How to: DIY Wedge Camper
Discussion in 'Tonneau Covers, Caps and Shells' started by Ripcord, Apr 15, 2019.
  1. Jun 16, 2024 at 8:51 PM
    #3521
    jjnicolas
    jjnicolas Well-Known Member
    JJ
    NorCal
    19 trd off road DCLB
    Vinyl wraped the roof of the camper. 20240615_164544.jpg 20240615_193541.jpg
    lamjam, Raceface35, El Tigre and 5 others like this.
  2. Jun 16, 2024 at 10:52 PM
    #3522
    antwon412
    antwon412 Well-Known Member
    2022 Gladiator Mojave
    Lifted. Locked F/R. Method 705s. 37s.
    that looks killer. Great job
    jjnicolas[QUOTED] likes this.
  3. Jun 16, 2024 at 11:36 PM
    #3523
    jjnicolas
    JJ
    NorCal
    Thanks ;) my white aluminum roof panel turned chalky because of age. When it rains or even just morning dew, streaks of white would drip down the whole camper. It was annoying lol. This should fix that.
  4. Jun 17, 2024 at 5:20 AM
    #3524
    guaco.supreme
    guaco.supreme Fk around and find out
    MN
    Have you had any issues with your roof vent in the rain? I was thinking of doing this same thing, but concerned that when the tent is open and there is a heavy enough rain that the runoff might be enough to splash over the lip of the vent.
  5. Jun 17, 2024 at 6:54 AM
    #3525
    jjnicolas
    JJ
    NorCal
    I only had it in the rain a few times. I thought the same thing, but had no issues with rain getting in. I didn't add the skirt, which is the only issue I have now with rain.
  6. Jun 24, 2024 at 11:26 AM
    #3526
    jerseyhokie
    jerseyhokie Active Member
    Rouselle
    2018 Cement Gray Tacoma TRD OR
    Great job! What's the overall length of your extrusion? Looks like about seven feet in total.
    Also, wondering if you can share some more pics on the tent material and sewing process. I love the look and functionality of the big windows.
  7. Jun 24, 2024 at 2:55 PM
    #3527
    ENTaco
    ENTaco Member
    2006 Tacoma TRD Offroad
    DIY Wedge Camper
    Sure! Extrusion is 100" long, so just over 8 feet.
    I started by cutting a rough shape of the canvas, with plenty of extra, based on the dimensions of the tent opening. I used the width of the fabric - two hems to determine the max opening height of the camper. I hemmed those first (the rear window) before anything else, to establish a baseline.
    Next I did a test fit with the rough cut shape, and the two hemmed edges that were already locked in:
    The keder rails and awning cord are really nice because you can pull the sides tight then pin them in place, remove the rails, then sew the final hems.
    Once I had that complete, I started on the windows. Essentially just lots of measuring and marking first, then make the final cuts.
    The zippers are all double stacked so you can open the window, the bug mesh, or both together. I actually sewed all the lengths of zippers together first, then made hems large enough to accomodate the dual zipper design. Then, sewed the zippers onto the canvas. Used lots of basting tape, clips, and pins.
    I did the bug mesh last on the side windows, once the canvas was already sewed to the zippers. This was because the bug mesh on the side windows is on the outside. This allows you to open the window from the inside but leave the bug mesh up, or take them both down at once.
    The rear window was a bit trickier since I wanted the ability to prop the rear window canvas open like an awning with some poles. So, for the rear window, the mesh is on the inside. Velcro on the bottom of the rear window allows you to easily readjust the rear mesh and canvas panels when closing.
    Lastly, I terminated the zippers on the windows behind sewn on triangular and rectangular patches, to hide the ends and make everything shed water better:
    I had 0 sewing experience prior to this. I purchased a Juki HZL-F300 for this project (and future projects) and it was incredible. Sewed through multiple layers of canvas and zipper like butter. Pretty much everything is just a simple straight stitch with a few zigzags and overcasting stitches in a few spots.
  8. Jun 25, 2024 at 10:10 AM
    #3528
    guaco.supreme
    MN
    Since theres quite a few that have had theirs for a while now, whats your thoughts on Alupanel type panels? Still worthwhile or should I look at alum sheet instead?
    I see quite a few have waves and bends in the Alupanel after some use, but it's hard to tell how bad in photos. Ripcords IG also stated "Gone is the steel space frame and flimsy doors and in comes an all aluminum structure."
  9. Jun 25, 2024 at 10:43 AM
    #3529
    ENTaco
    ENTaco Member
    DIY Wedge Camper
    My build was just completed a few months ago so I can't speak as much to the longevity, but here's my thoughts regarding Alupanel:
    I was considering aluminum sheeting instead, but ultimately went Alupanel for the cost and availability near me. It was around twice the cost to go aluminum from my local suppliers. Aluminum sheets are also a bit tougher to work with, and heavier for the same thickness. Ultimately I figured even if I damage a panel and it needs to be replaced, it will be cheaper to replace than to have spent more on Aluminum.
    That being said, yes the Alupanel can easily warp if it is not stiffened. I accidentally dropped a piece while working and had to straighten it out. My black panels also have some visible scuffing from a recent offroading trip where brush was scraping on them. This could easily be remedied by a wrap or other more durable coating than the finish they come with.
    Ripcord's V2.5 Update on IG shows that he made custom GFC style aluminum panels with the edges press-braked. If I had the extra cash that would have been a really nice way to go. Really comes down to cost and level of fabrication effort to make the decision between the two options.
    Others can chime in on the longevity but I'm happy with the decision to go Alupanel/Maxmetal at the start. I can always upgrade in the future if needed.
    Cheers
  10. Jun 26, 2024 at 9:55 AM
    #3530
    jerseyhokie
    Rouselle
    I am so appreciative for the write up. This clears up SO much for me. I will 100% be stealing all your ideas so look forward to a post on that in the coming weeks. I especially like the cork gasket material on the base of your sleeping platform frame. Cheers!
    ENTaco[QUOTED] likes this.
  11. Jul 18, 2024 at 1:15 PM
    #3531
    BRFab
    BRFab Well-Known Member
    BC
    '19 Alien Grey TRD OR
    I want to mount some L-Track to the roof of my wedge camper for a roof rack, which is powder coated aluminum and I'm curious what you guys use to prevent water from getting in. The inside of the roof is carpeted/fabric so I'd rather not slather some types of silicone or other sealants that might weep inside on bedding etc
    Thanks
  12. Jul 29, 2024 at 5:44 PM
    #3532
    QueenCity_Offroad
    QueenCity_Offroad Member
    2021 Cement Tacoma TRD-OR
    Backwoods Adventure Mods Front Bumper Backwoods Adventure Mods Rear Bumper w/ DIY Swingout Backwoods Adventure Mods Aluminum Skid Plates Kenda Klever RT 35x10.5r17 RRW RR6-H w/ protection rings Dobinson 3" w/ UCA's
    Anyone have a file for awning brackets that fit the 4.5” extrusion to 4.5” awning profile? Thought I’d check before making one. (If someone want to help me make one even better haha)
  13. Jul 29, 2024 at 7:56 PM
    #3533
    jjnicolas
    JJ
    NorCal
    Been 3 years and my welds are still holding together lol. Spent a full week dispurse camping in the Eastern Sierras. A lot of washboard dirt roads, bumps, rain, dust and 5 different sites. Camper did really well. Southco latches did start to bind, but there are dust covers that people 3D print. Also I'm curious how long the 100 lb wedge struts will last. If one blows out, that would suck lol
    lamjam, ENTaco, ETAV8R and 3 others like this.
  14. Jul 31, 2024 at 2:56 PM
    #3534
    El Tigre
    El Tigre Well-Known Member
    Long Beach
    2018 DCSB TRD Sport 4x4 6speed
    Armrest MOLLE Panel (https://www.tacomaworld.com/threads/3rd-gen-center-armrest-molle-panel.712437/) Hood Scoop Hidden Baja Designs S8 10" Diode Dynamics SSC2 Pro Ditch Lights Bilstein 6112 front Bilstein 5160 rear Bakflip MX4 DIY Bed Lights RGB Rock Lights Modified Amazon 8 gang switch controller (thread coming)
    I got so excited when I saw this post. I've been follwoing for years now and had always wanted to design the base out of extrusion (I've done so in CAD at least) but was certain there was a reason he didnt do it initially maybe for strength or something... Amped to see his test results!
  15. Jul 31, 2024 at 4:27 PM
    #3535
    ScottThePainter
    ScottThePainter Well-Known Member
    2023 TRD Off-Road Magnetic Grey
    I’m using the Super Pacific awning brackets on my RTT. I just slotted the bottom hole more to fit my tents extrusion profile. I would bet they fit the 4.5” extrusion well.
  16. Jul 31, 2024 at 8:31 PM
    #3536
    Raceface35
    Raceface35 Well-Known Member
    Tim
    Murrieta, CA
    2011 Tacoma TRD OR
    King 2.5 Ext Travel Front & Rear, Icon Delta Joint UCA, OME Dakar "Heavy" Leaf Springs, 33x12.5R17 Ridge Grapplers, CaliRaised Sliders, RCI Bed Rack, Viair On-Board Air
    Made a mini roof rack to go in front of the camper
  17. Aug 2, 2024 at 2:39 PM
    #3537
    Tim_dH
    Tim_dH Active Member
    2013 Tacoma
    Very cool, how are you attaching it to the roof?
  18. Aug 2, 2024 at 9:35 PM
    #3538
    G_W_Chonkr
    G_W_Chonkr Well-Known Member
    Enzo
    Clackamas, OR
    2020 Tacoma TRD OR
    Update! Done with the tent and install! Couple of hiccups overall but ready for a camp in the next couple weeks.
    The 3d printed keder corners worked for the most part but they were a pain to get installed with the corners of the fabric. Updated the file with help from a coworker to round out instead of meet at a corner and beefed it up for support.
    Still need to replace the corners with the updated version and let a little bit of fabric out since the wedge is pulling the rail out of the corner.
    Updated the sleeping platform that I initially had made of square tubing. It ended up being a 1/4 in too wide to hinge up once the keder track was installed... New platform I got from work that was scrap.
    Molle panels I picked up from SuperPacific and just installed rivnuts to mount them. Designed and 3d printed a couple of molle hooks to mount my camp chair. More parts for that coming soon too.
    Next update is the floor. Insulation and bedliner on a solid piece of plywood so I can piece together the storage for electrical and supplies.
    ENTaco likes this.
  19. Aug 3, 2024 at 6:32 AM
    #3539
    Raceface35
    Tim
    Murrieta, CA
    2011 Tacoma TRD OR
  20. Aug 15, 2024 at 1:11 PM
    #3540
    Onix Taco
    Onix Taco New Member
    2017 Tacoma TRD OR
    Has anyone tried to liquid nail or use some other type of adhesive to apply the angled aluminum door stiffeners to the inside of the doors as a replacement to riveting? Rebuilding my doors now to use a continuous hinge and would like the clean aesthetic without all the rivets on the exterior. Unsure if there are any issues with durability long term.
