How to: DIY Wedge Camper
Discussion in 'Tonneau Covers, Caps and Shells' started by Ripcord, Apr 15, 2019.
  1. Mar 11, 2020 at 11:26 AM
    #261
    Beater_Bimmer
    Beater_Bimmer Well-Known Member
    San Francisco, CA
    2002 Tacoma 4x4 DCSB
    You can easily follow these instructions and build in 2 separate pieces with some slight variations. 1) Camper shell w/ pop open sides. 2) RTT wedge style.
    BTW, I'm going to be embarking on this project in the next few weeks/months and will post my progress when that happens. Exciting!
    SR-71A and DeusExMachina[QUOTED] like this.
  2. Mar 16, 2020 at 10:04 AM
    #262
    plurpimpin
    plurpimpin Well-Known Member
    PDX
    2010 TRD Off Road 4x4
    @Ripcord Did you pay much attention to the modular floor system when you looked at the GFCs during your design stage? I was wondering if you have any design recommendations.
    I’ve been going through your plans noodling on how to incorporate the modular floor to allow the ceiling to be moved out of the way when setup and more interior living space is needed.
    I'm debating between 2 potential options:
    1) Mount Panel inside the extrusion by bolting a support plate to the bottom of the extrusion in place of the floor panel and then mounting the honeycomb panel to that. I'm thinking with something like 1/8" flat bar this could function like the poor man's version of GFC's custom extrusion.
    Pros:
    • no need to treat exposed edges of honeycomb panels
    • could potentially use multiple sheets of honeycomb instead of one large one (cheaper)
    • Does not make wedge any taller when closed
    • Allows full wall to wall panel sections to be removed
    • Potentially simpler to build
    Cons:
    • Heavier - extra parts
    • Not necessarily taking full advantage of the strength/stiffness of the honeycomb panels in supporting the structure - maybe not necessary?
    • Reduces interior storage space for bedding in wedge when closed
    obviously this is oversimplified powerpoint CAD but it gets the idea across
    2) Mount panel outside the extrusion like Ripcord did. Cut each edge slightly undersized to account for an edge treatment and then bond an appropriate size flat aluminum extrusion around the outside edges to close up honeycomb.
    Pros:
    • Honeycomb directly fastened to extrusion taking full advantage of its strength and stiffness - maybe negligible?
    • fewer parts/lighter weight
    • Does not reduce storage for bedding
    Cons
    • Single large piece of honeycomb required
    • Edge treatment could be tedious to apply
    • Makes wedge taller when closed
    • Smaller sized sections (width wise) would be removable due to leaving honeycomb attached to extrusion at outer edges for structure
    I presume they use an extrusion along the edges of the honeycomb similar to this one to enable the panels to pop in and out?
    Also does anybody know what thickness Honeycomb GFC uses for the floor? I thought I read 1 inch somewhere but I can't find it again.
  3. Mar 16, 2020 at 10:08 AM
    #263
    Ripcord
    Ripcord [OP] KM6PIM
    Jim
    Northglenn, Colorado
    Spruce Mica 2013 TRD-OR
  4. Mar 16, 2020 at 10:13 AM
    #264
    plurpimpin
    PDX
  5. Mar 16, 2020 at 10:15 AM
    #265
    Ripcord
    Ripcord [OP] KM6PIM
    Jim
    But to answer your question, I would go with method 1 from your post.
  6. Mar 16, 2020 at 10:16 AM
    #266
    plurpimpin
    PDX
    Thanks, that's the direction I was leaning anyway for many reasons.
    Ripcord[QUOTED][OP] likes this.
  7. Mar 16, 2020 at 1:12 PM
    #267
    MasterfulStu
    MasterfulStu Master Debater and Mechanic
    Stu
    North TX
    09 DB LB 4x4
    B 6112, 5125, Camburg UCAs, OME Leafs, TRD FJ wheels wrapped in Duratracs
    So bookmarking this for later
  8. Mar 20, 2020 at 3:24 AM
    #268
    robertjohnsonjr
    robertjohnsonjr Just looking for help from og tw
    B
    Tacoma
    2001 xtra cab 3.4 manual 4x4 tacoma
    No more 33s, exhaust,auxilary battery for lights and woofers, canopy w auxilary power...ditching hids soon
    Did anyone ever hit ya up to help build.
  9. Mar 20, 2020 at 6:47 AM
    #269
    rfreynol89
    rfreynol89 Member
    Rob
    2019 TRD Pro
    I beleive that GoFast has a custom extrusion that has a slot for the honeycomb, thus hiding the raw edge.
  10. Mar 20, 2020 at 7:37 AM
    #270
    joeink
    joeink Active Member
    joe
    2007 tacoma white 4X4
    nothing YET!
    I designed mine on Catia. My floor will slide forward so the family can be in side if weather is bad. I also plan on using a blowup mattress to save weight and have more room when lid is closed for blankets and pillows. Also will help with mold.
    Ripcord[OP] and SR-71A like this.
  11. Mar 20, 2020 at 2:33 PM
    #271
    Ripcord
    Ripcord [OP] KM6PIM
    Jim
    Correct, their extrusion has a flange at the bottom that allows the honeycomb to sit within the extrusion. Their extrusion is also a tad lighter than 80/20 per unit length.
    That's the beauty of DIY! You can change whatever you want.
  12. Mar 24, 2020 at 5:35 PM
    #272
    JimmyJames13
    JimmyJames13 New Member
    2009 DCLB TRD Sport
    Currently just starting out my build, I noticed that the mattress is 52" wide however the topper is only 50". is the mattress just squeezed in?
    Ayoung208 likes this.
  13. Mar 25, 2020 at 6:52 AM
    #273
    Ripcord
    Ripcord [OP] KM6PIM
    Jim
    yup! holds it nice and snug. The mattress isnt quite 52" wide, so if the camper was 52" it would be a bit loose.
  14. Mar 25, 2020 at 2:15 PM
    #274
    joeink
    joe
    nothing YET!
    Quarantine day 1. Installed the latches! C760DB1B-97F2-41CC-AE8D-2FA22E72934E.jpg
  15. Mar 25, 2020 at 2:17 PM
    #275
    Beater_Bimmer
    San Francisco, CA
    Is that wood?
  16. Mar 25, 2020 at 2:21 PM
    #276
    joeink
    joe
    nothing YET!
    @Beater_Bimmer it is aluminum core honeycomb with a fiberglass sheeting.
    Shellshock and robertjohnsonjr like this.
  17. Mar 25, 2020 at 6:19 PM
    #277
    JimmyJames13
    2009 DCLB TRD Sport
    Thanks for the reply Ripcord, another question for you. Bulb seal, top and bottom or just one side?
    Thanks in advance
  18. Mar 25, 2020 at 6:21 PM
    #278
    Ripcord
    Ripcord [OP] KM6PIM
    Jim
    just the bottom
    JimmyJames13 likes this.
  19. Mar 25, 2020 at 6:48 PM
    #279
    Beater_Bimmer
    San Francisco, CA
    Good questions. @Ripcord now that you've been running V2 for a while, any issues with water intrusion (esp. between 80/20 at the corners)?
    Also, is there enough positive pressure (with current design) to keep dust at bay?
  20. Mar 26, 2020 at 6:33 AM
    #280
    Ripcord
    Ripcord [OP] KM6PIM
    Jim
    Been dry as a bone so far
    LamzTaco likes this.
