How to: DIY Wedge Camper
Discussion in 'Tonneau Covers, Caps and Shells' started by Ripcord, Apr 15, 2019.
  1. Nov 2, 2022 at 7:17 AM
    #3121
    eforayter
    eforayter Well-Known Member
    1st Gen Xtra Cab
    Can anyone mill me the triple outside corner gussets? I am happy to pay for your service if so.
  2. Nov 2, 2022 at 8:27 AM
    #3122
    Montani_the_Taco
    Montani_the_Taco Member
    Lesley
    NC
    2015 MGM access cab 4x4
    3” lift 285/70/17 tires Bedrack Custom swing out rear bumper
    Jumping in late to the party here, but I want to start this project over the winter I think. Tired of the insecurity of my bedrack setup. I think I'm just making the topper for now, but may add the wedge in the future. I'm completely new to fabricating anything at all but know if I take my time, I can do it. I was wondering if anyone around Raleigh, NC has done this or is maybe planning to? I'm sure I will have a ton of questions along the way and possibly need a bit of help.
    Nicklovin likes this.
  3. Nov 2, 2022 at 9:12 PM
    #3123
    bot102
    bot102 The guy who ask a lot of questions
    Alec
    Castle Rock, CO
    2017 DCOR
    Beat up armor and broken stuff
    I bought those Valterra connections after you mentioned them months back, were they the ones that melted? I'm building my heater into a 22" Rigid Tool box.
  4. Nov 4, 2022 at 4:06 PM
    #3124
    jerseyhokie
    jerseyhokie Active Member
    Rouselle
    2018 Cement Gray Tacoma TRD OR
    Awesome setup. Thanks for sharing.
    nanserb[QUOTED] likes this.
  5. Nov 13, 2022 at 11:47 AM
    #3125
    Afilao
    Afilao Tacoma Driver
    SoCal
    ‘18 MGM DCSB Off-Road 6MT
  6. Nov 13, 2022 at 11:47 AM
    #3126
    nanserb
    nanserb Well-Known Member
    Elliott
    2019 ZR2 Colorado
    Yes, but only the straight ones melted due to how thin the walls are. The 45's and bulkhead connections are nice and thick, no issues.
    Sub_Par likes this.
  7. Nov 13, 2022 at 10:08 PM
    #3127
    G_W_Chonkr
    G_W_Chonkr Well-Known Member
    Enzo
    Clackamas, OR
    2020 Tacoma TRD OR
    2 years late but I picked up my panels just last week. I got them from SignsByTomorow in Peoria. They were the only company I could find that had the 5x10 sheets available at a reasonable price.
    They're not Alupanel by name but they are Dibond sheets which are pretty much the same thing.
  8. Nov 14, 2022 at 7:37 AM
    #3128
    eforayter
    1st Gen Xtra Cab
    This is a good deal for someone who is ok with the 3" version of the mattress. The EXPED called out in the build is the 10 (the one shared is a 7.5).
    Still a great deal at 50% off - just know it is the 3" version not the 3.9" version.
  9. Nov 14, 2022 at 7:52 AM
    #3129
    Unresolved Taco Issues
    Unresolved Taco Issues Well-Known Member
    Jeff
    FINALLY off the island!
    2020 Gray Tacoma Access Cab
    I've had the 3" version for a couple years and LOVE it! Yes, it's an inch thinner than 10. However, it still feels better than probably any other mattress you have tried(except maybe the 10 or 15). Also, the R-value is pretty high!
    I will say, the 7.5 does NOT come with any type of pump bag. The 10 comes with a little mushroom-shaped one that helps add extra firmness beyond what the self-inflation offers. You can still just manually blow into the valve, but that introduces moisture(mold) into the mattress and is not recommended by Exped. I purchased their pump bag separately ($30) for this reason.
    eforayter[QUOTED] likes this.
  10. Nov 14, 2022 at 8:03 AM
    #3130
    bot102
    Alec
    Castle Rock, CO
    2017 DCOR
  11. Nov 14, 2022 at 8:04 AM
    #3131
    bot102
    Alec
    Castle Rock, CO
    2017 DCOR
    Okay. Don't think I have any of the straight fittings. Only the bulkhead mounts and the connections to them
  12. Nov 14, 2022 at 3:07 PM
    #3132
    eforayter
    1st Gen Xtra Cab
    What did everyone use to cut their alupanel or dibond panels who didn't use a router? I am thinking a jigsaw with a metal / fine blade. Going to be cutting into mine this week.
  13. Nov 14, 2022 at 3:18 PM
    #3133
    davzx
    davzx Well-Known Member
    CO
    2007 Tacoma TRD Sport DCLB
    Yeah a fine blade will work just fine. Truly any blade will work, especially with how thin the skin is. I used a track saw with a general wood blade and it was all good. Sometimes if you go too fast on aluminum, a tooth can catch and shift the piece but that’s not really a concern on this material. Just don’t rush it.
  14. Nov 15, 2022 at 10:08 AM
    #3134
    G_W_Chonkr
    Enzo
    Clackamas, OR
    2020 Tacoma TRD OR
    I should be cutting into mine in the next week or two also. I asked for a small piece from the vendor to test with Jigsaw and can confirm it cut through it like butter. No issues. For the straight cuts, I'm going to use a circular saw with an aluminum blade. That was also recommended by the vendor.
  15. Nov 15, 2022 at 12:09 PM
    #3135
    jowybyo
    jowybyo Well-Known Member
    Joe
    Baltimore, MD
    '14 MGM DCSB Postrunner 4wd Conversion, Debadged
    I used a table saw with a wood blade. Cut it like butter. I also used a razor blade to cut some of the side panels. That was ok. Table saw was better. Very clean cuts.
  16. Nov 16, 2022 at 5:16 PM
    #3136
    Montani_the_Taco
    Lesley
    NC
    Hey all, I am planning my version out now. I was reading through this thread awhile back and thought I saw that someone else was considering making just the topper without the integrated wedge. Can anyone post a few pics? I am trying to get an idea of how high above my cab I want to take the topper.
  17. Nov 16, 2022 at 11:31 PM
    #3137
    austinmtb
    austinmtb Well-Known Member
    Austin
    Southern Oregon
    2004 Toyota Tacoma DC TRD 4x4
    ADS Coilovers & Shocks, All Pro Standard Leafs, TRD Supercharger, Haltech Standalone, URD 2.2'' pulley, Method NV wheels, Copper Discoverer STT Pro tires, ECGS 4:56 gears, custom steel tube bumper, custom steel skid plate,
    To those of you that just built the rooftop tent without the space-frame, what did you use for flooring material?
  18. Nov 17, 2022 at 10:08 AM
    #3138
    TRDMobile4x4
    TRDMobile4x4 Well-Known Member
    Nathan
    2019 Cement Grey Tacoma TRD Off-Road
    For those with the wedge fully built, have you had issues with bed flex even when you have the bed stiffeners? Hoping to build my own but I off-road frequently and all that weight on the bedsides is a concern.
    Leedehua likes this.
  19. Nov 17, 2022 at 12:00 PM
    #3139
    bot102
    Alec
    Castle Rock, CO
    2017 DCOR
    Not that I have noticed. @YamaDirtrider has a DCLB and I have a DCSB, We both wheel our trucks fairly hard and haven't noticed anything. Your CG will get way higher with the wedge, so keep that in mind. Almost rolled the truck a few times getting used to the new CG on a wheeling trip a few months back.
  20. Nov 18, 2022 at 4:03 PM
    #3140
    Montani_the_Taco
    Lesley
    NC
    Maybe a dumb question, but never had to use one. Any recommendations on rivet guns? Looks like prices vary a lot.
