How to: DIY Wedge Camper
Discussion in 'Tonneau Covers, Caps and Shells' started by Ripcord, Apr 15, 2019.
  1. Feb 9, 2022 at 7:48 AM
    #2641
    nanserb
    nanserb Well-Known Member
    Elliott
    2019 ZR2 Colorado
    Yeah!
    A couple of spots have lifted a little because of the hinges or the roof rack brackets, I'm guessing that if I ever silicone the top lip of the EPDM it'll help with that. For now I just am using a 1/2" 3M tape.
  2. Feb 9, 2022 at 8:25 AM
    #2642
    2ski4life7
    2ski4life7 Well-Known Member
    Seattle WA
    17 DCLB 4x4 TRD Off Road Previously '12 DCLB 4x4 SR5
    Did you install the rubber under the hinges or cut at the hinges? I just got mine so will be installing this weekend
  3. Feb 9, 2022 at 1:59 PM
    #2643
    Clamber247
    Clamber247 2004 Tacoma
    Boise, ID
    I'll have to dig up the photos, but essentially removed all the curved portions of the roof and made the rear a 1.5x1.5 instead of rectangle and drilled up through the aluminum and attached with bolts and the slide nuts in the underside of the track. Then had the wedge roof like everyone else's. I did have a brace across the front of the shell to attach too.
  4. Feb 9, 2022 at 2:08 PM
    #2644
    jowybyo
    jowybyo Well-Known Member
    Joe
    Baltimore, MD
    '14 MGM DCSB Postrunner 4wd Conversion, Debadged
    What did the dimension from the bed to the 80/20 end up being? Also what is the width to the inside of the 80/20 (the sleeping width)?
    Sub_Par likes this.
  5. Feb 9, 2022 at 3:28 PM
    #2645
    Sub_Par
    Sub_Par Well-Known Member
    Buffalo NY
    2011 TRD Off Road
    Any interior pics? Did you need to brace any other areas besides the front?
  6. Feb 9, 2022 at 3:45 PM
    #2646
    Clamber247
    Boise, ID
    Between the 80/20 is 50"
    Bed to bottom of 80/20 is 37.75"
  7. Feb 9, 2022 at 3:49 PM
    #2647
    Clamber247
    Boise, ID
    Nope no other photos of the interior, if I get a chance to open it up in the daylight, I'll grab some.
    I have a brace going across the roof in the middle, not sure it's needed, but nice to hang a lantern off of. The from overhang has rigid foam the same depth as the crossbar and the bed slides over. The foam is backed with carpet so that's where my feet are.
    Sub_Par[QUOTED] likes this.
  8. Feb 9, 2022 at 5:38 PM
    #2648
    demo243
    demo243 Well-Known Member
    Devon
    Topsfield MA
    2015 DCLB TRD 4x4
    @Clamber247
    Thanks! Just what I wanted to see!
    Would love to see more interior photos too
    Now I just need to find the right DCU cap. Found one a few hours away for a decent price, but it doesn’t have any side windows. Having slept in my current leer I think I would really miss not having them.
    Sub_Par likes this.
  9. Feb 9, 2022 at 7:22 PM
    #2649
    JD112
    JD112 New Member
    JD
    I was just curious if anyone has designed/built a way to take their wedge off like a slide in camper with jacks or something else? Not lifted to a ceiling.
    Pictures if you have them. Thanks.
  10. Feb 10, 2022 at 5:45 PM
    #2650
    jowybyo
    Joe
    Baltimore, MD
    Has anyone done anything clever to make the wedge portion removable? It would be cool to be able to remove it quickly and replace with a normal roof panel.
  11. Feb 10, 2022 at 5:51 PM
    #2651
    demo243
    Devon
    Topsfield MA
    2015 DCLB TRD 4x4
    Could just make second 8020 panel to to drop on. Would be a hassle having to undo all the bolts and lift it off, drop the other on and bolt em back down… but if you used bolts in the 8020 track that drop down through the frame it probably wouldn’t be too bad.
  12. Feb 10, 2022 at 5:55 PM
    #2652
    jowybyo
    Joe
    Baltimore, MD
    My first idea was to rimmed the top of the frame with 1.5”x1.5” 8020 then latch the wedge to that. Maybe you have to bolt the wedge to frame 8020 but the few brackets with face bolts would be easier to access.
  13. Feb 10, 2022 at 6:26 PM
    #2653
    Sub_Par
    Buffalo NY
    2011 TRD Off Road
    My first thought would be sealing it up, you could use bulb seals, but they don’t hold up well to repeated uninstall reinstall.
  14. Feb 10, 2022 at 6:29 PM
    #2654
    jowybyo
    Joe
    Baltimore, MD
    What about the same seal that is being used to seal between the two halves of the wedge.
  15. Feb 10, 2022 at 6:30 PM
    #2655
    Sub_Par
    Buffalo NY
    2011 TRD Off Road
    Yea I don’t see why it wouldn’t work, idk that anyone has any long term testing yet on their wedge to see if it’s still holding up well.
  16. Feb 10, 2022 at 6:33 PM
    #2656
    jowybyo
    Joe
    Baltimore, MD
    If it does leak it would be leaking below the wedge so I’m not was worried about a tiny bit of water entering as long as my bedding/mattress isn’t getting wet.
  17. Feb 10, 2022 at 6:48 PM
    #2657
    demo243
    Devon
    Topsfield MA
    2015 DCLB TRD 4x4
    I was thinking the same thing after my last post. Permanently mount a section of 8020 and then mount the wedge to it, only catch there is you would probably still need a 2nd “panel” to be your topper. That way your always latching 8020 on with either the blank top or the wedge. A latch may not be strong enough but a couple plates might do the trick
  18. Feb 10, 2022 at 6:50 PM
    #2658
    demo243
    Devon
    Topsfield MA
    2015 DCLB TRD 4x4
    But with all that said, I’m more likely to just hang onto my current cap so I could take the whole wedge off and just throw my leer back on… but I’d probably be to lazy to due that…
  19. Feb 10, 2022 at 6:55 PM
    #2659
    jowybyo
    Joe
    Baltimore, MD
    Right. I was thinking of making a 2nd panel that is just a roof for the frame without the wedge.
  20. Feb 10, 2022 at 6:59 PM
    #2660
    demo243
    Devon
    Topsfield MA
    2015 DCLB TRD 4x4
    that’s probably the easiest and fastest way.
    you might be able to get away with a cork seal “permanently” mounted on the extrusion attached to the space frame for sealing it.
    just gotta figure out the fastest and most secure to swap them out
