How to: DIY Wedge Camper
Discussion in 'Tonneau Covers, Caps and Shells' started by Ripcord, Apr 15, 2019.
  1. Mar 8, 2024 at 12:01 PM
    #3461
    jjnicolas
    jjnicolas Well-Known Member
    JJ
    NorCal
    19 trd off road DCLB
  2. Mar 10, 2024 at 5:37 PM
    #3462
    XLNguyen832
    XLNguyen832 New Member
    Love the build and would like to see a full breakdown including costs, hardware and connections if possible. Looking to also do one as well using 8020.
    tacoonright2002 likes this.
  3. Mar 14, 2024 at 8:36 AM
    #3463
    jjnicolas
    JJ
    NorCal
    It's been almost 3 years since I completed my build. A new issue arose with the aluminum roof panel. It is starting to degrade. My aluminum roof panel is white, so after a rain, water will drip down the sides leaving a chalky streak around the camper and especially the rear windows. It's more annoying than anything. Not sure if I should vinyl wrap the roof or use some kind of paint or sealer. So if you're on the roof stage of the build, I recommend you weather proof it and not leave it bare panel.
  4. Mar 14, 2024 at 10:22 AM
    #3464
    TheTacomaInn
    TheTacomaInn Well-Known Member
    Rob
    Littleton, CO
    17 OR Access Cab, OME 887,HD Dakars, 285s
    Interesting. Mine has been on for only one year but I have had some concerns about the ACM weathering. I have noticed that my black side panels have gotten some stains/ water marks that I can not seem to get 100% gone. I have been thinking about starting to use some sort of wax or sealer when I wax the rest of the truck. I will let you know if I find a good product.
  5. Mar 14, 2024 at 10:44 AM
    #3465
    jjnicolas
    JJ
    NorCal
    @TheTacomaInn I vinyl wrapped my side panels which seem to be holding up pretty good. Just the bare aluminum panels have issues over time. I'll let you know too what I decide to do
  6. Mar 14, 2024 at 4:34 PM
    #3466
    TheTacomaInn
    Rob
    Littleton, CO
    Just to clarify, when you say bare aluminum, did you use the ACM like RipCord (MaxMetal, E Panel, ect.) or did you us straight aluminum?
  7. Mar 14, 2024 at 4:55 PM
    #3467
    jjnicolas
    JJ
    NorCal
    @TheTacomaInn oh sorry, yes dibond like ripcords. Not straight aluminum
  8. Mar 16, 2024 at 5:14 PM
    #3468
    jjnicolas
    JJ
    NorCal
    Installed a roof rack for accessories and to fill in the gap. Previous to the rack, I could only feel the camper at higher speeds upwind. If you're starting this diy camper build and plan to use a roof rack, make sure you tweak the hight dimensions. Ripcords dimensions don't allow for a full roof rack. Cheers
  9. Mar 31, 2024 at 8:16 PM
    #3469
    jjnicolas
    JJ
    NorCal
    Made a drip gutter for the cabover corners. I had enough of the annoying drip into the cab when I open the doors lol
    20240328_171317.jpg 20240328_184223.jpg 20240331_161205.jpg 20240331_183930.jpg
  10. Mar 31, 2024 at 8:30 PM
    #3470
    Raceface35
    Raceface35 Well-Known Member
    Tim
    Murrieta, CA
    2011 Tacoma TRD OR
    King 2.5 Ext Travel Front & Rear, Icon Delta Joint UCA, OME Dakar "Heavy" Leaf Springs, 33x12.5R17 Ridge Grapplers, CaliRaised Sliders, RCI Bed Rack, Viair On-Board Air
    Made it this far in the build! Going to assemble the “lid” tonight and then order up the max metal for roof/floor. Wasn’t as bad aligning all the through bolts as people made it seem
    Calamity_taco and jjnicolas like this.
  11. Apr 1, 2024 at 1:37 PM
    #3471
    Codybuck93
    Codybuck93 Member
    Awesome build man. Dream setup! Enjoy
  12. Apr 8, 2024 at 6:54 PM
    #3472
    JMcFly
    JMcFly Well-Known Member
    Central FL
    2012 Tacoma SR5 4x4
    I’m still curious about hurricane hinge installs. The hinges available are made to mount to two pieces of what appears to be 1/2 or 3/4” ply.
  13. Apr 9, 2024 at 6:39 AM
    #3473
    QueenCity_Offroad
    QueenCity_Offroad Member
    2021 Cement Tacoma TRD-OR
    Backwoods Adventure Mods Front Bumper Backwoods Adventure Mods Rear Bumper w/ DIY Swingout Backwoods Adventure Mods Aluminum Skid Plates Kenda Klever RT 35x10.5r17 RRW RR6-H w/ protection rings Dobinson 3" w/ UCA's
    I notched the mounting edges to work around the support bars and end caps. From the teardrop guys, they said to have a bit of runoff on the hinges so the 62" hinge worked perfect for the 63" frame. I'll add vinyl molding to the top part over the hardware, and a boatload of silicone. Waiting on the frame to return from powder right now!
    My only conundrum is how I will seal the end of the hinges, open to ideas!
  14. Apr 9, 2024 at 7:06 AM
    #3474
    guaco.supreme
    guaco.supreme Fk around and find out
    MN
    Aha! I knew I saw this photo before... hello fellow United moderator!
    I don't think I added it to our discussion on United, but you can dab some black silicon in the ends of the hinge. I'll try to snap some photos tonight when I get home. Or you could fab up some small covers that sit against the ends that stop water from getting pushed into the hinge itself.
  15. Apr 9, 2024 at 7:13 AM
    #3475
    QueenCity_Offroad
    Ayyy wassup, thanks man!
  16. Apr 10, 2024 at 7:35 PM
    #3476
    tacoonright2002
    tacoonright2002 New Member
    2002 Red Tacoma 4X4
    I just bought one to mess around with 50$ on Amazon I think rec pro brand
  17. Apr 11, 2024 at 8:33 AM
    #3477
    time623
    time623 Well-Known Member
    James
    AZ
    1995.5 White Tacoma 4x4
    I've made it through 70 pages so far, so apologies if it got asked/done in the last hundred. I'll get through eventually..
    But has anyone extended the spaceframe top horizontal bars the full wedge length over the cab? Kind of like a ladder rack. Thinking with this you could bring the 80/20 to 1.5x1.5 top and bottom since it will have no overhang, it'll be fully supported by the spaceframe.
    Thinking the only downside would be reduced interior closed height? Any thoughts on a way around that?
    Seems like a really easy way to reduce cost by quite a few hundred. Those 1.5x4.5 get real expensive at 100"+
  18. Apr 11, 2024 at 9:05 AM
    #3478
    davzx
    davzx Well-Known Member
    CO
    2007 Tacoma TRD Sport DCLB
    Could work if the frame is beefy and rigid enough. The 1.5" extrusions are not very rigid themselves beyond like 5'. That's my biggest gripe with mine - I extended mine to 10', and with 1.5" on top it flexes noticeably, doesn't keep the tent fabric taut beyond the strut mounts. If I did it again, I'd keep the 4.5" for the bottom because of the long cab-over, but up the top to 3". Not as slim aesthetically obviously, but much better functionally.
  19. Apr 11, 2024 at 9:15 AM
    #3479
    time623
    James
    AZ
    Yeah I'm thinking something like this:
    So that you don't need 4.5" bottom to support the overhang, as none of the 8020 will be cantilevered. Though the roof section would still flex as you said..
    Looking at it more the issue is definitely going to be closed interior space, as it would only be 3" from roof to floor with the wedge closed. Probably can't get around that issue..
    Maybe do 3" 8020 on the roof, gets you 4.5" interior space and reduces the roof flex. Or 4.5" on the roof, but then were just back at the original 8020 cost and just made the frame significantly heavier..
  20. Apr 15, 2024 at 4:18 PM
    #3480
    IndependenceEnterprises
    IndependenceEnterprises New Member
    Brian
    RAM 2500 with plans to build a wedge camper via resources from TW members
    Custom DIY bedslide, locking diff, small lift/tires, cap/camper setup in the works
    It's begun....I have purchased a fair amount of my materials, and I'll post photos/updates as I get into it. Basics are going to be: Modified design for full size (RAM 2500), extended length, aluminum space frame, taller extrusion profiles for more load-carrying capacity on roof rack cross bars, different side/rear door frame and "jamb" design..."modified full pop" and a few other things I've dreamed up as I've studied all of you trailblazers.
    Meanwhile, I'm wanting to settle on door latches. Anything viable other than the legit Southo sealed units? I've gathered that the knock-offs aren't worth the savings. But it's hard to justify the cost of the real thing. I'm open to suggestions if anyone has them at this point. But soon I'm going to get busy fabricating, and will get past the point of being able to modify the design.
