How to: DIY Wedge Camper
Discussion in 'Tonneau Covers, Caps and Shells' started by Ripcord, Apr 15, 2019.
  1. Feb 20, 2022 at 10:46 PM
    #2701
    bot102
    bot102 The guy who ask a lot of questions
    Alec
    Castle Rock, CO
    2017 DCOR
    Beat up armor and broken stuff
    Welp guess I'll need to hop on the rubber trim train. Went camping this past weekend, opened up my wedge and found the mattress soaked
  2. Feb 21, 2022 at 12:10 AM
    #2702
    jowybyo
    jowybyo Well-Known Member
    Joe
    Baltimore, MD
    '14 MGM DCSB Postrunner 4wd Conversion, Debadged
    Why are so many having this issue now? Earlier in this thread it seemed like the bulb seal was enough to seal when the wedge was closed. @Ripcord, along with others, mentions that they had no water intrusion.
  3. Feb 21, 2022 at 5:17 AM
    #2703
    davzx
    davzx Well-Known Member
    CO
    2007 Tacoma TRD Sport DCLB
    Yeah I haven’t had any water intrusion in the wedge portion either throughout the CO winter. I’ve opened it up many times to check and it’s been dry. Not sure exactly why some do and some don’t, I don’t think I did anything different.
  4. Feb 21, 2022 at 7:47 AM
    #2704
    Sub_Par
    Sub_Par Well-Known Member
    Buffalo NY
    2011 TRD Off Road
    My guess is just user error, I mean every one of these is going to be slightly different so things can be shifted or hinges can not be as tight as others.
  5. Feb 21, 2022 at 9:18 AM
    #2705
    bot102
    Alec
    Castle Rock, CO
    2017 DCOR
    It's hit and miss. Honestly couldn't tell you how it got it. It was fine the last 8 months lol
    Sub_Par likes this.
  6. Feb 21, 2022 at 9:43 AM
    #2706
    nanserb
    nanserb Well-Known Member
    Elliott
    2019 ZR2 Colorado
    If you notice all three of us live up in Washington where it's wet 8 months out of the year, likely has something to do with it
    Bedawson and Sub_Par like this.
  7. Feb 22, 2022 at 1:34 PM
    #2707
    chequamegon
    chequamegon Well-Known Member
    Tim
    Minneapolis, MN
    2013 Super White DCLB
    White DCLB w/ Fox 2.5 Adj Resis, 32" Duratracs on TRD 17s, SuperPacific camper, 4.56 Nitros, ARB Front bumper, CBI rock slides, dual rear swingout rear bumper, solar, fridge, electrical
    Dang, so many of these are looking really refined!!!
  8. Feb 22, 2022 at 4:54 PM
    #2708
    jowybyo
    Joe
    Baltimore, MD
    What is everyone doing to finish the cut edge of the ACM roof and floor?
  9. Feb 25, 2022 at 6:23 PM
    #2709
    10degnorth
    10degnorth Member
    I want to share the camper design I've been working on. It is basically a slide in style Ripcord camper. It has a floor to it so it can be jacket up and taken off pretty easily. The lower section is also tall enough to have a bed platform down low and sit straight up with the top down. Most of the lower frame is 0.75" x 0.75" steel tube with plenty of reinforcement following the construction techniques used on Overland Underbudget's flatbed camper.
    Any thoughts? Thanks!
    banditcamp, NotTaco, Sub_Par and 2 others like this.
  10. Feb 27, 2022 at 3:39 PM
    #2710
    Taco Camper
    Taco Camper Well-Known Member
    Looks great but maybe go up on tube size?
    When I built my camper I wanted it to be as light as possible. Heavy gauge is tempting (easy to weld) but turned out to be unnecessary. I knew that once I loaded water+people+gear+camper it would be a tank anyway (and it is).
    Depending on what your panels are made from and if they open like a door or not (act like a shear panel or not) would drive your tube selection, gussets and any diagonal bracing. I settled on 1.5”x1.5” tubing 16GA (0.065”) which is 1.3lbs/ft. and it was nice and light but plenty stiff with a simple open frame (less welding and welding something like this means dimensional distortion!) Remember the key is stiffness not “strength” and I would suggest you estimate the weight before you begin to make sure you are ok with it.
    Ok I just watched a couple Underbudget’s videos and couldn’t figure out how exactly he built the sides/doors/roof but that looks awesome.
  11. Feb 28, 2022 at 7:00 PM
    #2711
    M61guru
    M61guru Active Member
    Las Vegas
    07 DCSB TRD 4x4
    King / Fox Shocks 3rd Gen Wheels
    How are you liking those hinges?
  12. Feb 28, 2022 at 7:43 PM
    #2712
    davzx
    CO
    They’re great - really rigid, smooth, quiet. And I like the way they look. Water intrusion hasn’t been bad - the bulb seal keeps it dry, but water will run a bit if the doors are opened in the wet.
  13. Feb 28, 2022 at 7:51 PM
    #2713
    M61guru
    Las Vegas
    07 DCSB TRD 4x4
    Do you have a link for those hurricane hinges?
  14. Feb 28, 2022 at 8:25 PM
    #2714
    M61guru
    Las Vegas
    07 DCSB TRD 4x4
    Right on, thanks. Great build!
  15. Mar 2, 2022 at 6:29 AM
    #2715
    dually
    dually Low and slow
    Interstate underpass
    '16 Inferno SR5 DCLB
    Got it mounted up! I used a 2" bulb seal along the bed and the bottom half of the SoftTopper mounts to mate to the bed rail.
    BudLoomis, bot102, M61guru and 2 others like this.
  16. Mar 2, 2022 at 7:15 AM
    #2716
    davzx
    CO
    Thanks man! I'm loving it. Never thought I'd want a topper, but I really dig it. Nice to have a dry bed in the winter. Have yet to use the actual wedge though - but soon!
    Another thing with the hinges - I wish I'd staggered my rivets along it. I went linear for aesthetics, but the rivets don't grab a large area, so there is some flex when first opening and closing the doors. I can certainly add more rivets, but again, driven by aesthetics (maybe a bit too much haha).
    M61guru[QUOTED] likes this.
  17. Mar 2, 2022 at 7:43 AM
    #2717
    JMcFly
    JMcFly Well-Known Member
    Central FL
    2012 Tacoma SR5 4x4
    for the floor and roof I left the edges raw. It doesn't matter.
    I have seen others use Trim-Lok edging on the doors to jazz it up. But I also left mine raw
    also I saw someone recently used hurricane hinges, going to need a link for those bad boys
    jowybyo[QUOTED] likes this.
  18. Mar 2, 2022 at 2:53 PM
    #2718
    M61guru
    Las Vegas
    07 DCSB TRD 4x4
    Gotcha...thanks for the advice, I'll keep that in mind. I haven't started my build yet - I have most of the parts and just now starting to watch the sewing how-to videos.
  19. Mar 2, 2022 at 2:56 PM
    #2719
    M61guru
    Las Vegas
    07 DCSB TRD 4x4
    These seem to be the best hurricane hinges for this application, in my opinion:
    https://bigwoodycampers.com/teardrop-camper-parts-and-accessories/teardrop-camper-hinges
    JMcFly[QUOTED] likes this.
  20. Mar 2, 2022 at 3:21 PM
    #2720
    jowybyo
    Joe
    Baltimore, MD
