How to: DIY Wedge Camper
Discussion in 'Tonneau Covers, Caps and Shells' started by Ripcord, Apr 15, 2019.
  1. Mar 13, 2021 at 8:40 PM
    #1481
    cliffthetundra
    cliffthetundra Member
    Landon
    2002 Tundra 4x4 V8 w/ Shell and Storage/Bed Platform
    Any chance you have a way to order for the Portland area? If not, I can plan a trip up your way. I only need (2) 4x8 sheets.
  2. Mar 13, 2021 at 9:56 PM
    #1482
    Afilao
    Afilao Tacoma Driver
    SoCal
    ‘18 MGM DCSB Off-Road 6MT
    You have access to a CNC‽ Jelly
  3. Mar 13, 2021 at 10:12 PM
    #1483
    howied
    howied Well-Known Member
    Pm me your zip and I’ll see what the shipping is?
  4. Mar 14, 2021 at 8:19 AM
    #1484
    Bassshreddin
    Bassshreddin Well-Known Member
    Wes
    2019 Tacoma trd off-road
    RLD canopy, icon stage 1 lift.
    Thanks for the info, was thinking of going that route, but wasn't sure on the placement of the holes and how to drill the holes accurately. What did you use if you don't mind sharing?
  5. Mar 14, 2021 at 9:46 AM
    #1485
    Labbi85
    Labbi85 Well-Known Member
    First I bought the floor file from ripcord (my way of donating for his effort) then is used a free cad tool to get all the measurements.
    Because everything on the panel is a straight edge I used a caliper to scriber the outer line for the holes by just moving it along the edge.
    Now I went with a automatic center punch with the right distance from hole to hole (1mm difference over this distance is not really visible, so I didn't care too much about 100% accuracy).
    And at the end I just used a step drill for the 5/16 holes.
  6. Mar 14, 2021 at 10:37 AM
    #1486
    Bassshreddin
    Wes
    Thanks alot! Yeah I've got the floor and roof cut files and am using fusion 360, guess I just have to figure out how to measure the holes
  7. Mar 14, 2021 at 10:44 AM
    #1487
    CayucosTacoma
    CayucosTacoma Just think outside the Yota
    San Luis Obispo/San Jose
    2004 Double Cab 4x4
    Specs in the Build Thread
    I did them by hand.
    The roof ones aren’t too bad. Just measure the center lines of the 80/20, draw some straight lines and drill the holes so they’re spaced out evenly.
    the floor ones you could something similar for the aluminum extrusion part and then drill from the flip side for the space frame.
    the doors are a bit trickier but there’s no really critical location for the hinges
  8. Mar 14, 2021 at 10:48 AM
    #1488
    Labbi85
    lets pretend the middle of the slot in the extrusion is 0.75in. adjust your caliper to 0.75 and lock it in place with the screw.
    now just place one tip of the caliper to the edge (marked red) and pull it along the Edge (yellow marked) this should make a nice parallel line into the Protection foil.
    625F1DC5-B568-4F74-88EC-81C6E5769886.jpg AA6330CE-F7E4-4C5E-A5E8-7345B4C85EF0.jpg
  9. Mar 14, 2021 at 10:52 AM
    #1489
    JMcFly
    JMcFly Well-Known Member
    Central FL
    2012 Tacoma SR5 4x4
    I’ll help anyone in the central FL area cut panels. Having and running a makerspace is super useful
    Slashaar and Afilao[QUOTED] like this.
  10. Mar 14, 2021 at 10:53 AM
    #1490
    Afilao
    SoCal
    I wish you were in Southern California!
  11. Mar 14, 2021 at 10:54 AM
    #1491
    JMcFly
    Central FL
    2012 Tacoma SR5 4x4
    There’s dozens of makerspace in socal. My $50 a month membership fee is awesome. I have so many tools and machines at my disposal.
    Afilao likes this.
  12. Mar 14, 2021 at 6:29 PM
    #1492
    howied
    such a good idea for a project like this.
  13. Mar 15, 2021 at 6:40 AM
    #1493
    alexshredslife
    alexshredslife Member
    Alex
    North Carolina
    2012 DCSB TRD OffRoad
    Nice work! Looks awesome. I like your simple bracket solution too.
    Did you make the roof rack brackets yourself? What are they?
  14. Mar 15, 2021 at 9:16 AM
    #1494
    WacoTacoma
    WacoTacoma Active Member
    Hunter
    Colorado Springs, Colorado
    Silver 2012 trd sport
    King 2.5 /TC UCA 33" Falken MT 16" SCS Ray 10 DIY Wedge Camper
    So the brackets are made from 2 inch flat I got from Home Depot I think its about 1/8" thick ( it might be 3/16") I just put it in a vice and beat with a hammer until I was happy with it. I used left over bars from my prinsu that I cut up. They are about 7 inches shorter than the width of the camper so thats why the bends were necessary.
    I wouldnt stand on it, However it will hold skis, full sheet of plywood, etc.
    heres a better close up
    Afilao and foxrcing07 like this.
  15. Mar 15, 2021 at 9:34 AM
    #1495
    foxrcing07
    foxrcing07 KO7FOX
    Morgan
    Modesto, CA
    2019 Raptard 2001 TJ
    Dirt
    Do you have close up pictures of how you cut the prinsu?
    Twizted likes this.
  16. Mar 15, 2021 at 9:40 AM
    #1496
    vermonttacoma
    vermonttacoma Member
    Vermont
    2017 DCLB TRD OR
    Was debating putting a roof rack on and here is the parts order from Tnutz. If you want to go through 8020.net you can get some angled brackets. Photo is from another TW thread.
    WacoTacoma likes this.
  17. Mar 15, 2021 at 12:32 PM
    #1497
    WacoTacoma
    Hunter
    I basically held it up and cut to fit ive got about 3/4 of an inch clearence63454B24-03E5-4ADC-BECC-64868D40BF85.jpg
    Slashaar and foxrcing07[QUOTED] like this.
  18. Mar 15, 2021 at 12:44 PM
    #1498
    TheTacomaInn
    TheTacomaInn Well-Known Member
    Rob
    Littleton, CO
    17 OR Access Cab, OME 887,HD Dakars, 285s
    All those short beds out there. How far is everyone hanging over the cab? How much deflection are you getting at the cab over portion?
    Thanks in advanced.
  19. Mar 15, 2021 at 2:49 PM
    #1499
    Afilao
    SoCal
    Looks like people are mostly doing 100" tent so it overhangs around 40" or so. I've read that doing the taller extrusion reduces deflection quite a bit but I can't speak from experience... Haven't started the build...
  20. Mar 15, 2021 at 2:53 PM
    #1500
    WacoTacoma
    Hunter
    From my experience most of the deflection comes from the rubber bushings that the bed is mounted on, with that being said I stood top of the tent and bounced up and down and couldn't get it to contact the edge of my roof rack.
    Rando_lurker likes this.
