-Known Member
    JJ
    NorCal
    19 trd off road DCLB
    @Pickup90 if there's ever a second time around for me, I'm getting a super pacific lol. Nice rigs btw
  7. Dec 14, 2021 at 3:38 PM
    #2467
    gnardoggie
    gnardoggie Well-Known Member
    I have a level similar to what you posted. You can generally see/feel how level your are then I hop out and refine.
    Your post has inspired me to hunt for something wireless - maybe bluetooth or something so you can check it from your phone while in the driver's seat.
  8. Dec 14, 2021 at 7:13 PM
    #2468
    nanserb
    nanserb Well-Known Member
    Elliott
    2019 ZR2 Colorado
    Simple hinges attached to the space frame with rivets. The weight of the platform is held up by angle inside the frame for when you're sleeping.
    3GQNlwQvxGad8a5EZQj5SnpAEn7OXlKTz74onA9Y_86533e6c74183e7897a002a4f78cb671a435abd0.jpg
    franzgod[QUOTED] likes this.
  9. Dec 15, 2021 at 5:33 AM
    #2469
    Mdlow
    Mdlow New Member
    Beater taco
    Stock really
    This is one of the best I’ve seen. Such an inspiration as well great job man! I am thinking about doing this for my Sequoia but making it an enclosed piece without the truck camper obviously. I search the 8020 website and thinking I could use the ready frame tubing for the base instead of the honeycomb aluminum and it would bolt direct to the extrusions. I’ve been chewing on how to do the bottom and that seems like a good method, any thoughts are appreciated.
  10. Dec 16, 2021 at 9:41 AM
    #2470
    NotTaco
    NotTaco Active Member
    Missoula, Montana
    2013 Nissan Frontier
    We'll be looking forward to your status report on the inverted hinge method, after some field testing and rain.
  11. Dec 18, 2021 at 11:33 AM
    #2471
    renosauce
    Are you talking about the table? I have a rain gutter for the top, as well as weather sealing that seals it right up..
  12. Dec 19, 2021 at 7:28 AM
    #2472
    mjshield2
    mjshield2 Member
    Bainbridge Island, WA
    2010 v6 access cab
    After adding 4.5 rail for more space to close up my bedding and add some roof insulation, I've ran into some water issues... sweet. So I've broken it down and started repainting, I'll start posting progress photos once I have some, just grinding off all the old paint now. Since there are so many joints it will still be tough to get complete water seal. Here's my current plan for waterproofing/rebuild if anyone sees anything to add or maybe it will also help someone get the juices flowing. I've had it for a year and took some short cuts, so no more messing around.
    A big question I could use some help is sealing the wedge when it's closed. I used the push it bulb seal which worked as well blind seeing eye dog. I then used this https://www.mcmaster.com/93085K365/ it works for water and dust, but it makes the wedge close at angle, and I have to adjust where the rain skirt is on the end so it actually repels rain... Not the end of the world but my OCD doesn't approve. Any thoughts/suggestions would be appreciated
    1. For all the Frame to extrusion, extrusion to alupanel, and extrusion to extrusion connections, I've decided to go with running 2 strips of butyl tape along the whole connection. Then use silicon to seal all connections inside and out.
    2. Grind down the corners of the internal and external connectors so I can use silicon to seal the interior and exterior 90 degree joins.
    3. At the end of each rail behind the external connectors, use a piece of gorilla water tape to combat water getting into the extrusion channels.
    4. For the hinges, copy your method using some of vinyl tent to gorilla glue to my continuous gear hinges. I have to use spacers so it doesn't hit my extrusions, also will use silicon on those connections.
    5. Did I mention using silicon to seal everything yet?
    6. Position rain skirt higher on tent.
    7. When reconstructing my frame, I am done fighting the nots seizing up and I'll have to do a lot alone which means I invested in some of these bad boys https://www.mcmaster.com/47065T229/
    8. I've also decided to go with a more fun paint scheme since my old one was real boring.
    if you read this far... thanks.
  13. Dec 19, 2021 at 9:15 AM
    #2473
    davzx
    davzx Well-Known Member
    CO
    2007 Tacoma TRD Sport DCLB
    T-Nutz sells those roll-in spring leaf nuts for way cheaper. I’ve been using them for my exterior mounted accessories.
    https://www.tnutz.com/product/dl-015/
    mjshield2[QUOTED] likes this.
  14. Dec 19, 2021 at 7:32 PM
    #2474
    Bassshreddin
    Bassshreddin Well-Known Member
    Wes
    2019 Tacoma trd off-road
    RLD canopy, icon stage 1 lift.
    What has everyone been doing to insulate the bed?
  15. Dec 19, 2021 at 8:14 PM
    #2475
    nanserb
    Elliott
    2019 ZR2 Colorado
    Diesel heater with quick connects to the camper, no insulation needed IMG_20211214_172931_946.jpg IMG_20211214_172931_886.jpg IMG_20211214_172931_987.jpg
    royfra, mjshield2, Salokin315 and 4 others like this.
  16. Dec 19, 2021 at 8:23 PM
    #2476
    YamaDirtrider
    YamaDirtrider Custom bumpers @FORT-ifyRigs
    Josh
    Elizabeth CO
    06 DCLB sport postrunner
    What hasn't been modified?
    I’ll second a diesel heater. I used a 5kw which was too much in a rtt. But the 2kw will be built into the side of the bed.
  17. Dec 19, 2021 at 10:11 PM
    #2477
    Sub_Par
    Sub_Par Well-Known Member
    Buffalo NY
    2011 TRD Off Road
    Is that a dust collector disconnect? Do you have a cap for if when not in use?
  18. Dec 19, 2021 at 10:17 PM
    #2478
    nanserb
    Elliott
    2019 ZR2 Colorado
    Sub_Par[QUOTED] likes this.
  19. Dec 20, 2021 at 9:18 AM
    #2479
    davzx
    CO
    Got a Bed Rug. Sooo nice to walk around/crawl on, and it insulates the floor a bit.
  20. Dec 20, 2021 at 9:24 AM
    #2480
    2ski4life7
    2ski4life7 Well-Known Member
    Seattle WA
    17 DCLB 4x4 TRD Off Road Previously '12 DCLB 4x4 SR5
    Is your camper sealed fairly well? I've been debating doing this route but since living in the PNW, I still get a little bit of water intrusion when it pours for hours straight.
