How to: DIY Wedge Camper
Discussion in 'Tonneau Covers, Caps and Shells' started by Ripcord, Apr 15, 2019.
  1. Apr 15, 2019 at 9:43 AM
    GHOST SHIP
    GHOST SHIP hates you.
    GHOST
    Awesome work! :thumbsup:
    My suggestions to address your two concerns:
    1. Bedrail caps from KB Voodoo:
    http://www.kbvoodoo.com/shop/powder-coated-bed-side-rail-cap-system-fits-years-2005-2015
    2. A small "roof rack" that only utilizes the two front mounting points. This could be a simple platform or basket to store gear, but more importantly it would be a perfect place to mount a fairing without looking out of place aesthetically. You could just build a simple fairing with some standoffs to mount to the slots at the front of the camper's leading edge, but IMO that would looked like an after-thought, design-wise. Either way, it would be a simple project for your skillset.
  2. Apr 15, 2019 at 9:47 AM
    Brooksie
    Brooksie Well-Known Member
    2015 Black Tacoma
    Method Wheels Toyo A/T Tires Snugtop shell More To Come
    Great build. Great detail. Looks awesome!!!!
    Ripcord[OP] likes this.
  3. Apr 15, 2019 at 9:48 AM
    Ripcord
    Ripcord [OP] KM6PIM
    Jim
    Northglenn, Colorado
    Spruce Mica 2013 TRD-OR
    I like the look of the painted bedside tops, so I will probably just cover those holes from the bottom.
    And I was thinking in the same direction as you for a roof rack using the front 2 roof mounting points. Probably what I will do, thanks!
    GHOST SHIP[QUOTED] likes this.
  4. Apr 15, 2019 at 11:37 AM
    TRD493
    TRD493 Well-Known Member
    Dave
    Texas (DFW)
    17 TRD Sport DCLB 4x4 / 01 4x4 V6 Extra Cab TRD SR5
    Or this company (I'm sure there are others), they make some light weight corrugated cores that are strong AF. They even have some with foam sandwiched in between....might be too thick though. Very nice build!
    https://www.laminatorsinc.com/
  5. Apr 15, 2019 at 12:04 PM
    Pyrotech
    Pyrotech Well-Known Member
    Nicely done...
  6. Apr 15, 2019 at 3:41 PM
    JerryW
    JerryW Well-Known Member
    Jerry
    Illinois
    2012 DCLB 4WD SR5
    Well done. That turned out great. :thumbsup:
    Have you seen any leaking from the felt seals?
    Seems like they might wick moisture through to the inside. I was thinking the butyl weatherstrip or some double stick foam tape would solve that. Thoughts?
  7. Apr 15, 2019 at 4:35 PM
    tacomavan
    tacomavan Well-Known Member
    Oregon
    awesome, you ever consider the flippac-style or is that a bit more challenging from a design/build perspective?
  8. Apr 15, 2019 at 4:39 PM
    frenchee
    frenchee Favorite Member
    Oceanside CA Area
    2003 Tacoma TRD Double Cab 4x4
    Converted to 4WD DD VW MK6 TDI
    Wow, that's awesome. Makes me feel bad about myself. I started designing the tubular structure to make my own GFC in 2018 but gave up. Just got an RTT. Damn I'm jealous.
    Good job on the square tubing, when I started I wanted square but was having a hard time with the angles on the top section. Circular is much harder to notch. Well done.
    Jig is badass.
    LTDSC and Ripcord[OP] like this.
  9. Apr 15, 2019 at 4:44 PM
    frenchee
    Oceanside CA Area
    Yeah, when I was "designing" the space frame the struggle was with getting the angles right on the tubes using square tube. A little trickier than round tubing. So jealous.
    Ripcord[QUOTED][OP] likes this.
  10. Apr 15, 2019 at 4:59 PM
    frenchee
    Oceanside CA Area
    Thanks for sharing the excel sheet, I also put a lot of thought into the seals but you have it all there. Very cool. What do you do for work?
  11. Apr 15, 2019 at 5:31 PM
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    Dude.. This is insanely awesome! Probably one of the best DIY / tutorial threads Ive seen on here, and thats saying something. Ill definitely have to bookmark this and re-read it at some point
    kevinlambchops, LTDSC and Ripcord[OP] like this.
  12. Apr 15, 2019 at 7:22 PM
    Ripcord
    Ripcord [OP] KM6PIM
    Jim
    Took it through some mild snowing and so far so good. I will keep an eye on them though!
    Also, both of the big areas I am using them (bulkhead-spaceframe & Wedge-spaceframe) are in a spot where water would just be getting into the truck bed area. Which is much less of a concern to me than the tent part.
    I did, but that would definitely be a bit more challenging. Those also take more time to setup, which was not what I wanted.
    Thanks! It was certainly a lot of work, but once I dropped the coin on the materials there was no turning back. And yes square was definitely much easier.
    I lived in that excel sheet for a few months haha. I am a mechanical engineer.
    Wow thank you for that compliment! I do like to make write ups.
  13. Apr 15, 2019 at 7:46 PM
    frenchee
    Oceanside CA Area
    Haha, I was 95% sure about that. I saw the whole DIY and was thinking, this guy has to be an ME especially after seeing the Mcmaster Carr on the spreadsheet.
    I'll have to message you about work out there. Been trying to get a feeler on ME positions out of my area.
    SR-71A, LTDSC and Ripcord[QUOTED][OP] like this.
  14. Apr 15, 2019 at 8:06 PM
    Pickeledpigsfeet
    Pickeledpigsfeet Well-Known Member
    Foothills, CA
    great writeup. Thanks for doing all the hard work, now I am going to make one for my Tundra this summer.
  15. Apr 15, 2019 at 8:20 PM
    #35
    Pickeledpigsfeet
    Foothills, CA
    Did you have a reason for not using aluminum sq tube for the frame?
  16. Apr 15, 2019 at 8:22 PM
    #36
    Ripcord
    Ripcord [OP] KM6PIM
    Jim
    Besides not being able to weld aluminium?
    The spaceframe was only 1/7th of the total weight, so there are other areas I could have spent more for more weight loss value.
    Pickeledpigsfeet, LTDSC and frenchee like this.
  17. Apr 15, 2019 at 8:58 PM
    #37
    Ripcord
    Ripcord [OP] KM6PIM
    Jim
    there's lots out here, especially in the aerospace and tech industry
  18. Apr 15, 2019 at 9:14 PM
    #38
    foxrcing07
    foxrcing07 KO7FOX
    Morgan
    Modesto, CA
    2019 Raptard 2001 TJ
    Dirt
    Sub’d for build ideas
  19. Apr 16, 2019 at 2:00 AM
    #39
    dskakie
    dskakie Well-Known Member
    Dan
    Northern CA
    2016 TRD OR DCSB
    Great thread man! I’ve been following along on your IG for the teasers but the final product and this thread blow those out of the water. Super clean work, stoked to see where it takes you this summer! :thumbsup:
  20. Apr 16, 2019 at 6:47 AM
    #40
    Ripcord
    Ripcord [OP] KM6PIM
    Jim
    Thanks! I am super happy with how it came out!
    I could still see myself making a V2 next winter, but this will be great for the summer.
