How to: DIY Wedge Camper
Discussion in 'Tonneau Covers, Caps and Shells' started by Ripcord, Apr 15, 2019.
  1. Mar 17, 2022 at 3:26 PM
    #2741
    Timk396
    Timk396 Active Member
    tim
    2007 TACOMA TRD OFFROAD
    I also agree that there is pretty minimal amounts of stress and a rivnut would be acceptable.
  2. Mar 20, 2022 at 7:43 PM
    #2742
    SloW8
    SloW8 Member
    One of the Other Guys
    37s, 2" lift
    Alright, I know it isn’t a Taco and I know I deviated a million miles from the original plan but it was all inspired by @Ripcord.
    I couldn’t go above the cab due to my 7’ garage door. That led to many modifications.
    I did mount the panels inside the frame and made mounts for Rotopax on the rear.
    it isn’t done. Will be painted to match the Jeep top paint.
    Bedawson, lamjam, .劉煒 and 11 others like this.
  3. Mar 20, 2022 at 8:25 PM
    #2743
    jowybyo
    jowybyo Well-Known Member
    Joe
    Baltimore, MD
    '14 MGM DCSB Postrunner 4wd Conversion, Debadged
    Well done dude. I like it a lot.
    SloW8[QUOTED] likes this.
  4. Mar 20, 2022 at 8:34 PM
    #2744
    jjnicolas
    jjnicolas Well-Known Member
    JJ
    NorCal
    19 trd off road DCLB
    @SloW8 looks great! I like how the tent extends for more room.
    SloW8 likes this.
  5. Mar 21, 2022 at 7:54 AM
    #2745
    davzx
    davzx Well-Known Member
    CO
    2007 Tacoma TRD Sport DCLB
    That looks rad! I dig the originality. Any pictures of the interior? Curious how the sleeping platform works.
  6. Mar 21, 2022 at 8:54 AM
    #2746
    sloshy
    sloshy Well-Known Member
    Houston
    2012 DCSB TRD Sport
    NONE
    I like how the it sits flush please post more of the interior and how it works
  7. Mar 21, 2022 at 9:34 AM
    #2747
    SloW8
    SloW8 Member
    37s, 2" lift
    Here are pics of the bare frame. Hopefully you can see the frames for the fold out piece, the removable panels in the middle and the larger flip up platform that can match the roof angle to open up the bed of the truck.
    I am 5' 11" and 235 pounds. So not small but I am okay to climb into the sleeping platform through the small hatch. On this trip I just left it out and slept on the side with the larger panel in place.
    Here you can see the panels inside. Sorry they are dirty and some still have the protective film in place. Ha.
    Still lots to do to finish. I need to seal everything, install the gas struts for the side doors, and paint the outside.
  8. Mar 23, 2022 at 10:44 PM
    #2748
    nanserb
    nanserb Well-Known Member
    Elliott
    2019 ZR2 Colorado
    I used Rivnuts, no issues.
    Timk396[QUOTED] likes this.
  9. Mar 24, 2022 at 7:08 AM
    #2749
    davzx
    CO
    Are those cabinet hinges on your side panels - did you use alupanel for those as well? I like the way those look.
  10. Mar 24, 2022 at 8:14 AM
    #2750
    SloW8
    SloW8 Member
    37s, 2" lift
    Yes, I used the surface mount hinges so I could recess the door panels into the frame.
    Yes, ACM/M-Panel/E-Panel stuff. I used the 6mm on the side doors. I would not recommend it. I would do the 3mm with stiffeners per plan. The 6mm is too heavy and still flexes too much so it will need some stiffener anyway.
    Cheers.
  11. Mar 29, 2022 at 4:39 PM
    #2751
    glove3390
    glove3390 Member
    2013 Tacoma Off-Road
    Alright, I pick my base frame up from the welder later this week and extrusion is on order. Looking ahead, the one thing that seems tricky / the most potentially frustrating to me is the blind bolting into the extrusion (frame to extrusion and and roof to extrusion). What worked well for people lining up the nuts in the extrusion? I think I saw some suggestions somewhere in here, but cannot find it now.
  12. Mar 29, 2022 at 8:34 PM
    #2752
    davzx
    CO
    So I bolted my wedge to frame in the upright position. I shimmed up each corner of the wedge about 1/2” and lined up the slot nuts with my pre drilled holes in the frame, double checking that I could see the nuts up through the holes. Then I laid down a bead of silicone at the interface and carefully pulled the shims. No issues, got it all bolted pretty quickly. I expected it to be tedious, but it was pretty simple.
    The more expensive roll-in spring nuts would have made it even easier. No risk of them sliding.
    M61guru likes this.
  13. Apr 1, 2022 at 6:14 PM
    #2753
    jowybyo
    Joe
    Baltimore, MD
    The tear down begins to convert this A.R.E DCU into a wedge camper.
    lamjam, Dan8906, Zebinator and 3 others like this.
  14. Apr 1, 2022 at 6:17 PM
    #2754
    demo243
    demo243 Well-Known Member
    Devon
    Topsfield MA
    2015 DCLB TRD 4x4
    looking forward to seeing the progress!
    what height cap are you starting out with?
  15. Apr 1, 2022 at 7:07 PM
    #2755
    jowybyo
    Joe
    Baltimore, MD
    23”.
    demo243[QUOTED] likes this.
  16. Apr 1, 2022 at 7:11 PM
    #2756
    jowybyo
    Joe
    Baltimore, MD
    Out of curiosity, what height is everyone making the frame?
  17. Apr 2, 2022 at 11:19 AM
    #2757
    jowybyo
    Joe
    Baltimore, MD
    Tear down complete. Next step, cut it to bits. Then rebuild it.
    based on my measurements, I’ll only have 1-1/4” of clearance between the overhang and the cab. I might make the frame 1/2” taller than it is now just to be safe.
    sloshy, Sub_Par and demo243 like this.
  18. Apr 2, 2022 at 1:15 PM
    #2758
    Sub_Par
    Sub_Par Well-Known Member
    Buffalo NY
    2011 TRD Off Road
    I have yet to tear mine down, how difficult was breaking it down?
  19. Apr 2, 2022 at 1:33 PM
    #2759
    jowybyo
    Joe
    Baltimore, MD
    Not terrible. Find all the rivets and drill them out first. Dealing with the sticky butyl sealing tape between all the joint is a pain. But otherwise it’s not in my top 10 of worst things to take apart.
    Zebinator and Sub_Par[QUOTED] like this.
  20. Apr 3, 2022 at 8:56 PM
    #2760
    sloshy
    Houston
    2012 DCSB TRD Sport
    NONE
    Wow I'm interested to see how it comes out keep posting updates
