How to: DIY Wedge Camper
Discussion in 'Tonneau Covers, Caps and Shells' started by Ripcord, Apr 15, 2019.
  1. Apr 1, 2021 at 2:20 PM
    #1621
    foxrcing07
    foxrcing07 KO7FOX
    Morgan
    Modesto, CA
    2019 Raptard 2001 TJ
    Dirt
    Typically the non black is still clear anodized
  2. Apr 1, 2021 at 4:59 PM
    #1622
    CayucosTacoma
    CayucosTacoma Just think outside the Yota
    San Luis Obispo/San Jose
    2004 Double Cab 4x4
    Specs in the Build Thread
    Ah yea I got the OVS 270 awning. The bigger one, thing is freaking heavy. Wasn’t sure the weight rating on the iron man ones.
    I haven’t mounted it yet. Modeled my concept in CAD so it’s “easily” removable if desired to store it between trips. Hopefully have it mounted within 2 weeks.
    Andersob85[QUOTED] and sicki like this.
  3. Apr 1, 2021 at 9:03 PM
    #1623
    Rando_lurker
    Rando_lurker Member
    2006 Tundra DC
    I don't think the latches release from inside.
    You could make it work by having them latch to something that you can move or release. Instead of latching against the tube, they could latch on a sliding tab for example. Then you could just slide your tab to get the panel to open. The latch would remain in the closed position. I believe GFC did this on their second gen model (with aluminum frame).
    Oyster Taco[QUOTED] likes this.
  4. Apr 2, 2021 at 6:26 AM
    #1624
    NotTaco
    NotTaco Active Member
    Missoula, Montana
    2013 Nissan Frontier
    Awesome Progress, Great Idea with the Tie-Downs!
  5. Apr 2, 2021 at 6:57 AM
    #1625
    Spacetruckin69
    Spacetruckin69 Member
    Nate
    NW Montana
    2013 Silver DCLB
    5100s, OME 885 springs,3 leaf AAL
    This is awesome. I recently had the idea of building a wedge camper and it’s great to see what kind of materials worked well.
  6. Apr 2, 2021 at 9:40 PM
    #1626
    foxrcing07
    foxrcing07 KO7FOX
    Morgan
    Modesto, CA
    Dirt
    Decided I didn’t like the amount of sag/arch the 1515 roof framing allowed, so I upgraded to to hella tall 1530
    I wish I had pictures, but the roof had probably 2 inches of sag
    natataka likes this.
  7. Apr 2, 2021 at 9:52 PM
    #1627
    Jarman02
    Jarman02 Well-Known Member
    Oregon
    2002 Tacoma Xtra Cab
    I convinced @Ripcord to add his awning bracket files to his site. Would just need someone to cut and bend it from the file. Worked like champ with my standard awning.
  8. Apr 2, 2021 at 10:23 PM
    #1628
    vermonttacoma
    vermonttacoma Member
    Vermont
    2017 DCLB TRD OR
    Versions for those of us who used 1530 3" extrusion is also up from Ripcord as well (in the drop down menu)
  9. Apr 3, 2021 at 5:39 PM
    #1629
    Ripcord
    Ripcord [OP] KM6PIM
    Jim
    Northglenn, Colorado
    Spruce Mica 2013 TRD-OR
    Giving the people what they want :kona:
    Files for awning mounts for 4.5" & 3" extrusions are on the site
  10. Apr 4, 2021 at 6:34 AM
    #1630
    JMcFly
    JMcFly Well-Known Member
    Central FL
    2012 Tacoma SR5 4x4
    OSH Cut did my bed brackets. Send Cut Send might also be one to use
  11. Apr 4, 2021 at 10:06 AM
    #1631
    Bassshreddin
    Bassshreddin Well-Known Member
    Wes
    2019 Tacoma trd off-road
    RLD canopy, icon stage 1 lift.
    Looking at the build sheet, trying round everything off for final assembly, and I can't seem to find the seals that cover the outside slots in the extrusion. Anyone here have a link? Can't seem to find going trough the tread either.
  12. Apr 4, 2021 at 1:00 PM
    #1632
    CayucosTacoma
    2004 Double Cab 4x4
    Finally finished this thing. can’t beat the eastern Sierras!
  13. Apr 5, 2021 at 6:30 AM
    #1633
    AVGeek
    AVGeek Well-Known Member
    Boulder City NV
    2011 Barcelona Red Reg Cab 4WD
    @Ripcord how much does the angle of the front of the space frame match the angle of the cab? I’m looking at making this for my RC, but since the back of the cab is more vertical than the AC/DC models I’ve seen throughout the thread, I’m concerned about any contact at the top of the cab. Also, how much taller than the cab is the space frame?
  14. Apr 5, 2021 at 8:58 AM
    #1634
    JMcFly
    Central FL
    2012 Tacoma SR5 4x4
    You don't really need those. They are purely for aesthetics / keeping muck out of the rails. but a pressure washer can clean them out easily.
    Bassshreddin[QUOTED] likes this.
  15. Apr 5, 2021 at 12:21 PM
    #1635
    bfaris1
    bfaris1 Well-Known Member
    Brian
    2018 White TRD OR
    6112 #700/5160 w/ Wheeler’s AAL RCI Skids Front to back RCI sliders SSO Slimline (Hi-clearance soon) Sungtop Various other crap
    For anyone curious or wondering, I grabbed some of the sewable keder track from sail rite to try in the corners. We’ll see how it holds up. I’m going to try a washer to spread the load out but I’m hoping this will make a better deal in the corners with the 4 hole bracket on the 1.5” extrusion
  16. Apr 5, 2021 at 1:18 PM
    #1636
    2ski4life7
    2ski4life7 Well-Known Member
    Seattle WA
    17 DCLB 4x4 TRD Off Road Previously '12 DCLB 4x4 SR5
    Nice idea! I tried to make the flap over the extrusion to be overlapping. Hoping that reduces water. If not I think I will try this idea.
    bfaris1[QUOTED] likes this.
  17. Apr 5, 2021 at 1:23 PM
    #1637
    2ski4life7
    Seattle WA
  18. Apr 5, 2021 at 2:06 PM
    #1638
    CayucosTacoma
    2004 Double Cab 4x4
    If you cut the bracket down .40” then it’ll let you slide the keder rail underneath.
    that’s what I did and that helped a lot. I’ll try to snap some pictures
    plurpimpin and bfaris1[QUOTED] like this.
  19. Apr 5, 2021 at 2:42 PM
    #1639
    bfaris1
    Brian
    2018 White TRD OR
    Pics would be great!!
  20. Apr 5, 2021 at 11:15 PM
    #1640
    cliffthetundra
    cliffthetundra Member
    Landon
    2002 Tundra 4x4 V8 w/ Shell and Storage/Bed Platform
    I cannot attest to the fit but I know this is supposed to be the same dimensions as the megamatt duo and several people are running that.
    I bought this mattress on eBay new for like $110 with free shipping fyi, so give that a look. *edit-- they have now jacked the price up... sorry!* Super conformable and good build quality. Arrived quickly too.
    bfaris1 and AbePDX[QUOTED] like this.
