How to: DIY Wedge Camper
Discussion in 'Tonneau Covers, Caps and Shells' started by Ripcord, Apr 15, 2019.
  1. Oct 22, 2020 at 4:11 PM
    #601
    JMcFly
    JMcFly Well-Known Member
    Central FL
    2012 Tacoma SR5 4x4
    I was reading through and saw this. If you have a friend with a track saw that will make cutting things straight super nice, especially the hole to get into the camper.
    otherwise you can cut aluminum with a high tooth count woodworking blade, if using a sawstop table saw remember to turn off the sensor system or you're out a blade and brake... dont ask me how I know :D
  2. Oct 22, 2020 at 6:41 PM
    #602
    2ski4life7
    2ski4life7 Well-Known Member
    Seattle WA
    17 DCLB 4x4 TRD Off Road Previously '12 DCLB 4x4 SR5
    I’ve read the front is slanted a little? What is the reason for that?
    I am thinking about making all the sides flat(maybe not the rear).
  3. Oct 22, 2020 at 7:22 PM
    #603
    b1g13en
    b1g13en Well-Known Member
    ben
    2019 TRD Off Road
  4. Oct 22, 2020 at 7:51 PM
    #604
    JMcFly
    Central FL
    2012 Tacoma SR5 4x4
    The space frame has compound angles to match the cab slant. And if you look the top of the space frame is narrower than the bottom so there will be a natural angle in to meet it plus the forward slant. I don’t like compound miters but I’m going to have to deal with them
  5. Oct 22, 2020 at 8:48 PM
    #605
    Jarman02
    Jarman02 Well-Known Member
    Oregon
    2002 Tacoma Xtra Cab
    Got my spaceframe roughed in. 57.25 inches is money! Fits like a glove. Still need to do diagonal supports. I am gonna go for a gas strut lifting floor as well. Will be primarily angle iron for that portion. Going to take some and stitch weld it to the upper square to support the floor and then the floor frame itself will be built out of an angle iron frame
    Looking at where the frame buts up against the cab, I think I am gonna do my bulkhead on the inside of the front to give the rear window room and allow me to fit the space frame more snug to the cab. For future reference, 1st gen peeps would be wise to do about 75.5 inches long or so to give the bulkhead more space and not have the spaceframe stick out to far on the back of the truck IMO.
    I also am pretty much done with the jig so if anyone in Oregon wants to buy my jig for a 6ft 1st gen taco, hit me up! Save you some time.
    JMcFly and CayucosTacoma like this.
  6. Oct 22, 2020 at 9:47 PM
    #606
    2ski4life7
    Seattle WA
    Awesome. Did you use the same 100" for the 80/20 length?
  7. Oct 22, 2020 at 10:07 PM
    #607
    jmartin2076
    jmartin2076 Well-Known Member
    Tacoma WA
    I did. Works great. Only issue I've had is with the cork seal between the frame and 8020. With the amount of rain we get in western WA it is soaking through. I'll probably replace it with something else next summer.
  8. Oct 22, 2020 at 10:09 PM
    #608
    2ski4life7
    Seattle WA
    Cool. Ah your in western washington. Want to make another one of these hahaha.
  9. Oct 22, 2020 at 10:12 PM
    #609
    jmartin2076
    Tacoma WA
    Not at all :) But if you need help or advice I'd be happy to. I see your in Seattle, I'm actually south I'm Tacoma.
    Oyster Taco and 2ski4life7 like this.
  10. Oct 22, 2020 at 10:35 PM
    #610
    CayucosTacoma
    CayucosTacoma Just think outside the Yota
    San Luis Obispo/San Jose
    2004 Double Cab 4x4
    Specs in the Build Thread
    Has it been heavy rains and noticable amounts of bleed through?
    I'm debating potentially using something like this if you're having issues under normal conditions.
    https://www.mcmaster.com/3949N128/
  11. Oct 22, 2020 at 10:40 PM
    #611
    jmartin2076
    Tacoma WA
    I would use that. I will be changing it to that or something similar. We've had some pretty good rain and when we do I get drips from the bolts going through the frame into the 8020. So watery is getting into the frame. The only other spot I'm getting water intrusion is the the corners where the bulb seal doesn't fit which let's a little water into the tent area. I'm working on that now with something similar to what you posted.
  12. Oct 23, 2020 at 5:29 AM
    #612
    JMcFly
    Central FL
    2012 Tacoma SR5 4x4
    I'd go with something like that or a butyl tape and a bead of silicone over the seam, cleaned up so it just fills the void.
    I'm in Florida so I am anticipating a lot of water
  13. Oct 23, 2020 at 9:26 AM
    #613
    2ski4life7
    Seattle WA
    @Ripcord Are your long bed plans work for a 3rd gen?
  14. Oct 23, 2020 at 10:36 AM
    #614
    Jarman02
    Oregon
    I would think butyl tape would be a cheap and more waterproof alternative to the cork. That and some silicone around the bolt holes.
    manwithtools likes this.
  15. Oct 23, 2020 at 10:50 AM
    #615
    jmartin2076
    Tacoma WA
    I agree, wish I'd have done that first.
  16. Oct 23, 2020 at 12:11 PM
    #616
    Tacman19
    Tacman19 Well-Known Member
    Dave
    Mid Missouri
    19 Tacoma SOLD
    As many as I can fabricate
    Mine don't leak but I'm sure these would in a barn stormer. They do have a gap.
    Zim
  17. Oct 23, 2020 at 12:20 PM
    #617
    jmartin2076
    Tacoma WA
    Mine look the same and I don't get enough dust or water through them to worry about.
    Tacman19 likes this.
  18. Oct 23, 2020 at 12:49 PM
    #618
    Tacman19
    Dave
    Mid Missouri
    19 Tacoma SOLD
    I bought the cheap latches. I noticed some rust already on one of the pins,(the handle pivots on the pin). Good thing is I can replace them later
    I've had considerable rain and where the aluminum and cork are joined, I have no problems. BUT...where I had a fabrication issue and the alum did not exactly conform to the gap, it leaked a little. My fault.
    Got to remember that cork has held 5 quarts of hot oil in a chevy 350 for decades....ahahahahhaha. My best try at justification. LOL
    You should be good.
    Yeah I really don't think this design would be completely waterproof. Next build I'll ditch these and go twist handle or T handle.
    Zim
  19. Oct 24, 2020 at 7:45 AM
    #619
    Jarman02
    Oregon
    Ahh, got ya, that and wine bottles ;) . I'm thinking I am just gonna go overkill on the sealing of the two sections as well as any holes in the frame. It does rain and snow here a fair bit at times and I also like to pressure wash my truck and keep it clean lol
    Tacman19[QUOTED] likes this.
  20. Oct 24, 2020 at 8:44 AM
    #620
    Tacman19
    Dave
    Mid Missouri
    19 Tacoma SOLD
    That would be a very good idea. I built mine in less than 20 working days. There are a few gaps..ahahahahahahaha.
    Zim
    But leaks at 2 or 3 corners because the perpendicular tube did not get ground flush. LOL.
