How to: DIY Wedge Camper
Discussion in 'Tonneau Covers, Caps and Shells' started by Ripcord, Apr 15, 2019.
  1. Jan 12, 2021 at 1:50 AM
    #1141
    Andersob85
    Andersob85 Active Member
    Brandon
    I saw your rig at az wilderness and was snooping on it. Where did you get your panels done? How do you like how you did the floor of the tent? I'm considering doing it like that now... how did you end up doing the floor inside of the tent?
  2. Jan 12, 2021 at 4:38 AM
    #1142
    nzbrock
    nzbrock Well-Known Member
    Noah
    San Marcos, TX
    99 TRD Prerunner 3RZ
    Your cuts need to be PERFECTLY straight. If you have a bench sander then you can straighten them out with this and a guide. Best option would be a bandsaw.
  3. Jan 12, 2021 at 6:15 AM
    #1143
    JMcFly
    JMcFly Well-Known Member
    Central FL
    2012 Tacoma SR5 4x4
    You can cut aluminum extrusion with a wood blade so long as its carbide tipped, just go slooooow, or obtain an non ferrous materials blade and still go slow.
    an abrassive blade will only get gunked up with aluminum. With aluminum you sort of work with it like wood. You sand, not grind. Had someone at the makerspace put a piece of aluminum to a grinder wheel and ruined it because it just loads up on the wheel
    side note I just thought of a way to hold the hardware in the extrusion after you pre space it out to mount the roof and anything else. Hot glue, a little drop on either side will keep it in place and is removable if you need to reposition
    I might go lazy route and stick the two of them vertically so I have something to bolt mounts onto for gear. Sure its not as structurally efficient as triangular supports but its better than nothing.
    Rando_lurker likes this.
  4. Jan 12, 2021 at 7:38 AM
    #1144
    Jarman02
    Jarman02 Well-Known Member
    Oregon
    2002 Tacoma Xtra Cab
    As others have mentioned, carbide-tipped blade. I used a Diablo non-ferrous blade on my miter saw and cut my extrusion. Cuts through it like butter. Do not use an abrasive blade, you'll have a bad time.
    Quite a few have, it's worth reading through the whole thread. Lots of good info has been posted in here.
    I modified the plans and just went with a 45 degree angle on the cross supports. Loving all the open room.
    plurpimpin and Afilao[QUOTED] like this.
  5. Jan 12, 2021 at 10:02 AM
    #1145
    2ski4life7
    2ski4life7 Well-Known Member
    Seattle WA
    17 DCLB 4x4 TRD Off Road Previously '12 DCLB 4x4 SR5
    Thanks for the info guys! Glad I asked.
  6. Jan 12, 2021 at 1:01 PM
    #1146
    mjshield2
    mjshield2 Member
    Bainbridge Island, WA
    2010 v6 access cab
    I'm trying find some dimensions/materials for making windows on the front and rear canopy panels. Anyone posted that/got an idea about what page there on?
    Buying a partially finished one that I might cut off part of the T weld as part of the sleeping support and weld the 2.5" tracks. That way I can make a modular floor and sit/stand in the bed to get out of the elements a bit more with friends.
    So much material love it. Thanks to everyone who has, and still is, contributing.
    Afilao likes this.
  7. Jan 14, 2021 at 5:37 AM
    #1147
    JMcFly
    Central FL
    2012 Tacoma SR5 4x4
    No dimensions have been shared other than overall size of the camper because the plans are a paid set. You can get the plans from ripcords website and he has the patterns for the canopy. If you have a finished canopy but needs windows you can kind of make them as big or as small as you'd like honestly.
  8. Jan 14, 2021 at 7:47 AM
    #1148
    dave.phipps72
    dave.phipps72 Member
    2017 TRD Sport ACLB
    Cool shit man. I don't have the time or knowledge for a lot of that, so I got a GFC. Yours looks awesome though!
  9. Jan 14, 2021 at 12:21 PM
    #1149
    mjshield2
    mjshield2 Member
    2010 v6 access cab
    I know the dimensions he put up are a paid set, and I'm going to be purchasing them.
    I worded by question pretty poorly--too much coffee and excitement. I'm asking about windows on the panels, and the materials used, not super sure how to install windows is the root of my question. Wondering if anyone that has done windows has some good references I could look at online?
    Anyone tried using clear boat vinyl for tent windows? Did you go the sewing route or the cement route with those??
    Thanks!
  10. Jan 14, 2021 at 12:44 PM
    #1150
    vitodaniel
    vitodaniel Well-Known Member
    Vito
    Southern NH
    2016 Toyota Tacoma TRD Sport
    Decided to test the durability of my composite panel , threw it on concrete floor and stepped on it few times. Probably will have many nasty scratches from tight trails. Has anyone sprayed their panels with bed liner or something similar?
    2ski4life7 likes this.
  11. Jan 14, 2021 at 1:22 PM
    #1151
    lukester78
    lukester78 Well-Known Member
    Luke
    97 Tacoma Single Cab 4x4
    @mjshield2 I think the easiest solution would be camper style aluminum framed windows.
  12. Jan 14, 2021 at 4:49 PM
    #1152
    NotTaco
    NotTaco Active Member
    Missoula, Montana
    2013 Nissan Frontier
    Whats Up Guys? Long time listener, First Time Caller.
    This might be a little long but here is a summary of my notes from my own process so far. FYI this is being fabricated to fit a 6' Bed 2013 Nissan Frontier.
    The Latches for the lower panels are called "Compression Latches" and can be found by searching for " RV baggage Compartment Latches" as well.
    http://www.rv-project.com/resources/rvsurplus.php has a list of surplus RV suppliers, thats where I found latches. They are upwards of $30 a piece brand new from SouthCo. Surplus is cheaper Obv.
    Go Fast Campers is now using what is called a "continuous geared hinge" on their lower panels. They are REAL expensive.
    Roof Top Tent Window Rods can be had from www.equipt1.com in Salt Lake City, "Fly Rod from EEZI-AWN 34" Long" also #ARB815121 can be had from multiple retailers.
    Windows for the truck cap portion: The ones that are used on the Vagabond Drifter come from a company called StateWide Windows. I got this information straight from one of the owner at Vagabond Outdoors.
    StateWide has not/will not return my inquiries.
    There is another supplier called Tri-State Windows in the Midwest that also sells RV windows, but they are real expensive as well.
    There is a cheaper alternative (which i will likely be doing myself), called a "push on window seal" you can Youtube Install videos. McMaster-Carr #3275T15 @mjshield2
    I will be mounting the frame to the truck with "truck toolbox clamps" with custom brackets welded to the bottom tubes. The clamps are available on Amazon.
    Here is a SailRite video with a more detailed instruction about installing bug mesh windows around a curve. https://www.youtube.com/watch?v=ofXWtGrAi4k
    Below are images of how I built the SpaceFrame, Two mitered corner rectangles aligned with two plumb bobs on center, sitting on a basic frame to hold the two frames at the appropriate height from each other. This gave me more flexibility to match the angles of the frame to the angles of the truck, rather than make a complete jig. I welded the frame in place, on the truck. Hence the blanket to protect from welding spatter. Angles were found with an angle finder, marked with a speed square, and cut with a grinder sporting a cut-off disc.
  13. Jan 14, 2021 at 4:54 PM
    #1153
    JMcFly
    Central FL
    2012 Tacoma SR5 4x4
    I like what you did there
  14. Jan 14, 2021 at 5:18 PM
    #1154
    plurpimpin
    plurpimpin Well-Known Member
    PDX
    2010 TRD Off Road 4x4
    I used Standard size aluminum framed RV windows on my front and rear panels. I bought them from a used RV parts store here for about $100 total.
    they are made to fit thicker walls ~1.5” thick so I just trimmed the depth of the frame down closer to the window (I wasn’t able to use the trim rings to secure them) and then installed them into cutouts in my panels with pop rivets through the window flange and panel. I Sealed them with butyl RV window tape.
    These aren’t the best pics but are the only ones I have of the windows at the moment. Could take some better ones tomorrow.
    first pic is my front panel that’s against the cab
    330AAD34-4A70-48C3-B550-765F75B18BB9.jpg 643B4BF3-577B-47B0-8F63-B0C521C49602.jpg 3C04CED5-8DD7-40AC-AD81-894AB7D91826.jpg
  15. Jan 15, 2021 at 5:50 AM
    #1155
    Jarman02
    Oregon
    Good to know!
    You could probably do a nice coat of spray-on liner like Raptor Liner or even roll on. I did roll on in the bed of my truck with Hurculiner and it looks pretty awesome, cant even tell it wasn't sprayed. I would be concerned though with the texture and ability to get it clean. There might be some brands out there that are a little smoother in texture.
    Alternatively, car vinyl wrap is fairly cheap for sizes like the doors and would be incredibly easy to install on the panels prior to cutting and drilling and you could protect it that way too. I know they make textured vinyl wraps as well.
    JMcFly likes this.
  16. Jan 15, 2021 at 12:18 PM
    #1156
    vitodaniel
    Vito
    Southern NH
    I was thinking going with vinyl, but still concerned if it gets scratched or start tearing apart....Once aluminum angle is riveted - I doubt I could reapply vinyl...With liner I could possibly just touch it up? Not sure..
  17. Jan 15, 2021 at 12:20 PM
    #1157
    JMcFly
    Central FL
    2012 Tacoma SR5 4x4
    scratches add character. You can always repaint or re-raptor line
  18. Jan 16, 2021 at 1:37 PM
    #1158
    JMcFly
    Central FL
    2012 Tacoma SR5 4x4
    My jig is 95% done. I’ll add the wings once I have the top and bottom frames welded can can add the 1” angled support bars. Cost about $80 with a big box of kreg screws. Already had a collection of kreg jig stuff to make the pocket holes. (Mental note move Jerry cans out of garage when welding commences...)
    Big clamps for the win.
    NotTaco, Tacman19, BaywatchDV and 2 others like this.
  19. Jan 17, 2021 at 12:49 PM
    #1159
    overlandozzy1
    overlandozzy1 Well-Known Member
    Jonathan
    2016 WHITE DCLB
    16 DCLB, ADS, 5.29s, 35s, RCI Skids, Baja Designs
    pm inbound
  20. Jan 18, 2021 at 6:28 AM
    #1160
    vitodaniel
    Vito
    Southern NH
    Painting question. Brush on, or spray can? Thinking either going with Rust Oleum clean metal primer and professional enamel, or self etching spray primer and professional spray enamel.
    Just wondering what people went with and if there is any feedback?
    TIA
