How to: DIY Wedge Camper
Discussion in 'Tonneau Covers, Caps and Shells' started by Ripcord, Apr 15, 2019.
  1. Nov 11, 2020 at 12:36 PM
    #801
    CayucosTacoma
    CayucosTacoma Just think outside the Yota
    San Luis Obispo/San Jose
    2004 Double Cab 4x4
    Specs in the Build Thread
    Also, if anyone is looking to get sheet metal parts cut there's a company called sendcutsend whose prices are super reasonable.
    You basically just upload a DXF file of what you need, choose the material and you're all set.
    I had 7 of these mounts laser cut and shipped to me for sub $40, material included.
    Everyone local to me either thought my job was too small or wanted way more than that.
    Ignore the flap disk marks and whatnot, the parts come in a lot cleaner than that.
    https://sendcutsend.com/?gclid=CjwK...BZAufUJWqJjuO1_t2GlMHAwDnPPMlzVRoCMxsQAvD_BwE
    They also offer bending as well, but I plan on doing that myself.
    124636034_361844898227590_44741700657816_d6a8f5ae8340aafa9ba51a31f82ca73c8e45bd37.jpg
  2. Nov 11, 2020 at 12:37 PM
    #802
    CayucosTacoma
    2004 Double Cab 4x4
    @Andersob85 Here ya go.
  3. Nov 11, 2020 at 12:40 PM
    #803
    Andersob85
    Andersob85 Active Member
    Brandon
    Thank you!!
    CayucosTacoma[QUOTED] likes this.
  4. Nov 11, 2020 at 12:42 PM
    #804
    JMcFly
    JMcFly Well-Known Member
    Central FL
    2012 Tacoma SR5 4x4
    I'm sending my brackets to them to get cut and bent, just need to get the bend lines added to the dxf
  5. Nov 11, 2020 at 12:44 PM
    #805
    CayucosTacoma
    2004 Double Cab 4x4
    I'm planning to finish the spaceframe this weekend and getting the doors cut out.
    Anyone have any tips or wisdom they want to share about setting the location for the gas strut mounts for the doors?
    Planning on just trial and error but wanted to know if someone had some learning they'd like to share or a better way to do it.
  6. Nov 11, 2020 at 2:34 PM
    #806
    Jarman02
    Jarman02 Well-Known Member
    Oregon
    2002 Tacoma Xtra Cab
    Thanks for the heads up on that cutting place!
  7. Nov 11, 2020 at 4:03 PM
    #807
    tomas_kazokas
    tomas_kazokas Active Member
    Tomas
    Toyota Tacoma Access Cab 3rd gen
    I'm curious about those who decided to use a 4 hole corner bracket, how did you deal with awning track interfacing around the bracket?
  8. Nov 11, 2020 at 4:06 PM
    #808
    tomas_kazokas
    Tomas
    They are sold at sailrite:
    122116 1 EA Awning & Sling Chair Spline Cording 1/4" (50 Feet) $25.00
    141100 12 4FT Awning Track Aluminum 48" $9.95
  9. Nov 11, 2020 at 4:58 PM
    #809
    Jarman02
    Oregon
    You talking about the inside bracket? You could either cut the keder rail short or mount it behind the corner bracket.
  10. Nov 11, 2020 at 7:09 PM
    #810
    Jarman02
    Oregon
    Pro tip, you’ll want to countersink the holes in your door just the slightest amount if the black rivets don’t sit flush when you put them in. They don’t have enough clamp force to pull flush otherwise. They also break like they should, so I can confirm it was the other rivets that had issues
  11. Nov 12, 2020 at 11:35 AM
    #811
    Andersob85
    Brandon
    Will you post what ends up working for you
  12. Nov 12, 2020 at 11:46 AM
    #812
    CayucosTacoma
    2004 Double Cab 4x4
    Yea, realized I need to mill a few things before I can get this squared away so probably won’t be doing the gas struts this weekend but I’ll keep you posted whenever I get around to it
  13. Nov 12, 2020 at 12:00 PM
    #813
    Nimble9
    Nimble9 visit squareonecreations.com Vendor
    Lebanon, PA
    2006 4x4 DCSB
    enough to have fun
    not sure if you still use SW, but I used to work for a VAR and if you need any SW help let me know!!
  14. Nov 12, 2020 at 12:15 PM
    #814
    Jarman02
    Oregon
    I'll be hopefully mounting my doors this weekend. Got the panel stiffeners on one door. Actually surprised with how stiff the long bed doors turned out, might no need diagonal support. For those long bed folks, you will need 5 of the 8ft Aluminium angle iron at a minimum.
    One thing I was wondering was how one might go about keeping water from running down the door and leaking into the bed of the truck if the door is open and it happens to be raining. Wonder if you could fashion a gutter of some sort.
    Also, I am thinking you could take something like a bike tube to seal up the knock-off southco latches. Basically, just cut the tube to length and then sandwich it between the latch and door on the outside face and then zip tie it around the arm end on the inside.
    2ski4life7 likes this.
  15. Nov 12, 2020 at 12:16 PM
    #815
    jowybyo
    jowybyo Well-Known Member
    Joe
    Baltimore, MD
    '14 MGM DCSB Postrunner 4wd Conversion, Debadged
    Thanks for the offer. I don’t need any help. I used it for more than 10 years. I mostly use CATIA now. It’s far better for large assemblies, complex parts and for surfacing.
    Nimble9[QUOTED] likes this.
  16. Nov 13, 2020 at 1:24 PM
    #816
    JMcFly
    Central FL
    2012 Tacoma SR5 4x4
    I finally managed to do a thing. Not sure if I want to actually make the side and front triangle supports
  17. Nov 13, 2020 at 1:45 PM
    #817
    tomas_kazokas
    Tomas
    I wasn't sure either... this video on youtube changed my mind. "2009 Truck Durability Test FORD CHEVY DODGE TOYOTA By Ford Motor Company"
  18. Nov 13, 2020 at 2:42 PM
    #818
    jmartin2076
    jmartin2076 Well-Known Member
    Tacoma WA
    I brought the top of my side supports closer to the ends, they don't meet, so that I have more open space. It's very easy for my to load and unload from the sides.
  19. Nov 13, 2020 at 3:29 PM
    #819
    Jarman02
    Oregon
    I did the same thing, I actually just did a 45 degree angle for simplicity and let that dictate where it went.
  20. Nov 14, 2020 at 1:19 PM
    #820
    nanserb
    nanserb Well-Known Member
    Elliott
    2019 ZR2 Colorado
    How are you guys building the space frame in Fusion? I made paths along a 3d sketch of the frame and the pipe tool did this:
