How to: DIY Wedge Camper
Discussion in 'Tonneau Covers, Caps and Shells' started by Ripcord, Apr 15, 2019.
  1. Jan 14, 2022 at 6:26 PM
    #2561
    NotTaco
    NotTaco Active Member
    Missoula, Montana
    2013 Nissan Frontier
    As a dude with a short garage door as well, I would look at engineering a lift mechanism/dolly to load the wedge camper on and off the jeep rather than over-engineer the camper to fit the short garage. Simple is better. I lucked out, the weight of the camper pushed the truck down just enough to squeeze through the garage door, in my case. I didn't account for the added height of the seals, don't do what I did. It almost didn't fit back in the garage. There are camper jacks available for slide in campers, you might look at the mechanisms in those and build a version for yourself. I considered this option.
    JD112 likes this.
  2. Jan 14, 2022 at 7:01 PM
    #2562
    Rando_lurker
    Rando_lurker Member
    2006 Tundra DC
    Interesting concept! I love the cardboard aided design! With these types of projects, it’s so much easier and faster to figure stuff out with prototyping like this. For a departure like this, I’d recommend making a moving proto in wood/scrap including hinges and tent. Tent could be cheap fabric scraps and duct tape. This will help find and fix issues with opening, closing, stability, etc.
    Feedback: i think your approach seems good for the constraints you have. If you’re sure you have to put it in the garage then it’s worth working around. And I really like trying novel solutions. Based on your proto and CAD work I’d guess you can make this basic concept work.
    One area that stands out to me is stability of the pop up area. If you cant sleep in the bed, you have to deploy the tent regardless of wind/weather. So you want that top to be stable and quiet in the wind. The main pivoting top looks ok. I think you could build that similar to these wedges - simple hinges and gas struts. The smaller fold out section may need some rigid elements in the tent to keep it tight and quiet. Maybe a U shape tube that follows the thin black lines in your CAD and goes through the tent at that edge to keep the two connected. That could pin to the frame with removable pins. Or maybe a U shaped tube through the tent connected to two gas struts where you show thin lines. I’d also consider something to preload and support the little fold out platform. The tent and U tube could probably hold it up, but then it can swing around when the tent loads with wind. Also could be something like drawer slides.
    I’d consider making the top wrap around all your other mechanism and seal interface. This can “shingle” water off of everything and avoid driving rain in the seal. That way you don’t have to worry about sealing the areas around the little platform when it’s folded closed.
    I’d consider a polyester based tent fabric over nylon. Nylon relaxes when wet so the tension in your tent drops and it can flap or sag and pool water.
    another option could be a full flip over. Flip pac goes forward which wouldn’t work here because of the required height. AT habitat goes back. And wildernest goes sideways. Would give you more space up top, but tent is more complicated to build and you have less hard roof when deployed.
    another idea is to make the roof with only two planes (current is three). You might be able to work that out with two panels for the roof and only have tent on the sides. Somehow i feel like it wouldn’t be worth doing three panels and two hinges, but 2 and 1 might be ok.
    This is rad and I hope you do it! Keep us posted as you make progress!
  3. Jan 14, 2022 at 7:12 PM
    #2563
    SloW8
    SloW8 Member
    One of the Other Guys
    37s, 2" lift
    Thanks for your feedback, appreciate the thoughtful advice.
    I am working on a prototype and was pretty happy with my initial pass. Have made a few mods since then (hoop bit) that I will try out tomorrow. I will re-read your thoughts after this wine dissipates….
    JMcFly and davzx like this.
  4. Jan 15, 2022 at 6:43 AM
    #2564
    Pj40
    Pj40 Well-Known Member
    Washington
    I think every wedge will be slightly different in exact height when closed. Definitely go with what youre measuring looks like 1.5 is perfect!
    nanserb[QUOTED] likes this.
  5. Jan 15, 2022 at 8:32 AM
    #2565
    Brushape86
    Brushape86 Active Member
    Sonoma, Ca
    Has anyone tried making the front and back doors entirely from lexan vs composite with a window of lexan
  6. Jan 15, 2022 at 1:12 PM
    #2566
    Sub_Par
    Sub_Par Well-Known Member
    Buffalo NY
    2011 TRD Off Road
    Strength and security would be the biggest issues I could see. What would be the benefits, price?
  7. Jan 15, 2022 at 1:25 PM
    #2567
    Brushape86
    Sonoma, Ca
    Lexan is very strong and easy to work with. The the visibility would be the main benefit. The back window of every camper I’ve ever had has been solid glass and I’ve never had a security issue
  8. Jan 15, 2022 at 1:35 PM
    #2568
    Sub_Par
    Buffalo NY
    2011 TRD Off Road
    Its easier to scratch than glass though, so the visibility wont be as good once its got some branch damage. Might not be an issue with the back door though since most branches are hitting the sides of the camper. I know lexan is strong, I just would be concerned about mounting latches and the struts to it, I mean you have to brace the aluminum so it might end up the same. Do they make tinted lexan or can you tint it for security?
  9. Jan 15, 2022 at 3:49 PM
    #2569
    Brushape86
    Sonoma, Ca
    Tap plastics formed me a tinted lexan windshield for my center console boat and it’s very rigid and pretty affordable. It does scratch though that’s for sure
  10. Jan 16, 2022 at 3:58 PM
    #2570
    dually
    dually Low and slow
    Interstate underpass
    '16 Inferno SR5 DCLB
    Front window in
    Squatting Pigeon likes this.
  11. Jan 17, 2022 at 12:27 PM
    #2571
    LeeV1992
    LeeV1992 Member
    Lee
    North Carolina
    2015 Black Tacoma TRD Sport Double Cab
    I had the same issue when I was ordering my extrusions last year. Originally ordered black but the wait time was way too long from 8020 so I ended up canceling the order and ordering the normal silver colored ones. Showed up in roughly 1.5 weeks and were cheaper. I think they look good
  12. Jan 17, 2022 at 12:38 PM
    #2572
    SloW8
    SloW8 Member
    37s, 2" lift
    Good feedback. I thought of a jack and a rack etc... but that is just as much engineering and hassle as doing a double fold in my opinion. Plus, I would need to unload and load it every time I use it and I really want to do lots of 2-3 day runs out into the desert this year and be able to quickly leave and quickly unpack. Having to spend an extra 30-60 minutes at the beginning and end of each trip is more than I am looking for.
    I have my design pretty dialed in and it seems like it is going to work without a lot of extra hassle, one more step than the simple wedge. And since this is for a different truck, I had to re-design it all anyway. I have been enjoying the problem solving of it all.
    Really appreciate your posts and thoughtful design ideas. I have several of your posts in the thread bookmarked.
    NotTaco[QUOTED] likes this.
  13. Jan 17, 2022 at 8:54 PM
    #2573
    nanserb
    nanserb Well-Known Member
    Elliott
    2019 ZR2 Colorado
    Talked to discount rubber, they recommended EPDM for UV stability and flexibility. Ordered a 30' roll of 1.5" total cost was $55 shipped.
  14. Jan 20, 2022 at 1:14 PM
    #2574
    2ski4life7
    2ski4life7 Well-Known Member
    Seattle WA
    17 DCLB 4x4 TRD Off Road Previously '12 DCLB 4x4 SR5
    why not go 1.25”? I see 1.5” on your photo overlaps a bit of the channel.
  15. Jan 20, 2022 at 1:26 PM
    #2575
    Pj40
    Washington
    Again everyone's build will be slightly different. Do what you think is best for your wedge and what you think looks good
  16. Jan 20, 2022 at 4:46 PM
    #2576
    dually
    dually Low and slow
    Only some gravy work left on the shell, then on to the wedge!
    NotTaco likes this.
  17. Jan 20, 2022 at 5:06 PM
    #2577
    jowybyo
    jowybyo Well-Known Member
    Joe
    Baltimore, MD
    '14 MGM DCSB Postrunner 4wd Conversion, Debadged
    That looks awesome. It’s all aluminum? Any idea how much it weighs?
  18. Jan 20, 2022 at 5:09 PM
    #2578
    dually
    dually Low and slow
    Yep, all aluminum 6061 for structural and 5052 for the panels. I think this should be around 150lbs as you see it.
  19. Jan 22, 2022 at 7:32 PM
    #2579
    nanserb
    Elliott
    2019 ZR2 Colorado
    I'm sure 1.25" would be fine, I just wanted a tad extra. I may trim it myself when it gets here.
  20. Jan 26, 2022 at 3:23 PM
    #2580
    Brushape86
    Sonoma, Ca
    Does anyone have the jig for the space frame available in Northern California ?
