How to: DIY Wedge Camper
Discussion in 'Tonneau Covers, Caps and Shells' started by Ripcord, Apr 15, 2019.
  1. Dec 8, 2020 at 9:44 AM
    #961
    Wasatch
    Wasatch Well-Known Member
    I don't believe the tack welds were to blame. I'm thinking the batch of tube I got had slight warps in them already. Just another reason to measure 50 times and weld once!
  2. Dec 8, 2020 at 11:01 AM
    #962
    Jarman02
    Jarman02 Well-Known Member
    Oregon
    2002 Tacoma Xtra Cab
    The frame should straighten out once you clamp it to the truck. Also the extrusion will force other parts to straighten out. 1/4 isnt that much over a 76in length.
    Wasatch and Tacman19 like this.
  3. Dec 8, 2020 at 3:46 PM
    #963
    JMcFly
    JMcFly Well-Known Member
    Central FL
    2012 Tacoma SR5 4x4
    well looks like I will be learning how to Tig weld sometime soon. Makerspace bought a Tig so I think I may go forth and add in the mod to make the bed panels movable and make the frames out of aloooooominium
    nanserb likes this.
  4. Dec 8, 2020 at 4:01 PM
    #964
    Jarman02
    Oregon
    Not sure if its just me, but the sewing portion is by far the hardest part of this whole build. I have two more bug screens to sew on to the zippers and the rain skirts and thats it. I think I am going to skip the awning portion of the rear window as I realize we hardly ever had that propped up on our past two tents since its just more wind noise when open. Not a massive deal to sew it on later.
    Also, anyone has anyone else that built one of these for a long bed had issues with the middle of the door not sealing all the way across on the bottom? Thinking I am just gonna order some 1/4 in foam strip from Mcmaster to go on the space frame for the bulb seal to seat into. Seems using bulb seal on the frame and door is a little too thick and causes the bulging of the front and back.
  5. Dec 8, 2020 at 5:59 PM
    #965
    Dubiousveracity
    Dubiousveracity Well-Known Member
    2018 TRDOR DCSB MT
    none
    Alupanel can be routered and bent doing so along the edges would add stiffness.
  6. Dec 8, 2020 at 6:03 PM
    #966
    socalexpeditions
    socalexpeditions IG: @socalexpeditions
    Don't overthink it so much!
    For that area, use butyl to fill in the entire gap. Leave the plastic piece in place. Once you have your camper ready to go on, the bulb seal will conform and seal that area. the 1/8th" height difference isn't a big deal.
  7. Dec 8, 2020 at 6:39 PM
    #967
    Dubiousveracity
    2018 TRDOR DCSB MT
    none
    Thanks I was wondering if it was actually an issue. My concern was how structural the bulkhead was with the composite bed. If a small build up of butyl tape and bulb seal is able to sufficiently spread the load, great.
  8. Dec 8, 2020 at 6:51 PM
    #968
    Tacman19
    Tacman19 Well-Known Member
    Dave
    Mid Missouri
    19 Tacoma SOLD
    As many as I can fabricate
    If you're using the T nuts and channel you can pull the frame down a quarter. Mine was off also mostly because of lack of clamps. If you clamp the frame down all 4 corners, and weld small runs from corner to corner, side to side, it should come back in to flat, if your jig is actually flat.
    Zim
    Ayoung208 and Wasatch[QUOTED] like this.
  9. Dec 9, 2020 at 12:33 PM
    #969
    vitodaniel
    vitodaniel Well-Known Member
    Vito
    Southern NH
    2016 Toyota Tacoma TRD Sport
    Hey folks, just wanted to share a useful contact with you all. I found this guy on eBay he was offering laser cut services, designing and stuff. I did my brackets through him, it was like $31 shipped or something, then after welding them on i realized that they are too short, not sure why because i did select third gen. So he offered his help modifying DXF file at no charge.
    I have made few more things in fusion360 and had him cut it for me.
    Anyways - a good fellow that can cut anything and help designing or modifying existing design , here is his email : villicana@outlook.com
    Thanks!
  10. Dec 10, 2020 at 9:10 AM
    #970
    nanserb
    nanserb Well-Known Member
    Elliott
    2019 ZR2 Colorado
    That's great!
    Aluminum isn't super difficult to weld, the trickiest part is getting your AC balance settings correct.
    Buy a ton of ER4043, 2% lanthanated tungstens, and get to practicing!
  11. Dec 10, 2020 at 10:22 AM
    #971
    Jarman02
    Oregon
    Anyone got a link for some brackets for the wedge gas struts that will place the gas strut connected to the top of the wedge below the bottom of the strut when the lid is closed? That way the strut is pressing the wedge closed. Looking to maybe ditch the side latch to give more room for side accessories and simplify opening/closing.
  12. Dec 10, 2020 at 10:33 AM
    #972
    Ripcord
    Ripcord [OP] KM6PIM
    Jim
    Northglenn, Colorado
    Spruce Mica 2013 TRD-OR
    I used some on the V1 camper. Though turned in the other direction, if you orient them as you describe you may run into issues with them bending backwards.
    Had to drill them out for the 5/16"-18 fasteners also.
    They can be found on the "V1" tab of the spreadsheet
    Jarman02 likes this.
  13. Dec 10, 2020 at 10:37 AM
    #973
    Jarman02
    Oregon
    Ah makes total sense. I suppose we can see how things go. Do you have any pictures of how you mounted your awning?
  14. Dec 10, 2020 at 10:39 AM
    #974
    Ripcord
    Ripcord [OP] KM6PIM
    Jim
    Worth a shot atleast, keep us posted.
    Here is the bracket I made to mount the awning. Had to space it away to leave room for the side wedge latch.
    M61guru likes this.
  15. Dec 10, 2020 at 11:01 AM
    #975
    Jarman02
    Oregon
    Ah those brackets look nice! Might have to draw up something similar for Sendcutsend to cut out for me. Either way, if I get rid of the latch, Ill still have to clear the strut.
    Ripcord[QUOTED][OP] likes this.
  16. Dec 10, 2020 at 11:20 AM
    #976
    CayucosTacoma
    CayucosTacoma Just think outside the Yota
    San Luis Obispo/San Jose
    2004 Double Cab 4x4
    Specs in the Build Thread
    Here's my rough idea.
    Still need to tweak it and take off quite a bit of the metal to make it look less blocky.
    Just a piece of plate with 2 holes and a tapped hole for the gas strut mount.
    Jarman02[QUOTED] likes this.
  17. Dec 10, 2020 at 11:37 AM
    #977
    JMcFly
    Central FL
    2012 Tacoma SR5 4x4
    I like how GFC or maybe its Super Pacific uses a machined aluminum piece for the gas strut mount. But one of them also mounts the strut inboard I believe
  18. Dec 10, 2020 at 11:41 AM
    #978
    CayucosTacoma
    2004 Double Cab 4x4
    The Super Pacific looks cool, hides it too.
    If I can get some scrap aluminum, maybe I'll try something a bit more complex.
  19. Dec 11, 2020 at 7:19 AM
    #979
    Jarman02
    Oregon
    Those who have decided to skip the vent in the tent, did you regret it?
    just thinking back to other tents I have had, the vent never seemed to help with condensation
  20. Dec 11, 2020 at 10:08 AM
    #980
    Wasatch
    Frame is together, now to decide on the length of the extrusion.
    Trying to keep it compact, I'm thinking of going 7' instead of 8' (planning on a modular floor). Anyone have insight on their choice of length? Anyone go less than 8'?
