How to: DIY Wedge Camper
Discussion in 'Tonneau Covers, Caps and Shells' started by Ripcord, Apr 15, 2019.
  1. Oct 13, 2020 at 7:25 AM
    #581
    Machrocket
    Machrocket Member
    Jamie
    I just started my build this week. Im attempting to make the "space frame" out of aluminum square tube. I want the finished product to be as light as possible. This is requireing a few extra aluminum gussets but the frame is coming together nicley. At least nice for somthing im making. Its a bit of a gamble on strength. and yes my shop is filthy and I am ashamed. :)
    20201010_213508.jpg 20201010_213521.jpg 20201010_213530.jpg 20201012_184414.jpg but so far it feels really strong.
  2. Oct 13, 2020 at 8:17 AM
    #582
    CayucosTacoma
    CayucosTacoma Just think outside the Yota
    San Luis Obispo/San Jose
    2004 Double Cab 4x4
    Specs in the Build Thread
    Very cool, what wall thickness are you using?
  3. Oct 13, 2020 at 8:24 AM
    #583
    Machrocket
    Machrocket Member
    Jamie
    Im using 1/8 for most of the frame and 3/16 for the cross beams that have to hold my weight.
  4. Oct 13, 2020 at 10:29 AM
    #584
    frenchee
    frenchee Favorite Member
    Oceanside CA Area
    2003 Tacoma TRD Double Cab 4x4
    Converted to 4WD DD VW MK6 TDI
    Good idea with the reinforcements. My experience with aluminum is if you dont get good penetration and grind them flush, you will get cracking very quicky.
    Hopefully you beveled most of the buttwelds you sanded down. I do think those plates will help reduce the stress in the welds though. Nice to see an aluminum version
  5. Oct 14, 2020 at 2:24 PM
    #585
    CayucosTacoma
    2004 Double Cab 4x4
    For anyone looking to buy some latches and need the full grip range.
    I bought a set of these to check quality vs some other knock offs.
    These seem super quality and the locks work as designed. Powdercoat seems pretty ok, few bare spots on the key hole area but not a big deal.
    Hope this helps someone
    caleebra and frenchee like this.
  6. Oct 15, 2020 at 9:43 AM
    #586
    Machrocket
    Machrocket Member
    Jamie
    Hello all, Im still in the planning stages on my RTT portion for my aluminum Go fast camper. I see that most wedge campers attach the faberic to the inside of the aluminum extrusion even actual GFC. But is seems in my head this would cause water and moisture to pool between the fabric and the extrusion? I have seen some flaps at the base to aid with this issue but they look like they would hinder putting the tent away getting stuck between the clam shell or just taking more time having to stuff things in. Do people have trouble with water intrusion or mildew along the edge with the "standard design or do I need to do some sort of extra thing like the flap. Any other options people have thought of would be appreiciated.
  7. Oct 15, 2020 at 5:45 PM
    #587
    plurpimpin
    plurpimpin Well-Known Member
    PDX
    2010 TRD Off Road 4x4
    I added some additional stiffeners to my side panels bridging the sections of aluminum angle on each side of my latches. The panels are now much more solid. Before the extra stiffener they were deflecting really badly at the latches.
    Really happy with how they turned out.
  8. Oct 15, 2020 at 6:12 PM
    #588
    CayucosTacoma
    2004 Double Cab 4x4
    Oh that’s awesome.
    Definitely going to steal that idea.
  9. Oct 16, 2020 at 9:20 AM
    #589
    Jarman02
    Jarman02 Well-Known Member
    Oregon
    2002 Tacoma Xtra Cab
    Noticed the bulb seal on 80/20s site is a good bit cheaper than the McMaster Carr one, same dimensions from what I can see. $1.15 ft vs $1.42
    Ayoung208 likes this.
  10. Oct 16, 2020 at 10:05 AM
    #590
    jmartin2076
    jmartin2076 Well-Known Member
    Tacoma WA
  11. Oct 16, 2020 at 2:11 PM
    #591
    riven29
    riven29 Well-Known Member
    1995 Maroon Tacoma
    @jmartin2076 What thickness of panel did you use this on?
  12. Oct 18, 2020 at 4:23 PM
    #592
    CayucosTacoma
    2004 Double Cab 4x4
    Moarrrrr tubez.
    Also added my movable interior platform. The "track" is made of .125" angle iron and the movable base is all aluminum (1.25" 3/16 thick). This gives an opening that's about 21" or so and can also be moved to over the cab to open up the bed.
    I'm going to add some of the grey carpet material people use for sound systems along the bottom of the aluminum so that there's no metal/metal interference between the track and platform.
    Really enjoying this project so far. Enjoying the change of pace from being a desk jockey M-F Lol.
  13. Oct 18, 2020 at 5:42 PM
    #593
    JMcFly
    JMcFly Well-Known Member
    Central FL
    2012 Tacoma SR5 4x4
    Feel like you need your own build thread to capture the awesomeness of your work
    CayucosTacoma likes this.
  14. Oct 18, 2020 at 6:22 PM
    #594
    plurpimpin
    PDX
  15. Oct 18, 2020 at 8:47 PM
    #595
    Jarman02
    Oregon
    @CayucosTacoma it looks like you went a decent bit taller on your build? How much more?
  16. Oct 18, 2020 at 9:42 PM
    #596
    CayucosTacoma
    2004 Double Cab 4x4
    At the apex of the cab it's about 4", might look a bit more than that in the photos because the angle.
    3" might be better aesthetically, but who knows.
    EDIT: Looked at the CAD model, it’s 3.5”.
    Looks pretty good in person and leaves plenty of room for body flex when wheeling. 3” still might’ve been better but I’m happy enough with how it looks.
  17. Oct 18, 2020 at 10:14 PM
    #597
    riven29
    1995 Maroon Tacoma
    Anyone else have a gap that you can see through the latch like i have or did i get crap i need to return to Amazon so water doesnt leak in?latch.jpg
    caleebra likes this.
  18. Oct 19, 2020 at 10:29 AM
    #598
    Clamber247
    Clamber247 2004 Tacoma
    Boise, ID
    Few things here or there, but it's time to use this puppy to its fullest extent!
  19. Oct 20, 2020 at 2:10 PM
    #599
    Jarman02
    Oregon
    Got my ottertex fabric samples. Seems nice and the thickness is on par or a touch thicker than my Roofnest tent, which is what I was after. Waterproof backing feels good too. Time to decide on a color and order.
    fatfurious2 likes this.
  20. Oct 21, 2020 at 5:02 PM
    #600
    jmartin2076
    Tacoma WA
    Sorry for the delay, haven't been checking the thread. I don't have any close ups but you can zoom in on the picture to see them. I think they look better than bare edges.
